Question about LG LFX25960ST Stainless Steel French Door Refrigerator
I have a LG LFX25960ST that is freezing the refrigerator content. I turned the temperature up and waited for 24 hours but it is 22 in the vegetable crisper. perplexed
  • 11 Answers
Try turning the thermostat up ie: number 1 setting is the highest temp number 8 is the lowest temp
Posted on Sep 09, 2009
Dorm refrigerator freezes everything
Lower the freezer letter by one letter, let set 24 hours for temp to stabilize, keep lowering until right temp/environment is achieved.
The temperature of refrigerators should not be allowed to exceed 41 degrees F as this will contribute to the growth of bacteria in the food, and cause different health problems, including food poisoning if consumed.
A temperature below 34 degrees F in the refrigerator may cause the food to freeze, and you will have to defrost it before using it. If this happens to vegetables and fruits they will go limp and will be rendered inedible.
At any time when you change the temperature, give it a minimum of 24 hours to take complete effect.
The external temperatures also influence the internal refrigerator temperature. This means, you will have to set your refrigerator lower in summer, and higher in winter, especially if you live in extreme climatic conditions. On the other hand, if the climate in your zone is moderate, your refrigerator temperature will be less affected by external temperatures.
In order to check and ensure the internal temperature of the refrigerator, you may place a thermometer kept in a glass of water in the fridge. The exact temperature will be available to you anywhere within 5-8 hours.
For your refrigerator to cool effectively, it is essential that your air vents are functioning well. Do not place any items before it, and clean it on a regular basis for maximum effect.
Read more at Buzzle: http://www.buzzle.com/articles/refrigerator-temperature-settings.html
Mar 05, 2014 | Kenmore Refrigerators
It is a french door, items in the fridge part are freezing, what should temperature in freezer and fridge be?
The factory presets your temperatures to the MID / MID setting of 0? for the freezer and 37? for the refrigerator. Refrigerator adjustment range is -15? to +15? in the freezer and 33? to 47? in the refrigerator. Depending on ambient temperatures the temperatures will be + or - 6? the set point. Whenever you make a temperature adjustment, you need to wait 24 hours to notice any temperature difference.
To adjust your temperatures: Adjust controls according to your Use and Care guide. Start out by making sure your settings are at the factory setting of MID / MID. Make only one adjustment: Adjust one control and wait 24 hours before making another adjustment.
To measure temperatures: If you try to measure temperatures, it is important to follow these directions: Fresh Food Section: Put thermometer in a glass of water. Check the temperature during the first door opening after a long (8+hours) non-usage period (such as overnight or when you arrive home from work). Frozen Food Section: Put thermometer between two bags of vegetables. Check the temperature during the first door opening after a long (8+hours) non-usage period (such as overnight or when you arrive home from work).
For more information it may be helpful to look at http://www.whirlpool.com/ or contact your local whirlpool support number
May 17, 2011 | Whirlpool Refrigerators
Vegetables freezing in crisper drawer
This is an issue with the convection system in the refrigerator, while the cold air trapped withing the crisper drawer remains and the temperature of the moisture in the area drops below the freezing point, the water content acts as a cover and thereafter enables the vegetables to freeze. A slight rearrangement of the utensils within the refrigerator solved the problem
Jan 21, 2011 | GE GSS22SGM Side by Side Refrigerator
Fridge is freezing in the lower part of the fridge...vegetable and meat compartments
have you check the temperature?
The temperature controls are preset in the factory at 37°F for the refrigerator compartment and 0°F for the freezer compartment. Allow 24 hours for the temperature to stabilize to the preset recommended
settings.
Jun 13, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
LG LFX25960ST refrigerator food freezing above the pantry draw. Made all the tempature adjustments and still happening.
I have the same problem and I know the solution.
For LG to get their "in the door icemaker" to work, they have to blow cold air into the door's icemaker compartment. This air travels through two vents located just inside the refrigerator on the left side. The problem LG has is that the seals between the door and the refrigerator for these vents leak. This means that cold air is vented into the refrigerator compartment. Any sensitive food placed on the bottom two shelf on the left side will freeze. I can place two bowls of water in my refrigerator and make ice in 6 hours, even though the refrigerator is set to 38 degrees. The good thing is that LG knows there is a design problem and they know they can not fix it. After calling LG repairmen out for my freezing problem and not getting the seals fixed, LG gave up. Of course LG will try replacing the seals, and then replacing the door; but the real problem is a bad seal design. Just keep putting bowls in your refrigerator and as long as they continue to freeze up, keep calling LG back and demand that they fix the problem. LG can not fix the problem because it is a bad design, so now I am getting a new refrigerator Model LFX 29927, which is better and has dual icemakers. If you an LG refrigerator with their in the door icemaker, place two bowls of water inside the refrigerator, and if your seals are bad and they freeze; complain to LG until they give you a new refrigerator.
Nov 10, 2009 | LG LFX25960ST Stainless Steel French Door...
Freeezes vegetables milk etc. even with refrig turned up.  Tried turning up freezer by 2 pts. ..Then tried turning up refrigerator to 44..Still no luck.No one seem to repair Lg Refigerator.s  in...
Have you made sure that the door to the ice maker area is closed and tighly latched? If the door is not pushed closed so that you hear the latch snap shut, colder air from the ice room will leak past the gasket and result in freezing in the bins and / or on the bottom refrig shelf. Another possibly might be air leakage at the very back bottom of the refrigerator section, where the air tower comes out from the freezer section.
Oct 07, 2009 | LG LFX25960ST Stainless Steel French Door...
LG French Door Model LFX 25960--Freezing in right crisper door
Have person who changed out you controlboard come back and recheck connections and controlboard itself.
Jul 26, 2009 | LG LRFD22850 Bottom Freezer Refrigerator...
Hoypoint ffa9op.defrosted
hotpoint ffa90, I have fridge and freezer problem, non of them are keeping the required temperature though the fridge temperature is showing the right temperature but not cold and the freezer is not freezing as it is contstant between -2 to -5 but it should be
-22, the fast freeze bottom does not fridge either, it does not take instruction.
Feb 01, 2009 | Hotpoint FFA90 Bottom Freezer Refrigerator
Follow up to question: meat & veg tray freezing food on new side by sid refrigerator
with very littlle ice cream I would set freezer temperature to -2 degrees and leave the humidity seting where you have it remember to let the unit run for 24 hours to stabilize then you can make another adjustment. By the way you are not being a pest I don't mind helping you at all, I am a service manager and answer quesitons allo day long.
Jan 09, 2009 | Kenmore 53642 / 53644 Side by Side...
Beko LF320 temperature dial numbered 1 to 10 which way is coldest?
Right to the point people. ok to make it warmer, it is the lower the number
thanks and go night ;)
Oct 01, 2008 | Refrigerators
LG LFX25960ST Stainless Steel French Door Refrigerator Logo
224 people viewed this question
Top LG Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
christian nielsen
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
