Question about Olympus FE-130 Digital Camera
"Battery Empty" sign with camera shut off
My camera has suddenly started to display a "battery empty" screen and subsequently shuts off whenever I take a picture, despite having just placed brand new batteries into the camera. Can you please recommend what I should do to repair the circuit? Thanks!
  • 1 more comment
  • Anonymous Jan 10, 2008
    my camrea wont work after putting new battreys in
  • RoSa_1 Jan 23, 2008
    i have the same problem with my FE-130
  • CHS Library Jan 31, 2008
    Yes have same problem. Works for couple minutes when you put new batteries in and then "Battery Empty" message appears.
    Problem Solver:
  • 24 Answers
This problem is usually found when using rechargable batteries as the voltage is only 1.2v rather than 1.5v fir alkaline. See if you can change the battery type in settings. If not consider using either long life non-rechargable lithium batteries or something else that I do but be careful: my camera used two cells so I put a rechargable lithium in one slit and a dummy cell in the other. The charge now lasts 10x as long as NiMh batts. The extra 0.6 volts doesn\'t bother the camera.
I mentioned be careful because if you put in two of these cells BG mistake you will probably damage your camera.
Posted on Nov 17, 2013
  • 797 Answers
You may try to set in setup the kind of batteries you are using. Many digital cameras allow you to set the kind of batteries being used. Whether or not this will solve the problem, is yet to be seen.
Posted on Mar 18, 2008
At the "battery empty" sign
long shot:
remove battery
press and hold down the power button,
insert battery
Jun 12, 2011 | Kyocera Finecam S4 Digital Camera
Whenever I open Pinnacle Studio 12, a box appears, titled 'Abnormal Shut Down Detected'. It reads: The last time Pinnacle Studio Plus ran, it did not shut down correctly. What would you like to do?...
Continue. Continue working on the same project
New Start with an empty project
Open. Open an existing project
Sep 11, 2010 | Pinnacle Studio Version 12 for PC
My camera stops working but the battery showed full.
Those are the symptoms of a battery that has been charged many times or has been allowed to completely discharge once or twice. Try some new ones.
Jan 06, 2010 | Panasonic Lumix DMC-LZ2 Digital Camera
Compatible Battery problem
Try clean contacts of the battery. If problem persists, note what is on the LCD when it turns off. Only symbol of an empty battery, or is there any text? If there is written "For InfoLithium/compatible battery only", it does not mean that the camera thinks the battery is empty, but that the battery do not communicate with the camera. If other batteries are OK, you should replace the bad one.
Sep 03, 2009 | Sony Cyber-shot DSC-W55 Digital Camera
Lens error, restart camera.
I had the same problem with my powershot and with the batteries going bad super fast. The way to fix it is to empty your memory card of all pictures then put it back in the camera blank. That should take care of the problem and should pro;long your battery life as well.
Aug 25, 2009 | Canon PowerShot A710 IS Digital Camera
Loosing power randomly
how old are the batteries and how many times they were charged without being fully drained can cause a short life for the battery. Try a new battery-fully charging it properly, but dont charge it again till it goes off by itself completely. If you have a wall charger, plug your phone in. If it stays on that way, check your 'power save' settings. That can also make your camera shut off. Try these steps first and see if it changes the 'battery' from being empty to full and stays on. hope this helps
Aug 24, 2009 | Sony Cyber-shot DSC-W170 Digital Camera
Camera won't work even with new batteries
Just had that same thing happen.
Try lithium batteries...Should solve it.
Jun 14, 2009 | Olympus FE-210 Digital Camera
"battery empty" on screen after I disconnected camera from compu
Hi, have olympus fe-280 camera. Battery on screen shows full but shows empty (an inch strip) in middle. I have charged it. Even bought a new battery. Can anyone help. Thank you. ...... I want thinking I may have two faulty batteries and just need to buy another one?!
Jan 25, 2009 | Olympus FE-280 Digital Camera
Flat batteries
a well known problem , this camera eats batteries there are high power (2950MaH) accus , those should be used with this camera even with 2700 MaH it is empty real quick
Mar 04, 2008 | Fuji FinePix S7000 Digital Camera
Olympus FE-130 Digital Camera Logo
139 people viewed this question
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Jerry Greenberg
Jerry Greenberg
Are you an Olympus Camera Expert? Answer questions, earn points and help others
