Question about Casio Exilim EX-Z57 Digital Camera
My Exilim will not read my memory card it says card locked and it's not.
  • 6,831 Answers
Hello
If the card works in another camera or another card doesn't work in your camera , the problem is with your card reader in your camera.
If you open you sd slot and look inside with a sharp light , you should be able to see on the left side of the slot there is a little copper or spring steel lever switch. This switch work as follows:
1. When no card is inserted / no write protection , the switch is open and thus the protection is off.
2. When locked card is inserted , the tab is depressed and tells the camera that the card is lock.
Contrary to popular belief ,the little tab on the sd card is not an electronic switch and does not physically influence the card operation itself. If you put a locked card into a camera without a sd lock switch , you would still be able to use the card normally.
It is incredible difficult to fix this switch because of space limitations in the sd card. Look into the sd slot and if you can see the switch , use a needle to pull the little tab down toward the base of the camera by about 2mm or until it works being careful not to bend it.
If this does not resolve your problem , there might be a short in the switch circuit and the camera will need to be disassembled to resolve this error. This should cost no more than $50.
Please feel free to contact me if you need further information
Kind regards
Andrea
Posted on Sep 27, 2010
  • 374 Answers
SOURCE: MY MEMORY CARD IS LOCKED!!
Exactly. Sometimes if you use a card reader it will automatically lock the card when you install it. Keep that in mind.
Posted on Apr 05, 2008
fotomohamed
  • 321 Answers
SOURCE: Camera says memory card is locked
pin inside is stuck
Posted on Jun 18, 2009
Larrysito
  • 73 Answers
SOURCE: Exilim memory locked
its or child lock ,check manual or firmware damage ....software in the camera check how to fix in manual..
Posted on Aug 30, 2009
  • 3287 Answers
SOURCE: My camera is locking my memory card. I slide the
I have had a similar problem with flimsy lock tabs. I solved it by placing a small amount of scotch tape over the tab - starting near the connection pads, over the tab to the back edge of the card. There's usually not a whole lot of extra room in the slot, so insert carefully and remove portions of tape as needed.
Worst case scenario - if you never use the locking tab (I never do) you could place a small dab of super glue to hold it in place. Let it "set up" before reinserting - you don't want the tab to move an be held on the lock position.
Posted on Sep 18, 2009
Testimonial: "Good ideas, I'll try both. I wasn't sure if it might have been a problem with the camera causing it to push the lock up, but I'll try this first"
  • 11967 Answers
SOURCE: casio exilim ex-z20 keeps saying memory card
Move the slide switch on the side of the card. Then, go into the camera menu and find "reset"...follow the on-screen instructions.
Posted on Jan 09, 2010
The card is locked so the camera doesn't work. how do I unlock it?
If your camera uses a SD memory card then -
SD and Micro SD memory cards has a smallslide switch on the edge of the card, which write protects data on the memorycard. Slide the switch from the READ position tothe WRITE position, which is furthest away from the contacts.
May 12, 2012 | Casio EXILIM EX-Z1000 Digital Camera
Message reads "card is locked." After
Look at the memory card. SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
Jan 09, 2011 | Casio Exilim Zoom EX-Z80 Digital Camera
The camera says in the screen that the card is locked The memory card is locked and I cant figure out how to un lock it is in the set up or what do I do ? my camera is EXILIM 8.1 Mega Pixels
I've never fiddled with this brand of camera, but there will be the option to lock the pictures in the menu. In your manual, look for "memory", "locking your pictures", things like that. Also, some memory cards have a plastic tab that slides to lock the card- make sure that isn't in the lock position, if your card has one. Good luck, and hope this helps.
Jun 11, 2010 | Casio Exilim Zoom EX-Z80 Digital Camera
Kimly may -casio exilim the card is locked
Look at your memory card. SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Dec 05, 2009 | Casio EXILIM Card EX-S770 Digital Camera
When I try to take a picture the scrren reads
the memory card should have a small switch on the upper left side it slides from lock to unlock if this doesnt work Look in the card slot - there may be a small bit sticking out over where the card's locking switch would fit when the card's inserted
Oct 24, 2009 | Casio EXILIM Card EX-S770 Digital Camera
Aug 30, 2009 | Casio Exilim EX-S500 Digital Camera
Casio exilim EX-S880 8.1.mp memory card locked
there should be a little swith on the side of the card. switch to the opposite and then try
Sep 27, 2008 | Casio Exilim EX-Z40 Digital Camera
Jan 04, 2008 | Casio EXILIM Card EX-S770 Digital Camera
Casio Exilim EX-Z57 Digital Camera Logo
78 people viewed this question
Top Casio Cameras Experts
Greg Cann
Greg Cann
Are you a Casio Camera Expert? Answer questions, earn points and help others
