Question about Garden
Troy-Bilt TB525CS Line Keeps Being Sucked into Housing
I have replaced the line on my TB525CS many times. Now however, when I put new line on, wind it in and start the weed eater, the line sucks back into the housing. I then repeat the process with the same results.
What could be causing this? I've had this trimmer for 6-8 months and this is the first time this has happened.
  • field4kids Sep 09, 2009
    Fortunately (or unfortunately) the spool will only turn one direction when winding the line - counterclockwise. This is the "Speed Spool" where you thread the line through the head and then wind it up. You don't remove the head to replace the line.
    However, the manual says to turn the head clockwise but it will not turn that way. Many others have said that this is an error in the manual and that counterclockwise is the way to turn it.
    As I said, I have done this many times (2 x a week when doing the yard) for 6-8 months and it just started happening...very strange.
  • Lewis Jul 22, 2013
    This has recently happened to my trimmer as well but it is 4 years old. After re-feeding the line 4 times this spool will not turn at all. Any suggestions? I would bet yours is still under warranty. Still a hassle.
  • 279 Answers
You may have wound the line in the wrong direction. Check it out. We all do it at least once...Lee
Posted on Sep 09, 2009
  • eldee Sep 09, 2009
    You then may want to go buy a new spool and head. There may be something broken that is not apparent but causes the problem...Lee
The string on my Troybilt tb70ss just keeps coming out of the spool when I try to weedeat. I am pretty sure I have followed the directions. What is the problem?
there should be a small hole to put string in on center of spool.
you might be winding the line the wrong way around try winding line in other direction.
Jul 16, 2011 | Troy Bilt Tb70ss Gas Trimmer
Line keeps breaking off inside case
Hi, Check your line size. This tip, written some time ago, explains the nomenclature of the spools, and how to wind them.
http://www.fixya.com/support/r2827867-winding_line_trimmers
Best regards, --W/D--
Jun 02, 2011 | Troy Bilt Tb70ss Gas Trimmer
What is the fuel line size for Troy Bilt TB525CS Trimmer?
Yes, something special to know. If the new fuel line is going into the gas tank, be sure to cut a steep angle on the end of the line going into the gas tank. This will allow enough of the line to get into the tank where you will be able to grab it thru the gas fill opening with needle nose pliers and pull it thru.
Apr 14, 2010 | Troy Bilt Tb425cs 26cc 4 - Cycle Curved -...
What size string do i need it is a tb525cs
Probably .065 to 080 line will probably do the trick .A line with 3 or 4 edges works great on everything
Oct 21, 2009 | Troy Bilt Tb70ss Gas Trimmer
Can not remove spool to replace string
If it's like my Ryobi, the alignment arrows are for feeding in string, not removing the spool. When aligned with the arrows, you should be able to insert two pieces of line into opposite sides of the housing. The ends of the line will come out of the spool next to a tiny hole. Put the end of each of the two lines into the holes, then pull the two lines from the outside. This will lock the ends of the line into the tiny holes in the housing. Now you can turn the housing by hand to wind the lines onto the spool. I think it will take about ten feet of line (on each side).
Alternatively, spin the bump stop out of the assembly. This holds the spool in, so when the bump stop is removed, the spool comes right out.
I hope this helps.
Jul 01, 2009 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
Describe string replacement Troy- Bilt TB5755SS
Cut two separate pieces of string, about 7 ft. each.
Stick the end of the line in the hole on the inside of spool.
Wind clockwise onto spool, putting the line that is closest to the ground on first.
Once you have winded this piece on, lock the last 4 inches of line through the slits on spool.
Repeat process for second piece of line, locking the last 4 inches in slot opposite the other locked in piece.
Put the spool on the trimmer, feeding the end of lines through either hole on trimmer.
Before you push the spool all the way on, pull the strings out of the locked position.
Jim
Jun 23, 2009 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
Line stuck inside head of troy-bilt trimmer
Take an awl or small diameter screw driver, same size or a bit smaller dia. than the line dia., and push it through the hole from the outside of the line head. This should push the piece of old line through the hole.
Recommendation: Leave at least one inch of line on the inside of the head, so you can grab it easily when you have to replace the line. I'll carry a pair of long nose pliers on me when I use my trimmer, so I can easily grab hold of the inside piece to pull it through.
Jun 12, 2009 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
The starter line on my trimmer will not pull at all.
Remove spark plug to see if problem is in engine or drive unit
May 20, 2009 | Craftsman 25cc Gas Line Trimmer
Line replacement on Troy-Bilt TB525CS trimmer
This was my problem as well when I initially purchased. After letting it sit for a week due to frustration...I tried again. I believe that the manual is wrong when it states that the winding is clockwise and could cause the teeth to eventually wear down. I watched the motion of the speed spool when I gently tugged on the line simulating the centrifugal force...there is no way that you can wind it clockwise and expect it to stay. I simply wound it COUNTER-CLOCKWISE to get the desired result. I finished trimming the lawn and had no more problems...except for learning that I cannot edge along concrete without the line wearing quickly.
May 08, 2009 | Mtd Garden
Garden Logo
656 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
