Canon Pixma iP6600D InkJet Photo Printer
Problem for Canon Pixma iP6600D InkJet Photo Printer
Screen shows error code 6500
By mahlernoll on Sep 09, 2009
Ihave also been getting rints that are off by about 1/4 inch, showing white paper at the end (4x6 prints) and a mark across the to that looks like it has slight score marks, as if I wanted to fold and cut it here, about 1/2 inch from top.
Clarification Request
Posted by gerand177 on Sep 10, 2009
Here is some great PRINTER solution by Some FIXYA EXPERT. Get any kinds of PRINTER solution from bellow. » Brother Printer Solution » Canon Printer Solution » Epson Printer Solution » HP Printer Solution » Lexmark Printer Solution » Xerox Printer Solution » Other Printer Solution 7
Solution #1
posted on Oct 01, 2009
Not Rated)
all-guru
Rank: Guru
Rating: 86%, 236 votes
The 6500 error code is a logic board error code. The PCI Bus error is detected by the ASCI. Sounds like it needs new logic board. but i suggest you to first of all you can try to reset your printer -
1. Turn the printer off with the Power button (if available).
2. Disconnect the data cable from the printer.
3. Unplug the printer's power cord for approximately 10 minutes, and then plug it back in.
4. Turn the printer back on. If this works you're done, if not try the next step.
1. After confirming that the printer is powered on, open the paper output tray.
2. Open the top cover and wait until the print head moves to the center.
3. Open the inner cover and check that ink tanks are properly seated.
4. Properly seated
5. Press down on each ink tank until a click is heard.
6. Close the inner cover and top cover
if reset method not works for you then you go for the new logic board replacement .............
Good Luck!!
Thanks
Was this helpful?
Yes
No
Solution #2
posted on Sep 11, 2009
Not Rated)
dejibank
Rank: Master
Rating: 75%, 10 votes
Was this helpful?
Yes
No
Popular Solutions for Canon Pixma iP6600D InkJet
Questions and Unsolved Problems for Canon Pixma iP6600D InkJet
Do you recommend Canon Pixma iP6600D InkJet Photo Printer?
Answer
Answer
cannon pixma ip 6600d errow vo43 cant reconize black cartg changed black 3 times
Answer
i have a canon ip6600d. when i turn it on the screen gives a U150 error and reads:The following ink... (More)
Answer
My Canon iP6600D printer has a new black inkjet cartridge in it but it won't print any black and... (More)
Answer
the flap that guilds the paper clicks too far forward and then touches the rollers this then makes... (More)
Answer
hicanon pixma ip6600d printer will not work with 64 bit windows 7 any idea
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Printers Experts
Top Printer Repair
(800) 836-9287
Celebrating 14 Years Of Outstanding Printer Repair...
Laser Repair 911
(918) 583-5483
Elite printer Services, Inc. is a full service HP...
Elite Printer Services
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
