Question about HP Pavilion dv9000z Notebook
HP Pavilion won't recognize DVD Drive
I have a HP Pavilion Laptop. I was burning DVD a couple of weeks ago, and now today I put a DVD in the computer and it won't recognize it's in there. When I take the DVD out the drive isn't there either. The message I get when I try to burn the DVD it say I don't not have access to the burner.
Any solution to this problem
  • angelaharris Sep 09, 2009
    This is the error message I receive for the DVD drive: Windows cannot start this hardware device because its configuration information (in the registry) is incomplete or damaged. (Code 19)
    I tried to update the driver, but it says the best driver is already installed.
    Sniper:
  • 87 Answers
Hello Angela,
Try the FixIt software from the following site :
http://support.microsoft.com/kb/314060
Regards,
Nikhil
Posted on Sep 09, 2009
Testimonial: "Nikhi, Thanks for the fix, it worked and now my dvd drive is recognized and is playing. Angela"
I had the same problem with my HP laptop. I reinstalled the OS with the recovery discs. It didn't work. I contacted HP on line, they spent about an hour with me looking at drivers, hardware, etc. Nothing worked. In the end they suggested I pull out the DVD unit and reset the BIOS. Still didn't work. I'm out of ideas.
Posted on Oct 22, 2009
  • HP Master
  • 4,924 Answers
Hmm it seams that the drive was disabled from the manager or something like that ...get into bios and try to find the drive ...it has to be found on devices where the hdd and the other drives appear ...if it isnt try to get the bios settings to the optimal factory defaults ..or to remove the bios battery for a few seconds...or if it has to short the power of the bios with a jumper...this just might get the drive back on its place ...anyway even if it does not ..reinstalling the OS will
Drive is on the computer but won't play
you need to replace the dvd drive, you dvd player is faulty, it happens a lot with laptops, mostly after about 3 years they go faulty and ether the cd reader or dvd reader stops working.
Aug 16, 2009 | HP Pavilion dv4-1140go Laptop
Hp pavilion zv6000 wont recognize dvd+r
Hi Terry,
The answer is pretty simple, the ZV series is about 4 years old, back then DVD manufacturers decided which formats they would support as it was too expensive to make desktop drives, let alone, laptop drives that supported all formats. That drive only works with DVD-R and I believe DVD-RW. If you want to burn other formats, the laptop will only support them if you add an external drive of a newer make.
Note: Virtually all current models support ALL DVD formats and many support BluRay as well.
Hope this helps,
Chris
Jul 07, 2009 | HP Pavilion ZV5000, ZV6000, ZX5000 Series...
DVD-RW Not recognized in Dell Inspiron 1525
Turn off your laptop, take the dvd-rw drive out of the laptop and then reseat it back into the slot so it snaps into place. Turn the laptop back on and make sure its recognized in My computer.
If it is reocognized then try to burn again and see what happens. If it still gives you the same message, see if your drive will read regular dvd movies. If it doesn't then that means the laser is going bad and the drive will need to be replaced.
May 18, 2009 | Dell Inspiron 1525 Notebook
My HP notebook will not recognize dvd-r disk
It's pointing towards a hardware problem. You can try updating your drive's firmware.
Check HP's support page to see if they have one available.
If not you can check the device manager details of your drive and find one floating around the net, I'm sure.
Feb 24, 2009 | HP Pavilion DV6700Z Notebook
New laptop... HP Pavilion dv2000 DVD drive does not recognize any disk
i hope the size of file not larger then then the DVD/CD, ( i think you already know about that)
if you burn multiple format of file, make a folder and put all the file in the folder, so burn the folder,
especially when you put a zip folder, sometimes it will cause error,
Oct 23, 2008 | HP Pavilion dv2000t 14.1" Notebook Laptop...
Laptop CD/DVD Drive
Hi RC2935
Try this and see if it will help you
Here is what you do  Click on start and then go to run type in regedt32 For Vista Click start and search for regedt32 and click on it
Go to the following HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
Delete the upper and lower Filter or witch is available close window and restart the PC it will work
This is common on the Acer, HP,Toshiba etc,etc
if you need help let me know
kind regards mervin
Sep 24, 2008 | Computers & Internet
HP 530 Laptop - CD/DVD Drive not functioning
you have a faulty drive/connector/motherboard or even cd/dvd laser, if it,s warranted. send it back while it,s covered.
Mike @ compurepair.
Feb 24, 2008 | HP Pavilion dv6000z Notebook
HP dv4000 laptop CD not reading
Hi
Type of media settings might be the issue but making a change for standard CD/DVD recording (it affects reading too) Issue can be resolved. Right click on the CD/DVD drive (Usually D drive ) click on properties and select and choose the recording option. Click the enable CD recording for this drive option
Click on apply and OK. Try again. You may try after reboot the computer. If issue persist please post so we can think about some alternate solutions.
Good Luck
Jan 23, 2008 | HP Pavilion dv4000 Notebook
Burner doesn't act right
If you have a backup HDD or ipod etc.. bacup your important files and re - install xp. If this dosen't work or you don't want to risk it then you might be able to just send in the DVD drive
Jan 07, 2008 | HP Pavilion ze2000 Notebook
HP Pavilion dv9000z Notebook Logo
1,131 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
