Question about Kenmore Refrigerators
Odor in the fridge after the compressor broke down
    President:
  • 704 Answers
All refridgerators will develop an odor whenever they are turned off, or the temperature gets too warm. The reason for this is that the small microbes from the various food stored in the fridge will start to grow some bacteria which will make the fridge smell.
You should empty the fridge and freezer, turn it off and clean the inside with a solution of white vinegar and water (50/50 mix) and wipe all the surfaces and dry it off. Also clean out all the bins and shelfs and compartments. Then leave the doors propped open for a few hours to remove as much moisture as possible until it's dry and you can confirm there is no more smell.
Put back all the shelfs and such and turn the fridge back on and you should be fine. Hope you find this Very Helpful and best regards!
Posted on Sep 09, 2009
Can't find bad odor
You probably don't want to hear this, but here goes: usual cause of this is from spilled liquids that have gotten under or behind inside panels of fridge. Other most common cause is from something nasty getting into the motor/compressor area located in lower back of unit. Most people don't know that the compressor area should be cleaned about once a year. Good luck with your fridge.
Jul 02, 2012 | Refrigerators
We have a terrible odor from fridge side. Cleaned it 3 times..found nothing and odor persists Any suggestion? No odors when doors are closed
What does it smell like? Burnt plastic , mold , rotten food? Check gaskets and temp in fridge, food could be spoiling. It is tough to get serious odors out of fridges. Bleach, vinegar are good for killing odors. Check manufactures recommendations.
Apr 14, 2011 | Viking 42 in Built In Professional...
There is a strong odor coming from the freezer something like a fish smell or a burnt wire. The ice maker is working ok and the fan blows air just fine and the freezer and refrigerator are operating just...
The smell could either be the fan motor or the defrost heating coil...
Check out these tips...they can help you figure out what is going wrong withyour refrigerator
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Mar 18, 2011 | Amana ABB1927DE Bottom Freezer...
Odor can it be freon leak?
Two possible causes of odor on fridges:
* Freon Leak
* Defrost Drain Pan dirty.
If the fridge was unplugged for a while or there was a liquid dropped in the refrigerator, it's more likely to be the drain pan. It is located at the back of the appliance, above the compressor.
If it is clean and the smell is not coming from there, then you may suspect about the freon leak.
Nov 06, 2009 | Sub-Zero 661/F Side by Side Refrigerator
My GE refrigerator is leaking cold air at the wires coming out from the back of the refrigerator. The frame around this hole is cold. Is there a leak inside the refrigerator? What can I do to fix this...
refrigerant could leak inside the unit, it could smell bad if the compressor had a burnout
refrigerant carries oil troughout the system and back to the compressor
if the compressor had a burnout, the oil would turn acidic creating an odor if there is a leak
personally I would check what's inside, open a box of baking soda and see if this eliminates the odor
if your fridge quits cooling, you've got a leak
Sep 17, 2009 | Refrigerators
Refrigerator Odor
sounds like fungus in the drain tube
unplug fridge p\and pour some bleach in the freezer
it stinks but it will kill the smell
after 10 min or so take fridge to patio and hose her down water will not hurt the fridge it will however clear the drain lines
and it might be a good time to clean the coils and the colection tray under the back of the fridg any way
Aug 06, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
When motor comes on there is a stale,odor
check around the compressor area and the drain pan there might be a mouse or something dead under there make sure to unplug the fridge before you go messing around back there
Jul 11, 2009 | Kenmore 50522 / 50524 Side by Side...
I have an odor cause my fridge has been closed with no power
yes drain pan is located in the back on top the compressor....10:1 solution of water and bleach is good enough to clean it with....kills mold and mildew....also remember that if the fridge lost power and found cause a stench inside, could be held by the plastic....ive been using dryer sheets in my units to help with odors. may take a few weeks...but a new dryer sheet a week helps.
Jun 12, 2009 | Refrigerators
Fridge has an odor recently
It is likely that you have a problem with the capacitor.  Look for it on top of the compressor.  If it is discolored or smells...you'll know!...replace it.  While you're there, clean out the condenser fins.
Nov 14, 2008 | Kenmore 50522 / 50524 Side by Side...
Fridge odor
There are a couple of methods to help remove odors from a fridge. The first is a cookie sheet with baking soda spread across it left in the fridge for several days. The other is something called Activated Carbon. Most stores sell it as a carbon odor filter and it is pretty cheap. It actually works better then the baking soda so I recommend you pick some up and just leave it inside the fridge. You can also put this behind your fridge or wherever you have foul odors. Hope this helps.
Nov 01, 2008 | Kenmore 18.3 cu. ft. Top Freezer...
Refrigerators Logo
79 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
dweatherby
paulcarew
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
