Question about Minolta EP1031/1031F CS/PRO Copier
The main switch will not turn on Minolta EP1031F CS/PRO Copier
  • Minolta Master
  • 1,294 Answers
Please check the folowing parts:
1.The alimentation cord and fusers
2. This copier have 2 microswitch to contact one under front door,and the second under main power cover(in the rear side )
3.Press down the top parts(platen cover)
4.Check the power switch.
Posted on Sep 13, 2009
Please explain code c000 by minolta ep4000/5000 CS/PRO Copier
Sir/Mam,
C-0000 is the code for the Main motor something is preventing it from turning more then likely in the fusing section the hot part. Or the motor is already burned out or the Printed circuit board that controls it. open and close the front door to reset.
Aug 18, 2013 | Minolta EP4000/5000 CS/PRO Copier
Minolta cs pro 1031f error CE 034566
Could not find that in the service manual But might be the main board. Will it scan if the document is placed on the big glass instead of the document feeder.
Jul 16, 2013 | Minolta EP1031/1031F CS/PRO Copier
What's your problem?Minolta EP3050 CSPRO Copier printed copies, then display read ''malfunction detected'' code C0070
Main hopper toner replenishing motor M8 failure to turn.The output from toner bottle home position sensor does not go high within 5 seconds after M8 motor has been energized.Verify the conectors,sensor and motor.Open the front door,turn the toner bottle 1/4 turn clockwise manually with the bottle holder closed.Under the above condition does the toner bottle turn when the front door inter lock switch is turned on?NO - change the toner replenishing M8 motor.Does the toner bottle stop at home position after turning?NO- change PC35 toner bottle home position sensor.Recomanded use vacuum cleaner.
Aug 14, 2012 | Konica Minolta Copier Toner EP6001 CS Pro...
Where can I download service manual for Minolta pro ep 2030. Free if possible
i can download it for you send me an email to forward it to you
Jan 31, 2011 | Minolta EP1083 CS/PRO Copier
EP1052 cs/pro copier hang but the light color is still green , I switch off the power and on it again , but nothing is change !!! can you tell me in instruction what to do please ... thank you
Minolta EP1052 - Operates but nothing prints on the paper. Toner seems OK. Can't get to print in any of the exposures.
Any ideas - or has it finally died??
Nov 30, 2010 | Minolta EP1031/1031F CS/PRO Copier
WE HAVE MODEL #EP1031F. THE "READY" BUTTON DOES NOT LIGHT UP, COPIER DOES NOT PRINT. THERE IS ALSO AN ICON LIT UP BY THE COUNTER WINDOW THAT LOOKS LIKE A CROWN. IS THIS INDICATING IT NEEDS...
Have you installed a new toner??? It may take a few minutes for the copier to add enough toner to make a copy. It's been awhile scince I've worked on one... But I think if you turn it off and hold down the Clear/Stop botton when you turn it back on, it will make the copier add toner... It looks like the display i chashing a box in the display. Good Luck
Nov 01, 2010 | Minolta EP1031/1031F CS/PRO Copier
How to clear M2 on minolta EP 4000/5000 cs/pro copier pls send solution to michofolasenterprises@yahoo.com
clear web or drum count and developer,you will not effect the the machine aporation,by clearing count
Sep 16, 2008 | Minolta EP4000/5000 CS/PRO Copier
Cs pro 5000
  • sorting problem, see main sort motor,clean all photo inter,ben shift. good luck
Apr 28, 2008 | Minolta EP4000/5000 CS/PRO Copier
80 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
CheckitRight
CheckitRight
David Burkhart
David Burkhart
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
