Question about VIDAR Systems VIDAR TruScan Select Plus
Using a vidar truscan select p-75 with vista
Will a vidar truscan select model p-75 work with windows vista? If so can I use TruInfo?
2 Suggested Answers
  • 5223 Answers
SOURCE: can the vidar truscan p-88
This scanner does black&white and gray-scale scanning but not color.
I hope this helps.
Posted on Aug 31, 2010
Can the vidar truscan p-88 4019 do color?
I hope this helps.
Aug 31, 2010 | VIDAR Systems VIDAR TruScan Select Pro
Input Not Support
This means, that your operating system is not set to the recommended resolution of your monitor. Your monitor has a "fixed" resolution where the image will look best. You can change the solution in Windows XP if you right-click on a free space of your desktop, then choose "Properties". In the new window, that comes up, select the rightmost tab. There you can use the slider to adjust your resolution. Just try some different resolutions until the message disappears. If you use Windows Vista oder Windows 7 you can access the resolution windows by right-cliking on your desktop and selecting "Screen resolution".
Jul 18, 2010 | AOC 19LVWK LCD Monitor
I can't fax docs. on my all in one lexmarkx74-75
Why not just use the fax that is integrated into all windows XP systems, and probably Vista???
If it's not already installed, go to control panel, "add/remove programs", "add windows components", select 'fax services'. The use it as if it were another printer (don't forget the phone line)
Feb 26, 2009 | Lexmark Office Equipment & Supplies
I don't have driver for truscan titan yet
hi,
hope this can help you for your truscan titan drivers update at the link below.
http://support.vidar.com/default.htm
Nov 28, 2008 | VIDAR Systems VIDAR TruScan Titan II
X1150 Lexmark printer purchased with imac - need to install without disk
If you do not have the disk you must download the software from Internet, follow instructions below,
Click here:Official Lexmark Drivers and Software
A web page will open, follow instructions, select model, select operative system etc., and click on download .
Chose to download the file in my documents when asked.
After downloading, find the file,double click on the file ,then if you get in troubles, follow the instructions below to reset and reinstall drivers:
  • Unplug printer USB.
  • Go to control panel >> installed printers in Windows and remove (delete ) any installed printer from printer list.
  • Download driver from website, or use the disk and run the install file.
  • Follow driver installation wizard.
  • Plug back printer when prompted from installation wizard.
Note:some printer does not work on Vista, if you do not find any driver download for Vista on your model page, that means your model is not Vista compatible.
Jun 28, 2008 | Lexmark X1150 All-In-One InkJet Printer
Software driver for vidar true scan select plus
Try this:
1. To obtain the driver, go to ftp://ftp.vidar.com/pub/sti drivers/ and
download "autocd.exe".
2. Run "autocd.exe" and the contents will be extracted to a folder.
3. In the Windows Control Panel, open the Device Manager (Control Panel->
System->Hardware Tab->Device Manager) and select the Driver tab within
the Vidar Scanners properties.
4. Click on "Update Driver" and browse to the STI folder (unpackaged from
autocd.exe).
May 09, 2008 | Office Equipment & Supplies
Minolta Dimage Scan Dual ll
Hello ! I try to use many difrent driver in difrent mod. eks:95,98,2000,xp
The best was 98,butt it still stops when the scanning starts.
Solution for my problem.......Vuescan from Hamrick.com
Mvh
Vidar
Norway
Feb 24, 2008 | Minolta Dimage Scan Dual II Film Scanner
Fluffs on my glases
Use a suction pad to lift the glass off of the magnetic plate and clean the underside.
Jan 25, 2008 | VIDAR Systems VIDAR TruScan Titan II Plus
Vidar select Pro Bulb? Blown out?
An E-mail to the makers web site will tell you whether parts are available for self fit or you need the expensive repair dude.
Nov 21, 2007 | VIDAR Systems VIDAR TruScan Select Pro
VIDAR Systems VIDAR TruScan Select Plus Logo
182 people viewed this question
Top VIDAR Systems Office Equipment & Supplies Experts
jasbo
jasbo
Are you a VIDAR Systems Office Equipment and Supply Expert? Answer questions, earn points and help others
