Question about Canon imageRUNNER 400S Copier
E001 switch off the machine and on again - Canon imageRUNNER 400S Copier
  • 78 Answers
E001 is a fixing assy fault you have to clear the error in service mode after correcting the fault of course. I would try clearing the error code in service mode 1st. press *28* function tab clear tab error ok then restart copier
Posted on Sep 10, 2009
E001 reset mode
Posted on Aug 03, 2012
Please help me, I have a Duplo machine DP L500 and it's giving me service call E001. What would be the problem?
    ewol3i Apr 01, 2012
    main motor error..check main motor boards fuse at the back of the machine or the timing belt might be damage
  • Joseph Nov 28, 2013
    check the encoder sensor
ERROR CODE E001 DUPLO DP C120 Duplo Office Equipment Supplies
The manual is here, although it does not mention error codes.
http://www.toshiba-sa.net/Documentation%20%20Duplo/DPL-500/DPL-500_Instruction_Manual.pdf
Duplo machine DP L500 error E001 Google Search
Mar 07, 2018 | The Office Equipment & Supplies
Ir 3300 000001-0002 error
Title : E001 Error Code That is Not Resetable Error : paper jam
When the machine powers up the E001 error code is displayed but cannot be reset. (Note: The reset procedure for an E001 code is COPIER>FUNCTION>CLEAR>ERR)
Workaround :
In this case, the Main Power Supply PCB Assembly was replaced. The machine was powered up and the E001 code was able to be reset. The part number for the Main Power Supply Assembly is FM2-0260-000.
Remember, if the fixing unit circuitry has an open or a short, the code may not reset. Be sure to confirm the fixing unit wiring and try resetting the code before replacing the Main Power Supply Assembly. Canon USA, Inc. Systems & Technical Support Division1-800-528-2830
Aug 13, 2013 | Canon Office Equipment & Supplies
Could you help me to fix on error of np6650 about e001-e003 turn on again power
E001 - E003 such problems are mainly in the fixing assembly so you need to:-
1. check for the fuser lamp if it is not broken.(if broken replace)
2. the themistor if working properly.(if broken replace)
3. cables leading to the thermistor and the fuser lamp if working well.
5. change the fixing roller if it is finished.
6. reset the machine(in case of IR1600)
Jul 13, 2011 | Canon ImageRunner 1600 Copier
Error code E001; machines switches itself off after displaying this code. What does this mean?
Your in luck, Canon really did not change there error codes from way back then..... A E001 means you have a problem with the fusing unit. You may have a blown thermal fuse or one of the heatting lamps or you may have a bad thermister. It may be one or all of them. Did you try to rest the error code?
Mar 30, 2011 | Canon NP 6650II Copier
Canon IR600-550-60. Error code E001.
550 just gave an error code E060, what do I do?
Nov 09, 2009 | Canon imageRUNNER 600 Printer
Error E000001-0000
e001 is a fuser error. it might be able to be reset, but should be looked by a tech.
SERVICE MODE
*28*-press the additional func button, 2&8 at the same time, and the additional func button again.
when you have done it correctly, the screen will change and it will say service mode across the top.
Then select:
copier
func
clear
err
press the done or ok button on the lower right side of the screen.
turn the machine off at the black switch on the right side, wait 10secs, turn back on. should work.
****DONT MESS WITH ANYTHING ELSE IN SERVICE MODE YOU CAN REALLY SCREW UP THE MACHINE.!!!!!!!!!!!!!!!******************
Apr 23, 2009 | Canon imageRUNNER 6000 Copier
Canon imagerunner c3220
Were the heaters at fault. It is more like a thermister problem. Replace the thermisters, both. And I would also change the thermostat as well. When you are sure thatyou have removed the faulty unit reset by doing the following.. service mode/copier/function/clear/error followed byswitching the machine off and turn on again.
Oct 31, 2008 | Canon imageRUNNER C3220 Color Copier
E001
That is a fuser realted issue. Not warming up properly.
Most likely a defective fuser. The over heat has opened, the heat element has gone bad.
Fuser more then likely needs replaced
Jan 15, 2008 | Canon NP 6545 Copier
Canon imageRUNNER 400S Copier Logo
695 people viewed this question
old marine
old marine
