Question about Tools & Hardware - Others
Hi i have a macallister router 127r but can not get spare parts for it i need a 1/2 collet plus collet nut will any other make fit it cheers andy
efs_perpends
  • 1996 Answers
SOURCE: Back in December 2009, I wrote asking why my Freud
Thanks for the follow up....
I'm glad your problem was resolved in the end.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Posted on Jun 21, 2010
joboo1
  • 257 Answers
SOURCE: Need a 1/4 inch collet for a craftsman 315269210 router
Pssssssttt ( ya wanna know a secret?) When you buy a product from Sears, they make nothing. They have things made to their specs by other manufacturers. So what are the odds you searched a part number and came up with the exact same item made by somebody else? More interesting - Ryobi started as a die cast business in 1943 and Milwaukee has been around since 1924. Do you think they might make parts for each other or did Ryobi ( Japanese Co who has a manufacturing facility in China) make a cheaper part that uses the same number on purpose? I think you might be pretty safe with the cheaper part. Good Luck, this should Fixya!
Posted on Mar 19, 2009
efs_perpends
  • 1996 Answers
SOURCE: how do you fit 6mm collet cone on new produce
You have, I presume, already locked the spindle and loosened the collet nut with the wrench, have you not?
Once the nut is loose, you should be able to remove it by spinning it off the threads by hand. Then insert the 6 mm collet cone into the collet,
carefully thread the collet nut back onto the collet, and tighten it with the bit in place.
Sometimes bits are a snug fit, especially into a new collet. If you have some fin sandpaper you can gently chamfer the very end of the bit where you first insert it into the collet, and this may help to insert it. If you have to, push a bit.
I have noticed that some companies tend to mill the shafts of their bits a little too close to the exact tolerance, or even oversize them slightly, and this can cause frustration when inserting their bits. In exceptional circumstances, I have resorted to polishing a couple of small bit shafts with very fine (600 grit or so) emory cloth, just to allow the bit to enter the collet. I would not recommend this with a new router collet, unless you have checked the bit with a micrometer and it is oversize. Odds are you just need to break things in a little.
The force need not be brutish, but you may need to use some force, yes.
If I've managed to answer your question or solve a problem, please take a moment to kindly rate this post....thanks!
Posted on Mar 29, 2009
SOURCE: How does one change from one collet size to
I just did this on my black and decker router. You need to unscrew the nut that holds the collet and remove it altogether. Then slip out the collet in there and replace it with the new size. Take care to notice how it goes in when you take the old one out. Then rescrew the nut that holds it in place and tighten. My router had three collets and only one of them works for each size, so if it doesn't tighten properly, it may be the wrong size. Good luck.
Posted on Apr 28, 2009
efs_perpends
  • 1996 Answers
SOURCE: The router bits will not fit in the collet.
The collet is loosely screwed on, correct?
Is it close, or 1/4" off. You may need an adapter for different sized bits.
I have noticed, particularly with Freud bits, that they seem a bit oversized. Try putting the bit in the collet before you insert the collet into the router.
If you're very careful, you can use fine emory cloth (like 400 grit or higher) to polish the bit by cutting a long strip and clamping the bit in a vice, then gently polish the shank a little to allow it to fit into the collet. Pull back and forth on the ends of the sandpaper like you were buffing shoes, but I would only recommend this if you can use a micrometer to check the shank and it is in fact oversize.
You could create a dangerous situation if you polish too much and the bit is not held securely in the collet and flies out when the router is under load.
Another technique is to sand a slight chamfer on the end of the bit to help it slide into the collet.
Or return it and try another brand.
Posted on Aug 29, 2009
I have a B&D Router KW850E. It has collars and collet nut to take bits with 1/4 inch and 5/16th's shank. Can I get a collet nut and collar for 12mm or 1/2 inch?
probably not as the shanks of the router bits fit in the spindle shaft of the router which is around 1/2" dia
could always talk with manufacturer as to find an adaptor or like bit of equipment
Jan 19, 2017 | BITS Tools & Hardware - Others
Router bits wont fit on my router collet nut is to small.
The two sizes (in the US) for router bit shanks (and collets) are 1/4 inch and 1/2 inch. Some routers use only a 1/4 inch collet. Routers with a 1/2 inch collet also come with a 1/4 inch collet. You need a 1/2 inch collet to hold a 1/2 inch shank. Good luck.
Jan 16, 2013 | Tools & Hardware - Others
Collet stuck in shaft.
On some models the collet stays put on purpose. You don't have to remove the nut either. But if you really do have to remove the collet and it is the type that is supposed to come out (maybe you need to use the 1/4 inch collet) then just stick a bit into it without the nut and give the bit a sideways whack with a piece of wood. If the collet has been pressed in tight by the nut without a bit in place, then you won't be able to fit a bit into it, and maybe the collet is ruined. Find the largest diameter shaft you can to fit into the hole and pop that sideways. Good luck.
Dec 28, 2012 | Bosch 1617EVS 2 Router
I have a brand new Ryobi router model ERT241200. Am I supposed to insert the 1/4'' collet into the cavity where the collet nut is, then insert the bit into the collet and tighten the collet nut? I thought...
Do you have the collet upside down? It should fit in nicely and the lock nut fit over the top, no problem, If it doesn't, something is wrong. They only make 2 sizes of collets for router bits, 1/4 and 1/2 , if they get their parts from somebody who makes just collets, you could have easily gotten a different size in there. See if a router bit will fit the hole, then go to the store where you bought the router and ask them to try it in your router and see if it fits, they might have collets on the shelf. Check it out.
Jun 03, 2010 | Ryobi Tools & Hardware - Others
Router bits
Mike, The fit is just a little more snug than you expect. The collet is springy, and will expand to fit your bits, even if they were oversize (which is very unlikely). Put on a leather glove and just push the shank of the bit into the collet. Do not try to file down the shank of your router bits, you will only make them run eccentric. You don't need to remove the collet. Just loosen the locking nut about a half turn after it is easy to turn. Good luck. Thanks for using FixYa. Al Kupchella
Apr 20, 2010 | Freud FT2000E 3 Router
How does one change from one collet size to another size. My Freud router came with the 1/2" collet installed and I need to change to the 1/4" size supplied with the router to fit a bit I want to use....
Apr 28, 2009 | Freud FT1702VCEK Router
Hi I have A freud 2000 and have had it for several years but I only recently removed it from the box (long Story) I was trying to put in the 1/4" collet adapter ad it would not go in at all as long as the...
I have had a similar problem with my hitachi m 12 v. I ground the end of a long flat piece of metal so that it would fit around the collet. Mine had sort of a lip on it that the home made tool would fit under. the thing I made was shaped like an  open end wrench. I had to grind it down so it would be thin enough to fit under the lip and just fit around the collet. Then I hit it with a small hammer. a few times on each side of the collet. I kept going from one side to the other until the collet popped out.
Jan 30, 2009 | Freud FT2000E 3 Router
I am unable to get a tight fit on my router bit.
could be a couple things. First how is the shank on the bit e.g. is it worn down, second is it the right size for the collet being used (have to ask) and what is the condition of the collet and collet nut. What I would do is make sure there is nothing to prevent from completely tightening the collet nut. Also make sure if the collet locks into the nut that it is properly installed. Lastly make sure that you use the wrenches provided to tighten the assembly. If this doesn't help please provide the model number and brand and I will do some more research.
Jan 02, 2009 | Milwaukee 5615 21 Factory Reconditioned 1...
Tools & Hardware - Others Logo
987 people viewed this question
Top Tools & Hardware - Others Experts
J.D. Browning
J.D. Browning
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
