Question about Electronics - Others
Loud mains hum - Electronics - Others
  • 5,487 Answers
The large electrolytic capictors in the power supply could have failed.
Posted on Sep 27, 2009
Why does it make a loud Humming noise?
Something is still in the main wash pump, you hear the motor trying to turn the impeller and it can not
Mar 27, 2016 | Dishwashers
I have kenwood amp m-a100 which has loud buzz / hum on all channels and distorts radio very badly can you help ?
The loud hum will be probably caused by the Large Electrolytic Capacitors in the Power Supply section. All of them will need to be replaced to be on the safe side. The buzz noise is caused by the fact they are letting in the 50/60hz mains. Hopefully that should clear everything up.
Sep 09, 2014 | Audio Players & Recorders
Loud hum when volume is turned up and ground is attachedntable troubleshooting
Apart from the suggested solutions shown below, you might also want to consider the turntables power supply as the cause of the hum. Perhaps a faulty mains smoothing capacitor?
Apr 07, 2014 | Audio Players & Recorders
Benwin 5.1 surround sound system Humming loudly without anything pluged into it!!!
It is sad your having a problem with your
If humming can be heard on all speakers, then it could probably
be on the power supply.
If it is only on the main SUB unit, then it could be the amp itself.
But check for power supply capacitors that supplies voltages to the
amps.Check for amp output DC voltages too.
Oct 04, 2012 | Audio Players & Recorders
Loud hHum from Subwoofer
Sounds like the hum might be mains hum caused by the failure of the power supply capacitor(s) in the sub. It/they will be the largest on the pc board. You will find all the details (needed to replace it) on them. If you find more than one replace both.
Dec 10, 2009 | Audio Players & Recorders
When i put the tv on there is a loud humming as the tv warms the
could be a fault in the mains power-supply section,
Oct 13, 2009 | Televison & Video
GU1500XTL loud humming sound during the cycle, getting louder
The run capacitor on the main wash motor needs replacing. Eventually it will just hum and overheat instead of rotating, so better replace it now before it overheats.
I doubt you can acces it easily yourself, as it may be away from the motor, and have to be tracked down.
Aug 05, 2009 | Whirlpool 24 in. GU1500XTLS Stainless...
Pioneer Receiver SX-750: Getting a loud hum through the speakers
The hum you hear from the speakers and from the unit itself originate with 60hz AC power. They may not actually be related. Sometimes a transformer will hum slightly and unnoticeably. That you're getting a loud speaker hum says there is an electrical leak or a grounding issue somewhere.
Do all sources produce the hum or, say, just the phono? How about on headphones? Try rotating the AC plug. In those days they weren't keyed with one large blade as they are now.
May 17, 2009 | Pioneer Audio Players & Recorders
Dell 3300mp Projector Loud Noise
Judging by the mains hum noise and now shaking it sounds as if a motorized component has broken.
Humming could have been the initial jam, then shaking the damaged part attempting to rotate.
Maybe check your cooling fan blades?
Dec 02, 2017 | Dell 3300MP Multimedia Projector
Noisy
usually a noisy machine means either the main bearings have gone or the motor has got damaged/worn in some way. to check the main bearings try lifting the drum with the hand from inside or rotate the drum with the hand to see if the rumble can be felt. i cannot think what else would cause a loud humming though.
Jun 11, 2007 | Zanussi FJ1454W Front Load Washer
Electronics - Others Logo
63 people viewed this question
Top Electronics - Others Experts
Are you an Electronics - Other Expert? Answer questions, earn points and help others
