Question about Samsung HCM4216W 42" Rear Projection Television
Samsung Rear Projection HD tv IC convergence green only messed up now. Help please
Had this problem about a yr ago. New ic's and a few new fuses and it was fixed. I had a tv repair guy solder the ic's in but now the blue , red work fine. I can move them up down left right but the green looks to be messed up. It seems blurred or out of focus. The tv looks fine except the green. Any Ideas? I want to check the fuses on the board so I can ask the tv repair guy to fix the fuses or I could do them myself. What settings on a multimeter do i use to read these small fuses on the IC board? I can provide pictures as well. NEw ics are in I just dont get why the green is messed up still. Im guess a fuse on the IC board is blown.
  • 1 more comment
  • Anonymous Dec 30, 2007
    About how much would it cost to have a tech repair this problem ??
  • Dylang1 Feb 26, 2008
    I have the same problem, the green blur "outlines" everything on the screen.Everything looks green. When i use-to use the auto focus feature nice thin straight red lines would focus and center everything now if i do it they are green and wide and not straight. The green keeps giving me problems what should i do
  • Anonymous Nov 15, 2008
    vertical deflection coil
  • 934 Answers
To check the pico fuses you're merely testing for continuity. If you get an infinate reading you're in good shape - if it doesn't budge the meter the fuse is open... That's a really easy set to work on for convergence problems - the convergence board is easily removed..
Another cause for mis-alignment like that are the youke return resistors... There are several out front of the convergence amps that may have changed in value. They are 3.9 ohm - 2w resistors and will look identical to Rz123 and Rz124 (same banding). For those simply select a low ohm setting on the meter and check to see if any of them have some way low or way high reading...
Need anything else just ask...
Bill
Posted on Dec 10, 2007
Have a Panasonic PT-47WX53 47. It's probably as old as when it came out. I've messed around with the convergence before but it was never un-fixable. Then a couple a days ago I came into the ro
yes and also possibly the low ohm resistors. You can get the PT53WX53 convergence kit which fits your model from www.tvrepairworld.com which has the 2 ICs and associated resistors plus the CD with repair instructions.
Jun 09, 2012 | Panasonic PT-47WX53 47" Rear Projection...
HD 1080 Series (WD-55809) - Color convergence issue
I don't know of illustrated instructions but I can provide you with the service manual for your TV. It does have illustrations of disassembly and components as well as schematics. Your set very likely needs new convergence IC chips. This is a common problem with all projection TVs. The repair is not expensive ($60-75 in parts)  but does involve unsoldering and removing the old chips and soldering in new ones. Some times there are some fuses that need to be replaced as well. If you want the manual provide me with an email address.
Dec 04, 2009 | Mitsubishi WD-52525 52" Rear Projection...
My samsung rear projection tv has a problem with its convergence ic. i think theres two ics , but how do i tell which ic need replacing??
Always replace both once your going to the trouble each IC is usually less than $30.
This link will help show you what's involved.
convergence output IC problem. convergence board would have to be removed - remove and replace 2 STK IC's and check the surrounding resistors. Shops usually $200-$400 Be sure to vote/rate me if this helped Thanks!
See link for more detail
http://www.ehow.com/how_4575598_yourself-projection-tv-repair-convergence.html
Nov 13, 2009 | Samsung HLR5067WX 50" Rear Projection HDTV
Convergance
did you replace both ICs? also samsungs will usually burn at least two of the 3.9 ohm resistors when a ic fails.
Sep 26, 2008 | Samsung PCJ522R 52" Rear Projection...
Samsung HCN4226 Convergence IC Problem.
The problem is likely to be the digital convergence board that generates the convergence signal that is amplified by the output ICs.
Jun 22, 2008 | Samsung HC-R4755W 47" HDTV
Color is messed up
sounds like bad convergance ic
http://www.techlore.com/forum/thread/18970/Sony-KP-46WT500-Convergence-Repair/
Dec 14, 2007 | Sony KP-46WT500 46" Rear Projection...
Samsung 42" projection green and only green out of focus? Bulb? Tube? IC?
Just had new Ic?? Meaning single?? The symptoms you're describing are a convergence failure. That unit takes Stk392-040 Sanyo Ics and be aware there are a ton of Chineese knock-offs out there that can cause you real trouble, so purchase them from only a reputable part distributor... You need to change both amps, test all 3.9 ohm-2w resistors in that circuit, like Rz123 and Rz124 and check Fd102 3.5a pico fuse for open. That's actually a really easy set to work on for convergence problems because the entire convergence amp board is easily removed.
Bill
Dec 10, 2007 | Samsung HCM4216W 42" Rear Projection...
Triple Vision
One of your convergence output IC's has stopped working and needs to be replaced. This is a very common problem in projection TV's. The IC should be replaced and the convergence circuits realigned by someone with experience in repairing projection TV's.
Aug 04, 2007 | Samsung PCN5425R 54" Rear Projection...
Convergence for HD channels only
Hello, please check the IC7102 (24LC64). This is eeprom that contains the convergence data. Please ask the Panasonic dealer if they can supply a replacement IC with the data for your HD. If you need more info please advice. Arpi
Jun 08, 2007 | Panasonic PT-51HX41 51" Rear Projection...
Samsung HCM4216W 42" Rear Projection Television Logo
291 people viewed this question
Jerry Greenberg
Jerry Greenberg
