Question about Iomega 1.5TB Desktop USB Hard Drive
I have a iomega external 600gb external hard drive, and my computer will not work or load unless this is switched on ? it never use to do this, but now the dam thing has taken over all my computer help please
  • 696 Answers
Assuming this is a windows machine it's likely one of two things, either the machine was re-installed/repaired while the drive was attached and the boot sector may have been moved to the external drive by accident. The other is that the Virtual memory file may have been moved to the external drive which would prevent windows from loading.
If you have repaired the machine lately you may need to re-repair it with the drive detached in order to solve the problem. If not right click on my computer, select properties. When the new window opens select advanced then click the settings button in the performance section. Again select the advanced tab, Click the change button on the Virtual Memory section and remove any reference to memory being used on the external drive. If it is the only drive listed as using memory, be sure to add at least 2GB(2048MB) to the C drive first.
Let me know how you make out,
Chris
Posted on Sep 12, 2009
Where can i find a manual
I couldn't find a manual but maybe asking the proper question about your Iomega Hard Drive someone might get you an anser.
Most common issue is that it is not recognized so here uou have some solutions:
My iomega external hard drive not showing up in my computer but does...
iomega HDD external drive not detected LED comes ON but wont run SOLVED
Windows 7 help and support forum
External Hard Drive Not Showing Up
Aug 13, 2015 | Iomega Computers & Internet
Blinking light on iomega external hard drive
Try plugging the unit into another working computer. If the same thing happens then the external drive is toast. U may be able to remove the drive with within the unit, set it up as a slave, install on working computer and possibly extract any and all needed files before throwing it out.
Nov 22, 2013 | Iomega Prestige 1 TB USB 20 Hard Drive
My wife and I bought an Apple mac computer just over 3 years ago, and as we wanted to store our large collection of CDs on i-Tunes on an external hard-drive and not on the Mac computer drive, we bought an...
no --there are no engineers at fixya site
from your description the aux hard drive has failed
Most hard drives using discs are good for around 3 years max and then the bushes and bearings fail
If that is the case then you will have to find a repair shop that has the capability to remove the disc from the hard drive and recover all that you have saved
if it as what I have suggested then consider this
There are hard drives (SSHD) on the market that use solid state technology and do not have spinning discs that fail over time
The cost is around $60.00 per gig of storage
best if you take it to a computer repair shop for a proper diagnosis and while there discuss the SSHD technology to prevent failures in future
Feb 27, 2017 | Iomega ULTRAMAX 1TB TRIPLE INTERFACE...
My iomega 500gb external hard drive has a broken.
My Iomega (33654) 500GB USB isn't working. When I turn it on the blue light comes on for a few seconds. I can hear / feel it working but then the light goes off (it is still whirring inside). The computer isn't recognising it. I think it's still under guarantee but I can't find the paperwork. Do you have any ideas?
Apr 03, 2010 | Iomega (33654) Limited Edition 500 GB USB...
My iomega 500gb external hard disk is corrupted
my pc is not showing my 500gb iomega external at all,in device manager syas all is working correctly
Nov 08, 2009 | Iomega 1TB Desktop USB 2.0 Hard Drive
Iomega 500 MB External Hard Drive does not spin when you turn it on. Light just flashes white and blinks
The hard disk most likey is faulty. Remove the hard disk from the enclosure and connect it to an USB hard drive adapter and the plug it into a working computer's USB port.
If this computer cannot detect this as an external hard disk then it the hard disk is faulty and needs to be replaced.
If the hard disk is OK the the Iomega case is faulty and it needs to be replaced.
Sep 21, 2009 | Iomega Computers & Internet
Vista stops recognizing external hard drive
This doesn't sound like an OS issue. This appears to be more an issue of the connection to the hard drive. The USB cable likely isn't the culprit, nor the laptop USB inputs. If the drive was ever dropped or the cable gets removed and reattached often to the actual enclosure, you might be looking at a bad port on the enclosure. This isnt a lost cause. You can always buy a hard drive enclosure from newegg and move the drive from the IOMEGA to the new enclosure. You can get a new enclosure for $15. Just because the USB port is bad, it doesnt mean the data is gone and the hard drive cant be used.
Aug 26, 2009 | Iomega 33089 250 GB Hard Drive
Computer doesnt read the external hard drive anymore
It sounds like the hard drive head crashed when you pulled the power plug. Unfortunately if you can't get drive to be recognized, you won't even be able to run any diagnostics. You will have to take the drive to an authorized repair shop who will have to check the electronics to see if the head will respond. Unless you have data on your drive that you absolutely need, you will probably save a lot of money by replacing rather than repairing the drive.
Jul 10, 2009 | Iomega 1TB Desktop USB 2.0 Hard Drive
Iomega mini max external HD slowing things down
the hd external iomega 500 gb minimax have a litle noice and don't work dont conect whit my computer.
Mar 06, 2009 | Iomega MiniMax Desktop - Hard drive - 500...
Iomega 1.5TB Desktop USB Hard Drive Logo
801 people viewed this question
Top Iomega Computers & Internet Experts
Owen Barnes
Martin Murray
Are you an Iomega Computer and Internet Expert? Answer questions, earn points and help others
