Question about Microtek ScanMaker 9800XL Flatbed Scanner
Flashing indicator lights
When I turn the scanner on, the yellow and green lights (the power and ready indicators) flash on and off. There is a green light inside and also flashes on and off. The lights flash for a while then quit. Anyone seen a manual that gives a clue as to what the lights are trying to tell me?
This scanner has had SCSI reset issues prior to the current problem. It wouldn't always go through the reset sequence when powering on and if it didn't, it wouldn't be recognized by the computer.
PcExpert
  • 293 Answers
SOURCE: scanner
THE PROPER WAY ON INSTALLING USB DEVICES A. Enable usb ports on the BIOS. 1. Do not plug in your device right away. Install all drivers and software first! 2. Reboot 3. Plug the power or turn on your USB Device 4. Plug in the USB Port. 5. Windows Will detect the Device Automatically. Finish! Hope this helps.
Posted on Sep 22, 2007
TampaNative
  • 778 Answers
SOURCE: Microtek Scanner installation issue
If running XP SP2, then try clicking Start > right click My Computer > properties > Hardware tab > Device Manager button > expand Imaging devices > right click on your Microtek ScanMaker > uninstall > Re boot > and let XP pick up the device and let the found hardware wizard configure it.
I have seen plenty of hardware that when following the devices manufacturer's instructions for install, such problems as you're having occur and XP SP2 usually will cure it, though you may still need the device manufacturer's CD (for the driver) in your optical drive.
This link: http://support.microtek.com/downloads/bymodelname.phtml?viewtype=2&srch_in=ScanMaker+5950&frmsearch.x=10&frmsearch.y=11&frmsearch=Search&frm_rqst=2&axn=1 will allow you to select between the 5950 and 5950 Pro then on the next page you will be able to download the latest XP driver for your Scanmaker among drivers for other Operating Systems also.
I hope this helps, and Good luck.
Posted on Mar 21, 2008
acdr
  • 1913 Answers
SOURCE: computer cannot locate scanner microtek 9800xl
change your adapter is has not proepr voltage which are reqired for scanner.
Posted on Mar 27, 2009
SOURCE: Scanner will not connect to computer. Light is
I found that I need a new lamp and they are no longer available. Thank you. Betty Haith
Posted on Oct 29, 2009
  • 1099 Answers
SOURCE: Have not used the scanner
Sorry to say but the microtek support site indicates that this scanner is for windows machines only.
Posted on Feb 03, 2011
When you turn of the TV the POWER indicator flashes green for several minutes. The TV never comes on. After the several minutes of the POWER indicator flashing green, it stops, I hear a click and the...
A continuous flashing red light with the word LAMP on it would definitely mean you're going to need to spend a few bucks on a new lamp....or for a few more, upgrade to a TV from this century that doesn't require lamp changes :)
May 11, 2011 | Panasonic PT-52LCX66 Projection Television
Power box light is blinking orange and sometime a steady red and console want come on.
Green Indicator Light:
The default indicator light is green. When the Xbox 360 power supply light is green it means that there are no problems with your power supply. However, if you are having problems and the power supply light is green, this means that the console is faulty and you need to contact Xbox 360 support.
Orange or Yellow Indicator Light
When the Xbox 360 power supply light is orange or yellow this means there is no problem with your console but the power supply can't supply it with power.
To remedy this problem, first try unplugging the Xbox 360 power supply from the console and unplug the power cord from the wall outlet. You'll also want to uplug the Xbox 360 power supply from the power cord.
Wait for about five minutes and then reconnect everything. You might also want to try plugging it into another wall outlet without an extension cord.
If you are still getting an orange or yellow indicator light, then something is at fault with the Xbox 360 power supply. If this is the case, contact the Xbox 360 customer support to get a new one.
Red Indicator Light:
If the xbox 360 power supply light is red, then there is something wrong with the power supply connection. If this is the case, try the same solution as listed above of unplugging the power supply from the console, unplugging the power cord from the wall outlet and unplugging the power supply from the power cord. Wait for about five minutes and then reconnect everything. You might also want to try plugging it into another wall outlet without an extension cord.
If the indicator lights are still red, then there is a fault with the power supply. If this is the case, contact customer support about getting a new one.
No Indicator Light:
If the XBox 360 power supply light is not illuminating at all, this usually means that the Xbox power supply is not connected to the wall outlet correctly. On the other hand, it might also be a fault with the power supply or the power cord.
Either way, try the same solution as listed above for the red indicator lights. If you still don't see any lights illuminated after unplugging and then reconnecting everything, you'll need to contact customer support about getting a new power supply.
Green and Orange Indicator Light:
If the indicator light is flashing green and orange, this may mean that the console does not detect the AV Pack.
Disconnect and then reconnect the Xbox AV Pack. Make sure the connections are firmly connected. Turn your Xbox back on.
If the indicator light is still flashing green and orange, try another AV pack if one is available.
If the indicator light is still flashing green and orange, you'll need to contact Miscrosoft Customer support.
Flashing Orange Indicator Light:
If your Xbox console's indicator light flashes orange, this means the internal components have overheated and the Xbox has automatically shut down to prevent damage.
Turn off the console and let it cool for at least 10 minutes.
To prevent the Xbox from overheating in the future, make sure that it's not placed in a closed cabinet or on carpet. It's best to get the Xbox elevated off the ground where the PSU can have maximum heat release.
You'll also want to make sure the Xbox is not located near a heat source like the back side of a television, computer, monitor, or other electrical device.
Aug 26, 2010 | Microsoft Xbox 360 Elite Console
My glowbouy flashes green and red...what does this mean
According to the owners manual for these swimming pool lights, this is what each colored indicator means. Hope this helps.
Solid green
The battery pack is fully charged.
Slow flashing green
The battery pack is almost fully charged.
Slow flashing yellow
The battery pack is half charged.
Medium flashing yellow
The battery pack is less than half charged.
Fast flashing yellow
The battery pack has almost no charge.
Fast flashing red
A charging error has occurred and the light should be unplugged and then plugged back in. If the Fast Flashing Red persists after several attempts, the battery condition is questionable.
Also in the trouble shooting guide, it mentions this:
Problem: Red Indicator Light Is Flashing While Charging
Solution:
A red flashing indicator light when charging indicates a selftest
error condition. Unplug the product and plug it in again.
Try this several times; if the indicator light continues to flash
red, unplug the GlowBuoy and take it to an authorized service
depot.
Oct 22, 2009 | NRS CANTAR GLOW BUOY FLOATING POOL LIGHT...
I have a canon mp830 that is has trouble code 5c00 on the lcd. the power light and trouble light flash alternately green and yellow respectively. I've cleaned the print head. How can I reset the printer to...
Canon MP170, MP450, MP530, MP600, MP610, MP800, MP810, MP820, MP830, MP960, MP970
MX700, MX7600, MX850
1. Switch off the printer the button Power
2. Holding button Resume (the red triangle in ring), include the printer (press the button Power ) - an indicator fires green cvetom.
3. Holding button Power , release the button Resume
4. Not releasing button Power , two times press the button Resume and release both button.
5. After indicator of the cut-in/readiness flashing.. and fires constantly, fall into service mode.
6. Four times press the button Resume , under each striking Resume indicators are switched: green-yellow.
7. Once press the button Power for acknowledgement of the selected action (the unset of the counter абсорбера). For switching off the printer button Power press once again.
Jul 09, 2009 | Canon Office Equipment & Supplies
Tv went off while watching a program power standby red light blinks 6 times then pauses then repeats tried unplugging unit waiting a few minutes then replugged same results nothing. can anyone help me ?...
Here's an excerpt from the Sony Manual online. And the link - http://esupport.sony.com/US/perl/webtree.pl?template=EN&mdl=KDF55XS955&content_id=68&category_id=11&problem_id=52
The POWER/STANDBY (red) indicator flashes three times
If your power/standby indicator is flashing in a pattern of three flashes, this may indicates that the lamp cover is not attached securely. Follow the directions in the Operating Manual under changing your lamp that related to closing and securing the Lamp Cover. Ensure that the Lamp Cover Door is securely fastened by tightening each screw.
The POWER/STANDBY (red) indicator flashes continously
If your power/standby indicator is flashing continuously, and the lamp cover has been secured, your TV may be in need of service.
The POWER/STANDBY indicator is lit up green (not flashing)
A sustained green light indicates your TV is on.
The POWER/STANDBY indicator is lit up red (not flashing)
A sustained red light from your power/standby indicator simply indicates that your TV is in standby mode. This shows you that your TV is ready to be turned on with the remote.
Is it the power light and not the lamp light? If the lamp light is flashing then replace the lamp.
Apr 07, 2009 | Sony Grand WEGA KDF-55XS955 55" Rear...
Xerox Documate 252, just quit working
The flashing green light has the following meaning:
• Blinking green: indicates the scanner is waking up from power
saving and preparing to scan.
• Steady green: indicates the scanner is ready to scan.
How to Adjust the Power Save Settings for the DocuMate 252
1. Right-click on the One Touch icon and choose Show
Hardware from the pop-up menu.
You can also click the scanner icon at the top of the One Touch
Button Panel.
If the Hardware View of the panel is open you can also right-
click on the DM252 icon.
The Hardware Properties dialog box opens and shows
information about your Xerox DocuMate 252 scanner.
2. Click the Properties button.
Your scanner has a built-in power saving feature that is set to
power down after 15 minutes of idle time. You can change the
time before the scanner powers down, from 1 minute to a
maximum of 3 hours.
3. Click the arrows for the Lamp timeout setting and choose a
time setting.
To return the scanner to its factory settings, click Reset Device.
4. Click OK to save the changes and close the dialog box.
Let me know if this solves the problem and thank you, Binary Bob
Dec 09, 2008 | Xerox DocuMate 252 Path-Through Scanner
UMAX 2100XL IS CONNECTED, 2 G LIGHTS FLASHING WITH NO PRINTS
OUR SCANNER IS CONNECTED BUT DOES NOT WORKING. DOES NOT POWER ON THE "SCANNING LAMB" NOW THE TWO GREEN LIGHTS ARE FLASHING ( POWER AND READY ) BUT THE SCANNER DOES NOT WORK OR SCAN.
Dec 09, 2008 | Umax PowerLook 2100XL Flatbed Scanner
Flashing device status light
Ok the lightning bolt is your power indicator: solid green-charging, Flashing green-fully charged, flashing red-low battery, flashing red three times the once green-bad battery. the "trash can" looking one is your hard drive activity indicator it will flash while your hard drive is reading and writing.
Nov 20, 2008 | Dell Latitude D600 Notebook
Microtek ScanMaker 9800XL Flatbed Scanner Logo
65 people viewed this question
Top Microtek Office Equipment & Supplies Experts
Tony
shelmnot
Are you a Microtek Office Equipment and Supply Expert? Answer questions, earn points and help others
