Question about Toshiba Satellite A100-S8111TD Notebook
How to use the import data - Toshiba Satellite A100-S8111TD Notebook
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 115 Answers
Wath's your need exactely?
if you want to import & export data betwen cmputer and outher drive use a software for synchro & file management.
try this one "Bi-exploreur"
http://www.lsi-dev.com/index.php?mod=download&ac=afficherid&id=58
Posted on Sep 09, 2009
When importing data from Excel 2010 spreadsheet Easy Mark says you must install Excel
If you selected an Excel spreadsheet from the Data Import dialog, you will need to select which worksheet within the spreadsheet contains the label data you wish to import. If you don't have Excel installed you'll need at least Excel Viewer as Easy Mark relies on the users system to view the worksheet.
Oct 17, 2013 | Panduit Easy-Mark Labeling Software...
Please give me the procedure how to import foxpro files in tally 7.2
To import data from a FoxPro database, use the Microsoft Visual FoxPro ODBC driver. To do so, follow these steps:
1) Click Start, and then click Control Panel.
2) In Control Panel, double-click Administrative Tools.
3) In the Administrative Tools window, double-click Data Sources (ODBC), and then add a new ODBC data source for your FoxPro database or tables by selecting the appropriate Visual FoxPro driver.
4) Start Access, and then open your Access database. 5) On the File menu, point to Get External Data, and then click Import. 6) In the Import dialog box, click ODBC Databases in the Files of type list. 7) In the Select Data Source dialog box, click the Visual FoxPro data source that you created in step 3, and then click OK. 8) In the Import Objects dialog box, click the tables that you want to import, and then click OK.
Jul 05, 2010 | Computers & Internet
How to get no. Of pixels from given image through java
try this code
import java.awt.image.PixelGrabber;
import java.awt.Toolkit;
import java.awt.Image;
class getpixel2
public static void main(String args[]) throws Exception
Image image = Toolkit.getDefaultToolkit().getImage("D:\\one.jpg");
if(image==null)
System.out.println("NO FIle");
PixelGrabber grabber = new PixelGrabber(image, 0, 0, -1, -1, false);
if (grabber.grabPixels())
int width = grabber.getWidth();
int height = grabber.getHeight();
if (isGreyscaleImage(grabber))
byte[] data = (byte[]) grabber.getPixels();
else
int[] data = (int[]) grabber.getPixels();
for(int i=0;i<data.length;i++)
int r = (data[i] >> 16) & 0xff;
int g = (data[i] >> 8) & 0xff;
int b = (data[i] >> 0) & 0xff;
System.out.println("(R,G,B)=("r","g","b")");
public static final boolean isGreyscaleImage(PixelGrabber pg)
return pg.getPixels() instanceof byte[];
} import java.awt.image.PixelGrabber;
class getpixel2
if(image==null)
else
May 15, 2010 | Computers & Internet
I need to print mailing labels imported from excel to word in columnar order instead of in order by rows across the page.
hi Samajane,
I understand the you excel file has data that is stored column wise. Well you can first convert the column wise data to row wise data and then import it to you word.
To convert the column wise data to row wise data.
1.Select the data in your worksheet.
2.Right Click -> Copy
3.Create a blank worksheet.
4.Goto Edit - > Paste Special
5.Check the Transponse Option
6.Press OK.
Now you have converted your column wise data to row wise data and now u can import it to your word and print mailing labels
Dec 14, 2009 | Microsoft Windows XP Professional
Hi, I need to Import Outlook Express Emails (that were on another PC - and the Maintenance / Store location from express has been backed up to an external hard drive) and import the mail and contacts into...
You ought to copy the Ms Outlook Data file that is usually stored in your computer containing all your outlook data.
To locate it:
  • open my computer on the current computer that has the addresses and files.
NB: Make sure that you have enabled viewing of hidden files in your computer. Do this by going to the
  • Tools on the Menu bar --------- Folder Options----------Click on the View Tab ---------on the Advanced settings ------File and Folders -----Turn on Show Hidden files and Folder on the Hidden Files and Folders Menu.
Open Drive on Drive C:
  • On C: follow this sequence to open the file
  • C:/-----Documents and Settings--------Click on the User Account-----Local settings-------Application Data------Microsoft-----------Outlook.
When you are here you will see the Outlook Office Data File.
  • Copy this Outlook Office Data File in a removable media e.g Memory Stick.
Now you have copied the E-Mail and Addresses File.
  • Go to the computer you wish to copy the E-Mails, Settings and Addresses.
  • Open Microsoft Outlook Program
  • Under the File Menu Click on the Import and Export submenu.
An Import and Export Wizard dailog box opens up.
  • From the Action to perform choose
  • Import Internet Mails and Addresses and click next.
  • The Outlook Import tool dialog opens.
  • Select the Internet Mail Application to Import from: Choose on Outlook Express 4.X, 5.X, 6.X making sure that the Import Mail, Import Address Book , Import rules Options are turned on.
  • Click next
  • Address Dialog Box Opens up
  • choose on the option accordingly and click finish
  • Browse for Folder dialog box opens up.
  • Select the location of your saved Ms Outlook Data file
  • Click OK
  • Starts to import all your E-mail files and Addresses to the new computer.
Thats it. I guess you have your mails and Addresses.
Incase of any queries please dont hesitate to ask.
Kind Regards,
Picofly
Sep 10, 2009 | Microsoft Outlook Express
How do I import information from one company file into another?
Intuit QuickBooks can export lists, such as customers, vendors, items... Under file choose Export.
Once the lists have been exported, they can be imported into another file.
Feb 26, 2009 | Intuit Computers & Internet
Sorting Imported sql data
Are you sure you imported the data or did you create a link to sql. If it is a link then it will not allow you to work with a subset of the data because it would effect the data on the sql database.
Apr 11, 2008 | Microsoft Office Professional 2007 Full...
Unable to import a notepad file with names and addresses into excel sprd sht?
I could not find any data tab.?
but if you open the notepad file it is just text.
just copy and paste into your application.
if you import a file it is usually comma or tab delimited but notepad is not either unless it was saved as such.
Feb 02, 2008 | Computers & Internet
Importing data from fox pro
try to use odbc and create link in ms. access.
or you can extract it to csv file and then import it to access.
Jan 28, 2008 | Computers & Internet
CSV file to Import correctly into Excel 2003
Rudils,
The key is to import the data and not open the file directly.
1. Open a Blank Workbook in Excel.
2. Data, Get External Data, Import Data. (Excel 2007 is Data, Get External Data, Data from Text)
3. Browse to your .csv file and Select "Import".
4. Import Wizard should appear.
5. Page 1 Select "Delimited"
6. Select the row which you want to start the import.
7. click "Next"
8. In the Delimiters, select "semicolon" and/or other delimiters you are using.
Note: The bottom half of the window will preview the way the data is to be imported.
9. click "Next"
10. highlight each column of your data in the window below. For each column you can specify "General", "Text", "Data", or "do not import column" using the radio buttons in the top left of the Wizard box. This is an optional step.
11. Click Finish.
I hope that helps. Please add a comment if it not clear.
kpenguin
Nov 22, 2007 | Microsoft Excel for PC
Toshiba Satellite A100-S8111TD Notebook Logo
24 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
