Question about HP Computers & Internet
Monitor Blacks out after starting and never comes back!!
  • Roman
    Roman May 11, 2010
    What happens with led on the front? Will it turn off after starting? If yes, the problem is related to the power supply most likely. If not, then if you have another monitor, connect it and set in the display settings some high-contrast color scheme (right-click on desktop, Properties) or set black background and keep Display Properties window opened in the middle of the screen, so that'll be your highly contrast image. Connect your HP back and under bright light check if after the display blacks you still can recognize the window you left opened on the desktop. If yes, then your problem is related to the backlight (CCFL lamps or inverter). If no, then to the power supply.
  • Yannick Verhoog May 11, 2010
    When exactly during starting does it black out? For example: After logging on, during Windows startup, during BIOS?
4 Suggested Answers
Geekman
  • 32281 Answers
SOURCE: monitor blacks out
You may have a defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp.
Connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out
www.lcdparts.net
Posted on Sep 12, 2009
jesselohse
  • 128 Answers
SOURCE: how com monitor blacks out
I am not sure I am fully understanding your issue...but monitors require power to operate.
Good Luck,
Jesse
Posted on Jan 06, 2010
budmrtn
  • 11361 Answers
SOURCE: monitor comes on when booted, then blacks out.......
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Posted on May 20, 2010
Monitor comes on when booted, then blacks out.......
May 18, 2010 | Computers & Internet
How com monitor blacks out
Good Luck,
Jesse
Jan 06, 2010 | Star Logic Monitor 11009515
Monitor blacks out after a while
your power supply is failed or the back lights.remove the back cover and look at the power supply. look for leaking blown capacitors and replace.
Dec 31, 2009 | Dell Computers & Internet
Philips Brilliance 200 W 6 Flat Screen Monitor blacks out
sounds like the monitor is burning out or color is out of alignment could be result of burning out and no it's not worth repairing it. had one guy repair a montior a while back, could be looking at easy 200 to 400 bucks repair. not worth it. much cheaper to buy.
Oct 16, 2009 | Computers & Internet
My monitor light comes on but there is no signal.
Isolate the problem. Connect the problem monitor into different computer. If the problem monitor worked on another computer, try connecting a CRT monitor to the problem computer. Once the display comes back, change the screen resolution.
Jul 29, 2009 | Gateway FPD1775W Monitor
My BENQ monitor blacks out
Use the remote to access menu mode
then try inputs through the remote
Jun 16, 2009 | BenQ FP71G 17" LCD Monitor
Blacks have changed to blue on my PC Monitor
Can you check your monitor's device settings (on physical buttons on the monitor) and check for changes to the Hue or contrast setting(s)?
It sounds as if the hue or contrast has been adjusted slightly, just enough to be visible.
May 24, 2009 | Acer AL2416W Monitor
Computer monitor goes blank after initial start-up reaches the desktop
Try setting your graphics card output to something simpler like a basic 640x480 resolution 64k colours and see if it still does it... it maybe that you have the resolution/colour depth to high for the monitor to properly handle
if it is stable at the lower setting slowly increase untill you reach a point that you and your monitor are both happy
Oct 08, 2008 | Computers & Internet
LCD Monitor blacks in and out for 1-2 seconds
does your monitor have an external transformer as the psu ?
If so, try disconnecting at mains for about 5 seconds and re-connect. failing that we'll need to dig deeper.
Jan 06, 2008 | Samsung SyncMaster 205BW LCD Monitor
Computers & Internet Logo
49 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
