J4680 all-in one ink cartridge installation problem with 1st time install
    Director Badge:
    Uploaded 100 video answers.
  • 685 Answers
Try this...
Posted on Oct 26, 2009
  • 30 Answers
I took the same cartridge had it refilled put it back in the printer keeps saying troubleshooting print cartridge what do do
when u put in a refilled cartage the reset will not engage ,so it will always read out of ink, check printer, etc.reset you printer manually everytime u print is the only thing u can do or buy brand new ink.and install new ink then remove this will let u print once,u will have to do this every time try xing out of prompt several times on youre computer if u r printing through it and that will work,but if u r printing on straight printer u half to reset it every time. hope this helps.
Jan 04, 2015 | HP J4680 Office Jet All-In-One Printer
Scanner Error - After installing 1st time Remanufacatured Ink Cartridges
Remanufactured cartridges have too many problems. I have be using refillable with auto-reset chips and never have a problem. Google- refillable cartridges and be sure to use the proper ink, dye base or pigment. It makes a difference.
Apr 09, 2014 | Epson Workforce 520 Printer
Please show how to replace ink cartages and what number to use.
Please open this LINK and follow the instructions on how to install the cartridges. And here's the supported cartridges details... Click HERE.
Let me know if you need further help..
Good Luck.
Thanks for using FixYa.
Mar 01, 2011 | HP J4680 Office Jet All-In-One Printer
Put in new cartridges now can't get to scan?
Remove the Cartridges and clean the Electrical contacts ( golden points ) on the cartridges
Power off the Printer
If possible clean the contact inside the printer cartridge slot with cue tip.
Power on the printer and reinsert the cartridges.
It should print the alignment sheet.
Place the alignment sheet face down on the Scanner bed and press OK button on printer front panel.
If this does not work, Press the Setup button ( Ranch like symbol )
Scroll down to TOOLS - Press OK
Choose Align Cartridge/Printer - Press OK
Sep 28, 2010 | HP Officejet J4680 InkJet Printer
J4680 printer cartridge problem with color will not print color
Is this cartridge an HP factory new cartridge?
Most companies build logic into the printer to prevent refilled cartridges or third party cartridges from being used.
They do this because they have protect both the print quality and the printer from damage by poor quality ink.
Don
Oct 22, 2009 | HP J4680 Office Jet All-In-One Printer
In the middle of a print job, my cartridge refill stops feeding ink. Printer MN J4680. Does this printer hold the cartridge # in memory in order to stop one from refilling?
HP printers do not remember the cartridge serial number to reject refills (certain Canon printers do though). It sounds like you have an air bubble in the sponge that is inhibiting ink from reaching the print head. I would guess that either you or the store/internet seller that refilled this cartridge hand filled it. These cartridges should be filled under a vacuum to remove air bubbles from the sponge and allow you to fully fill the cartridge (an air bubble takes up space that your ink could be occupying). I recommend Cartridge World or Office Depot for refills. Avoid internet sellers and refill shops that have one giant all-in-one machine that does the filling for them.
Oct 09, 2009 | HP J4680 Office Jet All-In-One Printer
Canon pixima mp140 error code E4
following error codes i found
E2-2 No paper (ASF)
E3-3 Paper jam
E4 No ink
E5-5 The ink cartridges are not installed or a non-supported ink cartridge is installed ,
or the ink cartridges are not installed properly
E8 Waste ink absorber full, or platen waste ink absorber full
Apr 24, 2008 | Canon MP140 PHOTO AIO All-In-One InkJet...
Mp 460 tryin to insert ink for the 1st time
Your post is in the wrong place. I almost got you the wrong directions. LOL
Issue: How do I install the ink cartridge(s)?
Solution: Installing / removing ink cartridges MP160 / MP180 / MP460
Installing / Removing Ink Cartridges To print normally, install or remove ink cartridges in an orderly procedure. Installing ink cartridges:
  1. After confirming that the printer is powered on, open the scanning unit (printer cover).The ink cartridge holder moves to the replacement position.
    Note: After confirming that the scanning unit support is fixed into position, release your hands.
  2. Take out a new cartridge from its casing and gently remove the orange protective tape in the direction of the arrow.
    Note: - Do not attempt to reattach the protective tape once you have removed it.
    - Do not touch the gold electrical contacts or the print head nozzles after removing the protective tape.
  3. Insert the ink cartridge into the ink cartridge holder.- Black: the left slot- Color: the right slot*
    *One black cartridge and one color cartridge must be installed in the machine in order for the printer to operate. It does not matter if the capacities (Standard or High) do not match.
  4. Push up on the front of the cartridge until it locks into place. (A click sound will be heard when the cartridge is locked in place.)
  5. Confirm that the ink cartridges are installed properly.
    <1> The ink cartridge is not installed properly.
    <2> The ink cartridge is installed properly.
  6. Fold the scanning unit support and close the scanning unit (printer cover).
  7. Wait until the preparatory operation is complete; it takes about one to two minutes.
Removing Ink Cartridges:
  1. After confirming that the printer is powered on, open the scanning unit (printer cover). The ink cartridge holder moves to the replacement position.
  2. Press down on the semi-circular tab to release the cartridge and then remove it.
    Note: Handle the ink cartridges carefully to avoid staining clothes and surrounding work area.
  3. Remove and replace each cartridge individually. Or, remove the second cartridge after the first has been removed.
  4. Fold the scanning unit support and close the scanning unit (printer cover).
Nov 12, 2007 | Brother HL-2040 Laser Printer
146 people viewed this question
jasbo
jasbo
