How do I change my printer to black ink instead of color.? My color cartridge is dry & I can't gbet another right now. the printer is stuck on color so it won't print.
  • 590 Answers
Just remove the empty color cartridge and yse your printer with black cartrdige only. Most of the printer like HP will print using the available black cartridge only. Simple
I hope this is useful to you
Posted on Sep 09, 2009
  • Hi,
    Just remove the empty color cartridge and use your printer with black cartrdige only. Most of the printer like HP will print using the available black cartridge only. Simple
How do i get the black ink to work?
Swipe ink outlet of black cartridge with a kleenex, If ink doesn't flow normally, it's defective, dry or stucked. If you believe it has ink, take it to a refill site and ask them to apply ultasound to get it work. If no result, you should buy a new cartridge or if it's new, claim your warranty for it!
Jul 20, 2015 | Brother Mfc-6490cw All-in-one Inkjet...
How do I print out in only black and white ink instead of using color ink?
Go to printer preferences;
Go to maintainance, select ink cartridge settings-- a drop down menue will have 3 choices--use Black only
use Color only
use both Black & Color
Click on the one that you want - you can change preferences at any time
Jul 05, 2012 | Canon PIXMA iP1600 Printer
When I print from the internet my copy prints my color comes out a different color I think it might be my black ink is off I have a dell 946 all-in-one printer.
Are you using Dell Series 5 ink cartridges?
Can you copy a document under the glass? Black & White and color? Do they look ok?
If you unplug the printer from the wall and remove the power brick for 60 seconds, this will reset any error messages the printer has. I would then plug everything back in.
Power on the printer.
Open the printer(with the power on) and take out the Dell Series 5 black cartridge and then reseat it. I would then take out the color Dell Series 5 ink cartridge and reseat it. Now close the printer and it will print an alignment page.
Any error messages?
black cartridge = black side(left side) color cartridge = color side(right side)
photo cartridge = black side(left side) color cartridge = color side(right side)
Dell Series 5 ink cartridges have a sensor in them that cannot be reset. Article on refilling Dell ink cartridges .
Dell Series 5 ink cartridges can be purchased at Staples, Walmart or Dell's Website.
It's possible to get a Dell Series 5 ink cartridge with a bad sensor. I would that these back to the place of purchase for a replacement or a refund.
Rick
Jul 27, 2011 | Dell 946 All-In-One InkJet Printer
All the colors won't print. Could there be dried
It seems that you have a clogged printer head.
This will need cleaning.
Usually you can do this with denatured alcohol and a cotton swab but check your user instruction guide to see what is recommended.
Apr 07, 2010 | Epson Stylus C84 InkJet Printer
HP officejet pro 8500 ink cartridge problem
Changing a printer cartridge is not complex but improper handling of the parts may damage the printer and the cartridge. If the user notices that while printing the ink comes out dry or faded, it may be time to change the ink or the toner. The user will know if it is time to change the toner because instead of a sharp image, one will get a faded image. It is time to change the ink cartridge when the printing comes out spotty or colors are used to replace others —for instance, blue for black or yellow for red. Remember, faded images signal the need to change the toner; spotty printing signals the need to change the ink cartridge get more help for change cartridge .
Hope this helps you.
Jan 21, 2010 | HP Officejet Pro 8500 Wireless All-In-One...
How to set hp deskjet 3550 inkjet printer to print in only black and white by ignore the color ink,for the important document. endliam< endliamc@gmail.com>
To Save the color ink you can change the printer settings to Black Only.
To Setup:
  1. Press START Button.
  2. Select RUN Command.
  3. Type these commands in CAPS.
  4. CONTROL PRINTERS and press OK or Enter.
  5. Now you will get Printers & Faxes Window.
  6. There you select the ink jet printer which you want to change the color settings.
  7. Right Click on it and Select Printer Properties later.
  8. Select Printing Preferences
  9. There you can see lot of window tabs (just like a worksheets). Depends on printer in any of the TAB you can see the option Black Only / GrayScale Printing Only.
  10. Choose the appropriate option and Select APPLY.
  11. Then give a test page for it.
That's it...
Hope this will be helpful to you..
Thanks & regards
Nandu :)
Dec 31, 2009 | HP DeskJet 3550 InkJet Printer
I use my MX700 only for black & white matters. It sometimes refuses to operate, informing me that my color cartridges have run dry. How do I overcome this?
Unless you have chosen to print in "true black" where only the black ink cartridge is used, your printer automatically will use some inks from the color cartridge to make black. (The reason given is so that your color cartridge will not dry out and cease to function when you do need it for color).
You did not provide your operating system. If you can find your printer name listed in "Control Panel" (usually in "Printers and Faxes"), right click the name and choose "Properties". See if you can find an option to print only using the black ink cartridge.
I hope this helps!
Dec 22, 2009 | Canon PIXMA MX700 All-In-One InkJet...
Changing the black cartridge also require change of color
The printer is very good.I ve been using it for approx 1 year now.The printer works on a combination of both black as well as colour ink cartridges.If any of the cartridge is empty,printer will not print.Kindly call Kodak with your problems at 1800 421 6699 and they will take care of the issue for you.
Oct 04, 2009 | Kodak ESP 5 Printer
Prints grey not black
I solved this problem but probably not what the printer manufacturer would recommend! The reason you are just getting grey is that the black ink cartridge is either empty or dried out from non use and only the color cartridge is working. I had the same problem after being away for 5 months. I put the printer cartridge in a bowl of warm water to disolve the dried out ink on the print pad. I dried off the cartridge with a soft cloth and then it worked perfectly.
Feb 25, 2008 | Epson Stylus CX4200 All-In-One InkJet...
Need to change dried old ink cartridge before it says it is out
press the Ink Change button then turn off the printer this will give you the Ink Changing psoition for a long time.
Sep 15, 2007 | Epson Stylus Color 740 InkJet Printer
105 people viewed this question
k24674
jasbo
jasbo
