Question about Whirlpool LER5636P Electric Dryer
I have a Whirlpool gas dryer that buzzes when I turn it on and gets hot, but does not rotate.
  • 304 Answers
The problem you describe sounds like a broken belt. The steps below outline how to check for that and disassemble if necessary.
Disconnect Power. Lift Cover on lint filter. Remove two Phillips screws taking care NOT to allow them to fall into the blower housing. Place putty knife in the seam between the top and front panel about 2” in from either side. Push in on clip while pulling control panel forward and tilting putty knife handle up, all at the same time. Same on opposite side. Raise top all the way.
Check for belt on drum half way back on the drum running from left to right. If belt is missing or broken replace with part number 341241 later in this process.
Looking down inside dryer on left and right see a 5/16" hex head screw about 6 inches down. Remove each side while holding front panel in place. Pull top of front panel about 3 inches forward from sides and then pull up. This will disengage the front panel from lower pressure clips and allow you to turn it sideways and expose the dryer interior. Rotate front panel to right to get it out of the way watching to ensure wiring is not damaged.
Place new belt over drum groove side down if old one was broken. Check white idler pulley for free rotation before installing in holes of floor under motor pulley. Replace with part number 691366 if rotation of pulley is not free or if it appears worn. Loop belt with ribs inward and pass through the open space in the idler arm below pulley then pass loop over motor pulley rib side down. The configuration at the motor should now look like the Whirlpool model in the image below:
http://www.applianceaid.com/images/belt-config.JPG
Grasp front edge of dryer drum and rotate counterclockwise slowly to align idler and motor pulley and to remove any twists in the belt.
Reverse disassembly process to re-assemble. Good Luck
Posted on Sep 10, 2009
Gas valve buzzing
gas regulator mate,between the supply and the appliance
Dec 23, 2011 | Whirlpool Dryers
Dryer does not rotate, makes buzzes as if wanting to start rotation
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Sep 13, 2010 | Whirlpool Dryers
Not heating up Gas Dryer
Modern gas dryers do not have a pilot light. They have an electronic ignitor (glow or spark). A glow ignitor turns on several seconds before the gas turns on and should get orange hot. A spark ignitor should make a clicking or buzzing noise.
Most likely the ignitor is bad but you can check it fairly easily to make certain. The best instructions I have found are at
http://www.acmehowto.com/howto/appliance/dryer/gdryer/check/ignitor.php
If it is the ignitor it can be replaced with a few hand tools. Remove the bad ignitor. Write down the make, model, and serial # of your dryer. Call your local appliance parts store to see if they have one it stock before driving over there.
Dec 22, 2009 | Whirlpool Dryers
The dryer will get hot but the drum will not go around
More than likely, the belt is broken. Otherwise, the drum motor is shot. (That's not very likely though).
Apr 22, 2009 | Whirlpool LGR5636L Gas Dryer
Dryer won't rotate stuck on fluff
one of two things has happened the belt is broken or the electric motor has failed
Apr 13, 2009 | Whirlpool ET8CHEXSQ Dryer
Whirlpool gas dryer makes buzzing sound when started, stops mid-c
Maybe something fell down into the filter housing. Get the back off and inspect it with the power disconnected.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Feb 17, 2009 | Kenmore 62602 Electric Dryer
Whirlpool Gas dryer ignites when I first turn it on and gets hot but won't stay hot or ignite again.
replace the 2 coils on gas valve after warm up they fail to open valve to reignite burner
Nov 03, 2008 | Whirlpool LGQ8611L Gas Dryer
Dryer wont get hot in the am i try it it will wrk for one load then wont get hot same thing for 4 days now
I have a Whirlpool dryer with LP gas, 7 1/2 years old. It will fire up once or twice after started then the next time it is supposed to fire it will make a buzzing sound. No heat. It will not produce heat after this until it sits for awhile then the same thing, will fire once or twice then no more. I replaced the ignitor and this did not solve the problem although it did have a consistent firing for about 3 minutes immediately after I replaced the part. then it started buzzing again and would not fire anymore. The propane line doesn't appear to be the problem either since it will work initially. Also the gas water heater in the house works fine.
Sep 23, 2008 | Kenmore Dryers
Whirlpool LER5636P Electric Dryer Logo
Top Whirlpool Dryers Experts
Tim Whalen
Sal De
Craig Butler
Craig Butler
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
