Question about Executone Lands Phones
Looking for a hookup manual for an Executone amp PB350
How do I program the Executone model 64 LCD to
I assume you mean change the time and date and that depends on which system model you have....assuming you have an "IDS"...go to the receptionists phone ( the phone you reach by dialing 0 or 3001/ 301 ) and without lifting the handset dial 28 followed by the time in military format...if it worked you'll hear a few quick beeps after inputting the time. You might have an Executone Medley...if so > http://www.mainresource.com/PDFs/TipsMedleySysAdmin.pdf
If you have an older version of IDS you need to program it via a programming terminal or laptop. Leave your email here if you get this and I'll email you - can do it remotely via built in modem.
May 14, 2010 | Executone 64 Corded Phone
I have an Executone R 3700 intercom system from 1957 (tube). It worked fine until a couple of years ago. Now all I get when I turn it on is a buzz. I've replaced the tubes, but that did not fix it. ...
EXECUTONE IS NO LONGER IN BUISNESS BUT SOME PARTS MAY STILL BE OUT THERE. WE HAVE AN EXECUTONE NURSE CALL SYSTEM IN OUR HEALTH CARE FACILITY WITH THE SAME PROBLEM PARTS NOT OUT THEREIF YOUR ANY GOOD WITH AN OHM METER YOU CAN START SNIPPING DIODES AND TESTING ONE AT A TIME AND SOLDERING BACK UNTILL YOU FIND THE ITEMS THAT ARE CAUSING THE PROBLEM. THAT'S WHAT I HAVE TO DO FOR OUR NURSE CALL. GOOD LUCK
Aug 10, 2009 | Kitchen Appliances - Others
Model 1B
you will need to have access to the phone system programming. you can do this through a laptop or through Operators programming if you have one there.
Once you are connected you will access A screen, then the EXT you need to program and then K for Keys. there is where you set up all of the programming on each key.
if you need more info, somehow contact me and I can help over the phone. Every system has a remote access through a modem that is built in on EVCM.card.
Aug 25, 2008 | Executone Corded Phone
Executone 64 Administrators manual
if you can get into the programming then first go to the B screen and then press A and set the drop pulse to 10 and then press C for Copy and then Y .
hit ESC and press J
the cursor should be blinking on the first line on top left corner, there hit F for Flash and press ENTER
Hit ESC and press A , put in the EXT you need to program the key for, then press Enter, then K, then K again and pick a key to programm. once you have picked one by pressing ENTER key to move the cursor program a code 815 ENTER, S for Subcode and then 1 Enter
ESC, ESC E for exit.
contact me for more info
Apr 17, 2008 | Executone 64 Corded Phone
EXECUTONE MODEL 64 Phone
quick way is to delete them both and re-record
Aug 08, 2007 | Executone 64 Corded Phone
Lands Phones Logo
83 people viewed this question
Top Executone Lands Phones Experts
David Burbee
David Burbee
Tom Chichester
batMichael
Level 1 Expert
Are you an Executone Lands Phone Expert? Answer questions, earn points and help others
