Printing from VB to Z4Mplus produces ''garbage''
We can print through a third party software - Labeltrain, but when we print to the Z4M+ printer ut of VB it just prints garbage characters
Z4MPLUS doesn't recognize the MEDIA(LABEL) automatically.
you should recalibt=rate the printer.
Are you sure that your previous label was not longer?
With the autocalibrate function activated the printer should try to detect the correct length. If it doesn't the yoou have
- A problem with the label border
- Preprinted stuff which the printer detects as to fo feed
Dec 09, 2013 | Zebra Z4Mplus Label Printer
My Zebra Z4M Plus printer is printing, but some part of the label is missing. The printing is good, and starting from a certain point, nothing is printed. There is a straight line (approximately 2cm from...
if is line across all the label, need printhead replacement, but first clian the printhead and the rollar, then check if the length and the with is the correct from the driver, last solution, resect the printer to factory defult.
Nov 04, 2010 | Zebra Z4Mplus Label Printer
New z4m is printing the data too big for the label and is skipping labels. Prints one, then a blank. I have several Zebra printers and the set up seems to be simular however I cannot get this one to print...
have you installed all the drivers correctly
and are you printing using the software that came with the printer or are you using word
if you are using word change the diamentions of the sheet when you go to print
Dec 29, 2009 | Zebra Z4Mplus Label Printer
Can't print images on zebra z4m printer
Check the "Dithering" setting in the printer driver. Turning "Dithering" on improves graphics but reduces speed of processing.
Apr 07, 2009 | Zebra Z4M Printer
Print problem
You should make sure you have the label program set for the same size label you are printing and calibrate the printer before you start a roll.
Feb 05, 2009 | Zebra Z4Mplus Label Printer
NO COMMUNICATION
hi i have zebra z4m plus printer when i give them command for printing it's not printing and i need a solution can you please help me thankyou
Apr 10, 2008 | Zebra Z4Mplus Label Printer
Printing problem
better to send it for repair
Apr 03, 2008 | Zebra Z4M Printer
When printing more then 10 labels from Acrobat some of them are missing
Hello!
Dear
I need ur assistance about this types of Model TLP-2844,LP-2844,S4M,S-600,105SL,110xiii,140xiiiPlus,Z4M,Z4MPlus,How can I Install a Printer With Label and Ribbon?Can U help me regarding this problem?I am waiting for ur assistance.If possible please send me a video file about how to Install a Zebra Printer with label and Ribbon.
Dec 13, 2007 | Zebra Z4Mplus Label Printer
Zebra z4m plus
try setting up your tcpip port to use LRP it seems to work for ME
Aug 11, 2007 | Zebra Z4Mplus Printer: Internal ZebraNet...
161 people viewed this question
k24674
jasbo
jasbo
