Question about Briggs & Stratton Garden
2001 john deere saber briggs moter smell gas in oil
Runs for minute starts flooding out dying have 2 drop rpms down stays running but will die in high idle you can smell fuel on oil dipstick could this be the fuel cylanoid going bad on my carb i think it is a 13 hourse briggs engine
  • 69 Answers
If you're using ethanol-blended fuel, the ethanol will eat away at the neoprene parts inside the Briggs carb.Going to need a carb rebuild.
Don't run your engine until it's fixed or you could damage it as gas will pour into the crankcase, causing the oil to thin and lose its lubricating ability.
Posted on Sep 09, 2009
I have a John Deere JS30 self propelled lawn mower I had issues with it running for 15 minutes and then it stops running. Was low on oil. Added oil over the full line now it runs for 3 min and dies
Wayne, correct your oil level to full line, change your spark plug and try mower. If still acting up after a couple minutes, the Gas cap vent may be plugged, remove or loosen cap to see if mower will run longer and better. If no improvement, the carburetor is dirty and needs cleaned or rebuilt.
Lawn Mower Starts Then Stalls
How TECUMSEH FUEL CAP can Give You Problems
lawn mower troubleshooting
HOW TO CLEAN The Carburetor on BRIGGS Stratton Quantum Lawnmower Engines
Apr 03, 2016 | John Deere Garden
John Deere high performance technology g4 crankshaft OHV twin 23 gross horsepower manufactured by Briggs and Stratton whenever I run over big weeds the mower dies once it dies it will not start for 20...
if the engine is a briggs and Stratton then check the valve clearance as B&S engines have a history of the valve stems stretching early in use and when hot hold the valve partially open until cooled down
Sep 16, 2014 | Cars & Trucks
2001 vw cabrio starts then dies immediately. will not stay running and you can smell gas -- seems to be flooding
Often, when a vehicle starts and dies immediately, there is a problem with the security system. It could be a key fob with a bad battery or a system that has lost communication with the rest of the vehicle. Try using a different key to start the vehicle. If this does not work, try scanning the vehicles computer to find any fault codes. Security system issues often have to be repaired by a dealer or a shop with qualified equipment. If you smell fuel when the vehicle starts and then dies, flooding would not be the problem, but rather a lack of fuel. Look for puddles of fuel under the vehicle and make sure there are no loose connections or bad lines.
Apr 23, 2014 | 2000 Volkswagen Cabrio
John Deere L120 runs for 15 minutes, bogs down and dies. A few minutes later starts right up, runs for a few minutes and dies again. I have changed the fuel filter, all fuel lines, air filter, cleaned the...
Is this an older machine ? If so try finding the points its usualy on the front lower part of the engine behind the cover, if you see that then it needs its condensor replaced, lookes like a round battery.
If this is newer or you can also try changing the spark plug sometimes they heat up and fail.
Sep 17, 2012 | John Deere Garden
John deere mower Won't start
Sounds like the carb is varnished up and needs to be rebuilt. They make rebuild kits depending on the carb number and you can rebuild it.
May 05, 2017 | Garden
14.5 horse I/C ohv with oil
sounds like the needle valve and seat in the carb is bad
Jun 02, 2012 | John Deere Garden
I have a john deere gx85, i have been using it all year and had no issues until recently. it runs strong for about 5 minutes then all of a sudden dies and sounds like it chokes itself out. i cleaned air...
A buddy of mine had this problem. He said there is a line running from the carb down to the crankcase. I don't know if a valve quit working in the carb or what...basically after he shut it off, it was draining fuel into the crankcase. Obviously he changed the oil, and started shutting off the fuel valve after he mows with it. No problems since.
I imagine the problem could be solved with a carb rebuild as well.
Oct 21, 2010 | John Deere Garden
I have a john deere riding mower model L100 it runs good but after 20 o 30 minutes gas stop going to the engine after it cool down it start running again does this mower have a gas pump
When it dies loosen the fuel cap and see if it will start.If it starts its because the tiny vent hole in the fuel cap is plugged.
Jun 26, 2010 | John Deere Garden
JD L120 riding mower keeps dying on me
Loosen fuel cap 1 turn to see if it will stay running.Theres a tank breather hole/vent in the cap and when it becomes plugged no air can get into fuel tank when fuel is used,can also be a plugged fuel filter.
Apr 21, 2010 | John Deere 420,1020,2010,2020,2510,2520...
Garden Logo
333 people viewed this question
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
donald boissonneault
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
