Question about Futaba Two Servo Trays For Standard Rc Servos Inc. S3004
Can't get new transmitter working on remote control car?
I have a tamiya lunchbox with fet speed control TEU101BK and Futaba FP R102JE 2 channel receiver. I have just bought a Futabe T2ER 27Mhz 2 channel transmitter and placed 27.145 R-08 crystals in to it. I can't seem to tune it in when i try it joults forward and back. steering is ok. Have i put correct crystals in or is there another problem? HELP PLEASE
  • Anonymous Mar 17, 2014
    I am using a futaba 7c radio and futaba 6106 rx with a detram 40 amp speed control and servos. controls work okay the throttle doesnt.
  • 421 Answers
Double check that the crystals are in the correct parts of the radio gear. You should have one marked with T and that goes in the trasnmitter and one marked with an R and that goes in the receiver. Make sure that the batteries are fresh and that the aerial wire of the receiver isn't damaged.
Posted on Jan 17, 2010
    Scholar:
  • 66 Answers
Your receiver is old 89-92 and will not work properly with your newer transmitter. you need a R122JE receiver.
Posted on Oct 03, 2009
T2er no information on how to charge batteries
YOU SHOULD HAVE A CHARGING UNIT WITH 2 LEADS 1 IS A JACKPIN THAT PLUGS INTO THE TRANSMITTER THE OTHER LEAD HAS A CONNECTOR SIMMILAR TO THE BATT TO RECEIVER IN THE HELI IF YOU HAVE A REMOTE CHARGING SOCKET IN THE HELI JUST PLUG IT IN. IF NOT DISSCONNECT THE BATT FROM THE RECIEVER AND CONNECT DIRECT TO THE BATTERY
Aug 18, 2011 | Futaba 6CH Digital Transmitter and...
Tip
Dei viper python valet hornet boa transmitter programming help
DEI REMOTE PROGRAMMING INSTRUCTIONS
Need a DEI Remote Replacement Now? Try our all New Remote Quick-Find
Not sure what type of Replacement Remote you need?
In order to enter Learn Routine, the Valet/Program push button must be plugged
into the main brain's Blue 2 Pin Port (Look for a small black push button located under
the drivers dash or drivers kick panel somewhere). If you do not have the Valet/Program switch, you may order it at www.lesscoelectronics.com or www.lesscosales.com
1)
Open a door and make sure the dome light is on.
2)
Turn the ignition on to the RUN position or you may also start car.
3)
Within 15 seconds press and release the Valet/Program push button
to select the channel you wish to program. For example, press and release
once for channel 1 (arm/disarm channel).
For Channel 2, press and release twice (trunk release).
For Channel 3, press and release three times (remote start).
(Some DEI systems require different programming for different channels. You
can get specific installation manuals with remote programming instruction)
Press and hold the Valet/Program push button once more. You should get a
confirmation chirp/horn-honk or a flashing LED light (If installed).
If you do not get a chirp/horn-honk the alarm may have a jumper in
the alarm that has the programming feature turned OFF (disabled).
4)
Once the alarm chirps/horn-honks keep holding the Valet/Program push button.
5)
Press the button on the transmitter that you would like to control the selected receiver
channel. A chirp/horn-honk will confirm that the code has been learned. If programming
more than one transmitter repeat step 5. Old transmitter codes will be dropped only
if programming 4 new transmitters.
6)
Once the code(s) are learned, the Valet/Program push button can be released.
Learn Routine will be Exited if:
Ignition is turned off
Door is closed
Valet/Program push button is pressed too many times
More than 15 seconds elapses between steps
One long chirp/horn-honk indicates that Learn Routine has been exited.
on Jul 29, 2010 | Car Audio & Video
Regarding the BLS452: 1 What is the maximum (electrically driven) rotation? 2 What are the pulse widths for the maximum rotation? 3 What is the current consumption on 6V? 4 Is it digital, & if...
Some of the information you're requesting is at the following link.
http://www.helipross.com/futaba-bls452-brushless-ep-car-high-torque-servo.html
The current consumption will be dependant on the loading of the servo.
Digital Servos give and quicker resoponse to your input and provide a higher torque in a shorter period of time. Full explanation st the following link.
http://www.futaba-rc.com/servos/digitalservos.pdf
Jun 23, 2011 | Futaba Bls452 Brushless Ep Car Hi-torque...
Plugged in charger and got not light on charger for transmitter. Replaced rechargable batteries with AA's turned on transmitter not lights on transmitter. Rechecked polarity on batteries and they were in...
what charger?
it needs to be designed for that particular transmitter, four cells, reverse polarity to Futaba and Hitec
http://www.rcgroups.com/forums/showthread.php?t=839823
Apr 05, 2011 | Spektrum Dx5e Dsm2 5-channel Air Radio and...
I am trying to locate a Manuall for Futaba 7c radio transmitter thank you Andrew Wilson .
Glad to HELP YOU!
You have HERE a list of ALL MANUALS (scroll down until you will see your 7c product) and just HERE the manuals for a SIMPLE 7C RADIO TRANSMITTER (as you have indicated in your post).
My best wishes!
Mar 17, 2011 | Futaba Toys
Steering servo makes hard rt turn without turning steering wheel. batteries are fully charged and all connections appear secure. can temporarily eliminate prob by turning transmitter off/on.
2 possible problems:
transmitter-The variable resistor inside your transmitter is stuck fully on. Take apart the transmitter - look for the part under the wheel. It should have a 3 wire variable resistor under there - check for broken wires shorting to the other side or simply broken solder joints.
2nd possible answer is the car has a shorted output drivers on the motor controller board.
hard to fix without a schematic.
the guaranteed seo services provider
Apr 13, 2010 | Futaba 3pm-fs Pro 3-ch Synthesized...
How to reset tamiya speed controlers
i have never heard of a reset????????????
there are usually 2 adjustments on them though
1 for throttle start point
1 for braking
Mar 15, 2009 | Dmm Hpi Subaru Impreza Wrc 2004 Car Body...
I have a Futaba T9CP transmitter sending to a FP-129DP receiver and on to 6 digital servo's 4 hitec and 2 futaba and they all appear to be delayed in there response to the transmitter movement and they...
have you got any expo dialled into the settings, this will delay or rather soften the response to your servos, the glitching you are getting may be due to you be close to the reciever and swamping the sinal hence the glitching, see if it goes when you walk away from the transmitter
Apr 22, 2008 | Radio Shack (15-2147) Remote Control
Futaba Two Servo Trays For  Standard Rc Servos Inc. S3004 Logo
189 people viewed this question
Top Futaba Toys Experts
Andrew Taylor
Andrew Taylor
Are you a Futaba Toy Expert? Answer questions, earn points and help others
