Question about GE Profile 26.6 cu. ft. Side-by-Side Refrigerator with Dispenser TFX27PRBWW
Model# psh23sgpabs, no power to compressor from inverter 115-230.Yes it plugged in got power to temp display.Any reset switches,thanks mike
  • 11 Answers
Check Water collection unit and empty if full also clean air filter may also have a reset button for HP trip
Posted on Sep 09, 2009
Serial#C11088451 no a/c output after switch is turned on from recepticle & battery charge % or output power watts display not working
Check inverter fuse, the fuse contacts and, check switch itself. I have seen numerous failed switches of the same configuration on other devices
Dec 30, 2011 | Xantrex Technology Statpower XPower...
My Frigidaire Freezer is not getting cold and my fridge temp is to warm. I am work so I cannot give you the model number, can you still help.
Hello Lisa,
Thanks so much for choosing my ad for your fridge problem. Even though you do not have model number I am not to worried about it. As I already know I feel your problem. Please read Below my solution and if you feel that this is the problem, then if you can rate my solution accordingly as well as some nice words, I would appreciate it very much. Feel free to save my information and call on me anytime for anything I can help you in my areas of expertize. Thanks, Mike.
I of course read your problem . A lot of times when fridge is running but not cooling it can be as simple as just cleaning the coil. Take off the bottom back panel. (make sure you unplug fridge) and once you get the panel off, look in there if you see the hoses/coils dirty, they need to be cleaned and use a shop vac to really clean it and sometimes I will use a can of that compressed air that people use for computers. ANYWAY, if it is at all dirty, it needs to have a good cleaning. IF your compressor motor is real hot, then it has overloaded. In other words, its working to hard because of the dirt build up. A lot of people say, hey my compressor is running, but its not getting cold. Most the time it is running, but not at full capacity because it is dirty the coils and vents etc... Now, you have to let the fridge compressor cool down completely after you have cleaned it real good, then plug back in fridge and keep an eye on temp to see if it gets cold like normal. IF not, then what needs to be checked or replaced is the starter relay and most likely the capacitor. that is the switches the plug right into the compressor. You trace the wires that go to the compressor, and you will notice it hooks into a couple parts that plug into the compressor, that is your starter relay and capacitor. This can be replaced yourself. But first lets try the good cleaning method. AS a note: even though the compressor is running and if it is cleaned and still does not cool, the starter relay and compressor could have gone out, and those parts are designed to kick start the compressor at higher amps to have compressor operate at full capacity. I hope this helps you. Mike from fixya.
Oct 24, 2011 | Freezers
Kitchen Aid refrigerator, model KBFA25ERWH01 – French Door / Bottom Freezer. Not cooling both frig & free. Unplugged to the compressor cool down. Unplugged and removed the capacitor and relay (DID NOT...
If the refrigerator try's to start and then shuts down, something is going the burn up. If it doesn't run, call a repair service.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/dan_77d17b8918f54455
Apr 01, 2017 | KitchenAid Refrigerators
Reset Switch
Try disconnecting the wire going to the t terminal on the primary control. If the unit shuts off, you have a pinched thermostat wire or a bad thermostat. If it continues, change the primary control. Yes, you can easily replace this control as long as you get the same replacement model.
Jan 24, 2010 | Heating & Cooling
Penguin model 610012-001a/c compressor won't start
I would check to make sure that the control is sending the "cool" signal to the control unit. LO on the room temp display usually means that the fan speed is set to low. Is LO and Auto showing on the display at the same time. Try resetting the thermostat first. Hold down the Mode and Zone buttons with the tstat off. While holding them down, turn the tstat back on and hold the buttons down until FF appears on the screen. Release the buttons and try the AC.
If this does not work, on the control board is a freeze control switch plug (blue usually). Try unplugging this unit and insert a small jumper wire. If the Compressor comes on and runs then you have a bad freeze control switch. If not, then you should replace the control board.
Hope this helps,
Jeff
Jun 23, 2009 | Dometic Rooftop RV Air Conditioner
Changing the temp read out format, 2001, 525
Im not sure which BMW your drving, but i belive in E46 3-series, you cycle the BC button till the temp is displayed, the click the trip button on the right side of the insurment cluster
Dec 14, 2008 | 2001 BMW 5 Series
DISPLAY INTERMITTENT
Mike, The problem with your laptop is the inverter board. This part changes the DC to AC to power the backlight.
Please list the manufacturer and model of your laptop and I will look up your memory location.
thanks
Jan 21, 2008 | Computers & Internet
Refrigerators Logo
243 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
