Question about HP PSC 1315 All-In-One InkJet Printer
Having problems loading printer onto computer
Not real good on a computer hope you can help.I have hp1315 all in one printer & compaq 5315 pc running windows xp dont no how to get this to work as i dont have a cd for this printer hope you can help every time i go to print it comes up fax and i can't clear it.thankyou luke
How to scan and save the image to my document using windows 7 and HP1315 scanner/printer
There are two ways of saving the scanned files to your document. - First, use the Solution Center on your PC. - Second, using other Microsoft applications. If you don't have Solution Center on your PC, try this link to help you install the right software and it also gives you some troubleshooting.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c02658530&tmp_task=solveCategory&lc=en&dlc=en&cc=us&lang=en&product=374568#N299
Hope this will help!!!
Apr 10, 2011 | Office Equipment & Supplies
Can not load the printer drivers on Compaq Presario SR1403WM Desktop PC message says it can recognize device the device is plugged in I am trying to load Lexmark 8300 printer I have disk but it stops...
Don't think you need to worry about a internal computer problem at the moment. Chances are that it is a dodgy disk.
First thing to do is to download the driver file fron the manufacturer's website. The fact that it detected your printer suggests that it is not likey to be a connection issue.
If you download the driver and it still does not detect the device, disconnect the printer, restart the PC, then run the installation program that you downloaded and then connect the printer when prompted.
If this does not work, suggest you try a different usb port in your computer and try again.
Finally it could be a software problem so you could recover the pc back to its factory settings with your recovery discs. Only when that does not work should you think about it being a printer or pc hardware problem.
Note that you could try connecting the printer to a different pc to test whether it is the pc or printer at fault.
Hope that helps - pls rate the solution
Nov 15, 2010 | Compaq Presario sr1403wm AMD Sempron 3000+...
My daughter's laptop Acer Aspire 5315-2713 has been experiencing sudden shutdown. I cleaned out vents and replaced cooling fan. Problem persist! I did notice cooling fan never runs. Help! What else can I...
buy your daughters laptop a laptop cooler with built in USB fans i had similiar problems with my wifes hewlett packard compaq cq bought a laptop cooler fixed the problem
(if you replaced the cooling fan why does'nt it run)
hope this helps
Oct 28, 2010 | Acer Aspire 5315 Notebook
Computer continually rebooting problem
You could try a windows repair install.
Apr 19, 2009 | Compaq Armada E500 Notebook
How to reset Bios
Good night sir, sir laptop ka bios password kaise tootega.mera laptop compaq ka cq40 moddle ka hai.
Sep 19, 2008 | Acer Aspire 5100 Notebook
No internet after formatting
A visit to the HP website will fix that problem.(HP owns Compaq now)
Your drivers should be HERE
The only real problem is figuring out what version of hardware you have installed in the laptop.
You will also be able to get your wireless drivers, audio, video etc all from there.
You will either have to download them onto the computer you are on now and burn them to a cd or dvd, or use a USB flash drive to copy them to your laptop. If you still have your original cd's that came with the laptop, then the drivers although out dated will be on there.
Hope it helps.
Apr 14, 2008 | Compaq Presario V4000 Notebook
HP PSC 1315 All-In-One InkJet Printer Logo
27 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
