Question about Admiral AW22 Top Load Washer
Admiral Washer Water Temperature Problems
The cold water is never totally cold and the rinse cycle is always very hot. I have switched the hoses, but the problem still persists. Anyone have similar problems?
  • 574 Answers
Does it have a automatic temp control? if so turn it off and see it your problem goes away.
Posted on Sep 09, 2009
I have a maytag bravos x mct washer. It will not pump cold water the hot water comes out not the cold any ideas?
If your washer doesn't go through the washer rinse cycle, the most likely cause is the water valve. What happens is the water valve will stop letting cold water into the washer; therefore, once the washer gets to rinse it will either stop or not do anything during the whole rinse cycle.
This is because when you selected your water temperature, you selected warm/cold or hot/cold. The hot water came in and you didn't notice any problems. When it got to rinse, the cold water the cold water won't come in. Therefore, the washer does nothing.
To check the water valve, first cut the water off and remove the hoses off the back of the washer. Then one at a time point the hoses inside the washer tub and turn the water back on. If you don't have good water pressure, turn the water back off and remove the strainer that should be in one end of the hose. Inspect the strainer to see if it is stopped up, clean it and reinstall it. Now repeat this test. If you have good water pressure now, reinstall hose and your problem is fixed.
If you still don't have good water pressure, the problem is in your house plumbing and you need to call a plumber. If you had good water pressure the first time you performed the test, the water valve is bad and needs replacing.
TIMER
If your washer doesn't go through the washer rinse cycle the timer may be the problem. Sometimes the timer gets stuck in the middle of the cycle or won't turn at all. If the washer runs, but the timer doesn't turn, the timer is bad and needs replacing.
Do you have anti-flood hoses leading to the machine. If you do there is probably a loose tube in the back causing a small leak. When the hoses detect that water is still flowing after a certain amount of time due to the leak it shuts down and causes the machine to turn off during the rinse/spin cycle
By the way my advice is free cuz God is good!
May 08, 2015 | Maytag Washing Machines
Fix washing machine
WASHER WILL NOT RINSE:
TIMER
Mar 31, 2015 | Admiral Washing Machines
Amana washer will not go through rinse cycle
TIMER
Mar 28, 2015 | Amana Washing Machines
No cold rinse, only hot
Either the wires have come loose on the water valve or you have a defective water valve.Open the lid and look at the water valve. Are all wires connected?
If yes, replace the water valve.
Jun 24, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Kenmore front-load washer stops at rinse cycle
When the washer initially fills for the wash, is it only hot water entering the drum? Try switching the water temperature between hot and cold as it fills. If any of them show little or no water getting through, it sounds too easy but check to make sure water supply taps are on, and that the cold/hot fill hoses aren't reversed. Remove the fill hoses and check any of the screen filters for blockage (in the hoses and in the inlet water valve). When the machine stops and waits to fill but all you hear is a hum, it sounds like there is power going to the valve but water is not able to get through it.
Mar 03, 2009 | Kenmore 43142 Front Load Washer
Water temperature control not working
the fill hoses are backwards,,,reverse fill hoses...on the job...also your under warranty ..call for service but you can do it your self..
Jan 17, 2009 | Whirlpool LTE6234D Top Load Stacked...
Water Temperature is hot on all rinse cycles Water temperature on rinse on all modes is HOT.  Water is hooked up correctly (the delivery folks hooked it up when installing).  Steaming hot - too hot to...
if your gettig hot water on rinse.your fill hoses are not correct.rinse is only cold.switch the hoses.if that dosent solve the problem call for warrenty
Jan 03, 2009 | EuroTech EWF150 Front Load Washer
Should the washer be hot after the rinse cycle?
Try cycling a cold/cold wash and see how that comes out.. if it comes out hot then your water inlet valve is letting hot water in when it shouldn't.. conversely, try cycling a hot/hot wash and see that it does indeed come out hot... ( quick tests to verify performance)..hope this helps.
Sep 18, 2008 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
Admiral AW22 Top Load Washer Logo
170 people viewed this question
Top Admiral Washing Machines Experts
Dan Webster
Dan Webster
Sal DeAngelo
Are you an Admiral Washing Machine Expert? Answer questions, earn points and help others
