Question about Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System
Whirlpool fbb36af20/2 fridge freezer frame of front fridge freezer getting hot, fan at bottom back stoped working replaced fan but when you plug in new fan it starts to work but when you fully push the fan plug in it stops im after a wiring diagram of the power board the fan plugs in to or any sugestions thanks ian
  • 22 Answers
Hot frame is mullion heaters. Keeps moisture from forming on door and causing rust. Sounds like the connector is defective, remove connectors and wire direct. If fan won't run then you need to call a qualified service tech.
Posted on Sep 12, 2009
Testimonial: "wired direct as sugested running ok thanks ian"
SMEG Fridge Freezer FA561XF - the frame of the fridge/freezer gets very hot and freezer isn't freezing stuff in bottom tray
That is a very bad sign, but before you unplug it pull the machine out from the wall and check to see if it feels hot back there as well. Then remove the lower cover and find the condersor fan motor. Its the only fan back there. I'd willing to bet that the fan is not running. The purpose of the the fan is draw air across the compressor and blow it through the condensor therefore lowering the temperature on both parts. When its not working/ running, the heat from the compressor and the condensor is pass onward to the machine and the machine then acts as a heat sink.
Also, if the machine is too close to the wall or the condensor coils are dirty you'll get the same effect, so be sure to check those things out as well
Jun 21, 2012 | Smeg FA561X Side by Side Refrigerator
Whirpool wgi fridge freezer, fridge not cooling?
Most frideges get all their cooling from the freezer. There will be a fan and duct in the back of the freezer that pushes cold air down into the fridge. If the duct is blocked with ice or the fan motor has quit. Your freezer will work fine but the fridge will barely cool at all. Check that the fan runs when the compressor is running, ( turn both temp knobs to the highest cooling and leave door open until comp. comes on). If the fan runs your duct is plugged. If not you need a new " Freezer Fan Motor". Most are simple to replace and cost around $100.00.
Jan 01, 2012 | Whirlpool Refrigerators
The middle part of the fridge frame where the side by side doors close onto is very hot to the touch. The fridge and the freezer portion themselves are working properly, but I just leaned on the frame in...
I had the same problem. I had just brush cleaned my coils and then it began. When I took the back off the fridge, I saw the fan was not spinning. I unplugged the fridge and then tried to spin the fan blades. I had inadvertantly bent a blade so it would not spin. I bent the blade back into shape and turned it on. The fan worked and very quickly the middle was no longer hot.
Apr 18, 2010 | Refrigerators
My compressor stoped working and it got hot and
If the fan was the problem and the compressor is now running , it should start getting cold.
Oct 16, 2009 | Amana ARB2217C Bottom Freezer Refrigerator
KitenAid KSRX25F -- HOT FRONT FRAME
The fan which cools the compressor is not working , OR , the coils under the front of fridge are very dirty .
Aug 01, 2009 | KitchenAid KSCS25IN Side by Side...
Fridge not getting cold
refrigerator hts 16 hbfrww is not getting cold but the freezer works well, ive defrosted the refrigerator plugged it back in it worked for about a week then stoped getting cold again.
Jun 16, 2009 | Frigidaire FRT18P6BS Top Freezer...
Whirlpool sbs fridge freezer - freezer stopped working
There are 2 or 3 things that would cause this. first make sure the condenser coils are not plugged with dust (vacumn or blow them out) next check to make sure the fan that cools these coils is running, (this is the most likely problem). if both of these check out ok then you would need to check to make sure your interior lights ar going off when the doors are closed as these will add extra heat and cause the center rails to run hot. last and most uncommon would be a freon system problem.
fyi there is a hot gas freon line that runs in between the doors to prevent exterior sweating. when poor or no air flow problems for the condenser coil exist it causes this area to become hotter.
One more thing. if you do determine that the condenser fan motor is bad you can put a normal house fan blowing on to the coil to help cool this area down until you can get the unit repaired.
If you need any further assistance leave me a comment here and I'll gladly get back to you. Thanks Peyton
Feb 24, 2009 | Freezers
The ice maker doesn't work, the fridge compartment is warm and the door seal is hot
sounds as if your compressor cooling motor is out.....check it in the back on the bottom.....remove the cardboard cover and see if the fan is running...if its not and it is real hot in the compartment the fan will most likely have to be replaced
Jul 28, 2008 | Whirlpool Refrigerators
Whirlpool Refrigerator Door Seal surface is HOT.
If the air flow on the condenser under the fridge is too low, the hot gas won't be cooled enough before it goes to the door jamb to stop condensation. Remove the plastic cover under the doors and look at the condenser (tube/wire thing underneath). If it is clogged with fluff, get a vacuum and nozzle and give it a good clean so the air can pass through. Other than that, your condenser fan may have stopped.
Jul 13, 2008 | Whirlpool GC5SHEXNS Side by Side...
Front metal piece that the seal goes against - between freezer and fridge
ED5VHGXMQ10 Whirlpool Fridge
I have the same problem. Too hot to touch between the freezer and refrigerator door. Is
this normal?
Jul 07, 2008 | Whirlpool GS6NBEXR Side by Side...
Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System Logo
163 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
