Question about Canon MX300 Office All-In-One Printer
Hello im trying to get my MX330 to print postage labels through microsoft word 2007. But before it prints it come up with a send fax screen. When i try to cancel this it cancels the print. Ive spoke to canon helpline but didnt help at all. Thanks Chris
  • 2,124 Answers
It sounds like the MX330 Fax driver is set up as the default printer in Word 2007. Before using the label option, which doesn't allow you to select a printer, check and see which driver is selected when you just go to print from Word 2007. If it shows MX330 Fax, change it to MX330 Printer.
Posted on Sep 10, 2009
HOW DO I buy a US postage stamp Printer?
You can print US postage stamps on a standard office printer to print postage by the sheet or using a specialty roll printer like the Brother QL-700.
http://www.pb.com/smb/online-postage-stamps/overview/print-stamp-sheets
This is one example from Staples.com:
http://www.staples.com/Brother-QL-700-Label-Printer/product_356066
Sep 10, 2014 | Office Equipment & Supplies
Hello, I have a problem with Zebra Z4M Plus
Hi, if is the vertical line, its the print head that need to be replaced,
try to clean the print head and try this to confirm:
turn printer off, press PAUSE button and at the same time, power on, don't release the button, please wait until printer LCD screen come on, then release button. It will print the PAUSE test and after few 3-4 prints, u can turn off and on again otherwise printer not ready to print your labels until u restart it. (pause test stops after 10-15 labels). this pause print just show how the print head is and if come with vertical lines, u will need to replace. other idea is (if u can) turn the bar code different position or on vertical way at label format. Thanks.
Aug 04, 2013 | Zebra Office Equipment & Supplies
How to scan
Step #1 - Have the printer powered up and plugged into Mac.Step #2 - Open "System Preferences" and the in the "Hardware" selection select "Print & Fax".Step #3 - Drag down the menu bar on the left side until you reach the bottom were its labeled "Scanners" Step #4 - Select the scanner that you want and began scanning.
Jan 15, 2012 | Canon PIXMA MX330 Office All In One...
Im trying to print avery labels but my printer does not have a setting for it
Normally support for printing Avery Labels is found within the application you are using to create the labels to be printed, i.e. in Microsoft Office Word or similar publishing programs. . . .Avery provide a Wizard extension to use in Microsoft Word to help you to produce and print on their labels. . . .See http://www.avery.com/avery/en_us/Templates-&-Software/Software/Avery-Wizard-for-Microsoft-Office.htm for further details and to download the Wizard. . . .Note: You need to allow Macros to execute within Microsoft Word in order to use the Avery Wizard.
Sep 22, 2011 | Epson Stylus NX400 InkJet Printer
Canon PIXMA MX330 multifunction printer. I get a lot of faxes. Is there a way to save ink & paper by having all faxes come in without printing them & just putting them to memory & review them...
unfortunatly not!The m/c will print each and every fax!I can suggest getting a fax to email nr and recieve the faxes on your pc and then printing what u need!Memory does keep about 258 pages depending on the coverage on the pages!
Feb 22, 2010 | Canon PIXMA MX330 Multifunction InkJet...
My canon mx330 printer ask me this questions when i hit the "print button" it pops up a window that asks"output file name"? I'm suppose to type something inthere?
Check that the printer shown in the print window is the MX330. It sounds like your default printer is set to be a virtual printer such as Microsoft XPS or Acrobat PDF. You need to set the MX330 as your default printer by going to your Printers and Faxes window, right-click on the MX330 printer and select "set as default" on the list there.
Oct 23, 2009 | Canon PIXMA MX330 Multifunction InkJet...
My fax (pixma mx330)says memory in use and shows
Hi, you must reset the machine in the factory setting mode.
Oct 09, 2009 | Canon Office Equipment & Supplies
I can't send a fax from my vista program with out printing out the fax first and sending it the old way, and that waste paper. in the xp or word 2003 I can go to the send in the file and the fax wizzard...
You need to go to printers and choose 'add a printer'. Under add printer, choose the printer called "MS FAX." That will install microsoft fax as a printer. Next, print your document by going to File, Print... (make sure it says "PRINT..." then you should see a selection screen, choose ms fax, and there you go. That should do it.
Oct 01, 2009 | Microsoft Windows Vista Ultimate Edition
OUR DYMO LABELWRITER TWIN TURBO JUST STOPPED PRINTING--
OK! The first time you tried to print ON THE LEFT SIDE, without anymore labels there, there was a "pending" error message in the print queue. This typically cuts off all furtther printing, as all subsequent requests are "behind" it in order or priority.
To fix this, open the Dymo Labelwriter "Printer" dialog box (double-click it on the tray or go to "start / control panel / printer and faxes" - then double-click on "DYMO LabelWriter Twin Turbo". Once open, you'll see a list of "failed" print requests. Somewhere in there you'll find the one with the "laserwriter output" out of paper message. Select that and cancel or delete it.
If this was the problem, all your attempts will now print (make sure you have enough postage paper in, and you'll have extras you can use, I'm sure!
Hope this helps.
Jun 17, 2009 | Dymo LabelWriter Thermal Printer
Word 2007 - not printing page numbers
>lets change the default printer to microsoft docuemnt imaging
>from control panel printer and faxes
Apr 16, 2009 | Microsoft Office Word 2007 Upgrade Version...
Canon MX300 Office All-In-One Printer Logo
108 people viewed this question
old marine
old marine
