Question about JVC AV-32120 32" TV
Mt channels have a black box on them - JVC AV-32120 32" TV
Turn close caption off in menu
Posted on Oct 18, 2009
I am trying to bridge two macrotechs 1200 and I am getting a loud huming noise . No sound. Just that noise. When I run them in stereo mode they work perfectly fine. What causes that?
Let's review the setup procedure and precautions. This is for bridging the amplifiers within a single box.
  • The mono-stereo-bridge switch must be in bridge position
  • The input signal must be connected only to Channel 1. NOTHING should be connected to Channel 2.
  • The Channel 2 level control should be turned all the way down. Turning it up will amplify common-mode noise.
  • The + speaker terminal is connected to the red binding post for Channel 1 and the - speaker terminal is connected to the red binding post for Channel 2. Neither side of the load should be grounded.
  • There are no connections to the black binding posts. They should not be grounded or shorted together.
It does not seem practical to bridge or parallel two MT 1200 boxes; it would be very difficult to get the levels and offsets precisely matched. If they aren't matched, you will get oscillations or common-mode amplification - that is your humming noise.The bridging switch makes six changes to the circuitry to get the amplifiers properly interconnected in one box so this won't happen in the recommended configuration.
Jun 20, 2011 | Crown MT 1200 2-Channel Amplifier
We get a black box on some channels
Ur captioning is on.When u turn into the channel have captioning,that why u have words,or symbols.Check ur remote have a CC button.Press it make sure it off.U will not get anymore black boxes with letters or symbols.
Feb 27, 2010 | Hitachi 43UWX10B 43" Rear Projection...
Black box in center of TV
Sounds like close caption is on. Go into menu and turn it off.
Jan 04, 2010 | Vizio Televison & Video
Screen has black box with greek letters on channel
If you put the TV on CH 3 and use a VCR (if available) to change channels you'll know if it's the TV or cable channel (sound like the channel)
Oct 05, 2009 | Televison & Video
We need to reattach the wires to the Channel Master 9510A unit but are unsure which color goes to which post. We have a red, white and black on the tip wires. Can you help?
Can't wait around for your response, so I kept looking on the web until I found a users manual that showed how to connect the wirew.
Thanks anyway.
mt
Sep 12, 2009 | Channel Master Televison & Video
Black box when tv is on and going through channels
This worked on my tv...give it a try:
go into your menu and find closed caption, someone has accidently set the closed caption mode to text, when the on screen display of channel or volume goes away the box appears. turn off the closed caption feature or switch it to something other than "text" mode, and your box will go away.
Apr 10, 2009 | JVC AV-36S33 36" TV
Connecting mt digital converter box
Antena will go into converter box input then out of the converter box output into the satilite boxes antena input then out to tv!
Please rate this response and help keep this area FREE!
Thank You!
Jan 22, 2009 | Televison & Video
BLACK BOX PROBLEMS: Insignia TV/DVD combo
The black box is caused by the Closed Caption option of the tv. Go into the menu and turn it off.
Jul 18, 2008 | Insignia IS-LCDTV32 32 in. Television
Big black box in the middle of the screen
The black box is there because your closed captioning is on and set to text mode. Some channels send the signal even when there is no actual text to display. You can get rid of it by either turning off closed captioning or changing it to CC1 or CC2 mode instead of text. If you can't find those settings, then restore factory settings as directed in your user manual.
Jun 04, 2008 | JVC AV-32230 32" TV
Blacked-out box covering 75% of screen
shut off close captioning. the close captioning is in text1 mode and needs to be CC1 in order to work, or shut it off
Mar 25, 2008 | Hitachi 51F500 51" Rear Projection...
JVC AV-32120 32" TV Logo
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
