Question about Panasonic TH37PX60 37 in. Plasma Television
The signal connector came out back of T.V. Where abouts on back do I put it back in?
    Sergeant:
  • 244 Answers
Hope you mean the cable is disconnected, and not the outside threaded male connector that came as part of the t-v! if that's broken off, could be complicated to replace. if it's the cable (female, inside threaded- electronics can be a bit sexist at times!) then look at the back for 'cable or antenna in' carefully re-attach the female to the male connector. it can become frustrating to get them aligned properly. make sure the copper wire in the center of the female connector is straight!! so it fits properly!
be patient! if it's a 'push on', makes it easier, but not as secure. if it seems loose, a gentle 'squeeze' with pliers can tighten it up, very gentle!!
good luck!
Posted on Sep 09, 2009
I have a 2004 chrysler pacifica and only 1 turn signal doesn't work drivers front all others work. Replaced bulbs and still no turn signal. Replaced headlight assembly no good.
Remove the connector from the assembly and probe the light green wire (with white stripe) with an ohmmeter. Hold the other meter lead to ground to see if the wire is shorted. If not, turn the signal on and change your meter to vdc to see if power is coming to the wire. If not, trace the wire back to the bcm to see if the wire is cut. If not, remove the connector from the bcm to see if the terminal is pushed back inside the connector. If not, put the connector back on. With the headlight connector still off, probe the wire terminal at the back of the bcm to see if there is power at the bcm pin with the signal on. If not, replace the bcm.
Aug 01, 2017 | Chrysler Cars & Trucks
UN50EH5000F
First disconnect the power and signal cables. Then, open the back of the TV carefully. Lots of screws of different sizes. Remember where each screw goes. You will find flat cable connectors and sockets. Just pull out each connector from socket, blow into the holes to clear any dust. Plug them back one by one.
Then close the back and put the screws on and plug in the power and signals. see if this worked. Lots of times, dust settles in the connectors and if you are in a humid environment, the dust and humidity form a thin layer of insulator enough to block low level signals.
Aug 08, 2016 | Televison & Video
Front right signal and back right stop light not
Hi Anonymous, before diagnosing any turn signal issue make sure the bulb is good and the light fuse has continuity. If no turn signals work the cause could be a faulty turn signal module or the connector going to it, look for corroded, loose, or broken pins/sockets. Contact spray cleaner is great for removing corrosion. If your speedometer does not function properly it will have to be fixed first because your turn signal module gets the data from the speedometer for normal turn signal function. If your front turn signals don't work use a test light to check for power and ground at the bulb socket, then start backtracking the wiring through every wire connector to the turn signal switch/button and check for continuity, go all the way back to the fuse if necessary to find the cause of the malfunction. If your rear turn signals don't work check your rear fender wiring harness connector first for corroded, broken, loose pins/sockets, power, and a good ground, (the harness connector is usually located under the seat on the front of the rear fender) then keep tracing the wiring look for obvious harness damage caused by the rear tire. If you still can't find the malfunction backtrack from the rear fender wiring harness connector. If one side does not work you could have a faulty turn signal switch or module check for continuity. For more information about your issue, please visit the websites below. Good luck and have a nice day. service manuals
Oct 18, 2013 | 2007 AMERICAN IronHorse Texas Chopper
2008 Honda Nighthawk 250 front turn signal not working
Hi, Anonymous before testing any electrical component in the Turn Signal Light Circuit it is "IMPERATIVE" that you have a fully charged battery of 12.5 volts or more and be able to pass a proper "LOAD" test because your battery may have 12.5 volts or more but little or zero amps causing the battery to be faulty and must be replaced, especially "AGM" batteries, also before diagnosing any turn signal/running light/parking light issue make sure the bulb is good and the light fuse has continuity with a test light. If you have replaced your OEM lights with one or all LED lights you are going to need a load equalizer.
If all four turn signals flash at the same time like hazard lights even though you only pressed one turn signal button then you have a LED light in the circuit and need a load equalizer that can be purchased from any motorcycle parts supplier.
If your rear turn signals don't work check your rear fender wiring harness connector first for corroded, broken, loose pins/sockets, power, and a good ground, the harness connector is usually located under the seat on the front of the rear fender then keep tracing the wiring look for obvious harness damage caused by the rear tire.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
Trying to troubleshoot turn signal not flashing
My blinkers wont blink
Honda CB250 Shop Manual
https://www.partsfish.com/page/oem-parts-for-honda
Honda CB250 Nighthawk Owner Manual
Dec 03, 2012 | 2008 Honda Nighthawk 250
Ford taurus hazard lights and turn signals not working
remove bottom screws under the steering wheel remove bottom cover and then the top cover where the turn signal arm sticks out . then remove the connector attached to the multi function switch at the turn signal arm. spray real good with circit cleaner . then put connector back on. should then ,if not replace the turn signal arm which has the multi function switch attached .about 50 dollars on a 96 taurus at auto zone.
Apr 13, 2012 | 2002 Ford Taurus
Abs lights flash back and forth. They don't turn off. Right turn signal won't flash, bulb tests ok. Right rear turn signal flashes very fast. Left turn signals all normal.
Hi, you could try re-setting the abs. To do this you will need a length of 2amp cable about 500mm long, fix a small crocodile clip to one end, remove seat and search for a three pin blank connector, when you have located this put key in ignition but do not switch on at this point. Bare the end of the wire and insert in CENTRE hole of socket, put croc clip onto a good earth, then press abs button at the same time turn on ignition, count for 30 seconds, let go of abs button, switch off ignition, remove cable, put seat back on. This should reset abs. Sit back and have a beer. Cheers.
Aug 12, 2010 | 1993 BMW K 1100 RS
How to change front bulbs for turn signal for 1997 Grand Jeep Cherokee
You will need a star screw driver and a phillips screw driver. First locate the screw on the outside between the turn signal lens and the side marker lens, looken that screw. Next, with the hood open, locate a metal piece coming from the turn signal body. That metal piece (about an 1 1/2 inch long) has a star screw. Unscrew it. Pull the turn signal body off its place. Grab the connector with your right hand (thumb and index finger), turn it counter clock wise, about one centimeter. When you feel it loose, just pul gently the connector and it should come out withe the bulb. Replace the bulb and put the conecto back turning it clock wise. Reassemble all again. That should take care of it.
Jun 29, 2010 | 1997 Jeep Grand Cherokee
96 Ford Taurus no turn signals or hazards
Take the turn signal lever and jiggle it, a lot. If they start working, the switch is bad. You can also turn on the hazards and take hold of the button and push it left , right , forward and back and see if they start working. If so, replace the turn signal/ hazard switch.
Nov 24, 2009 | 1996 Ford Taurus
How to replace my turn signal switch
Multi-function Switch Removal & Installation To Remove:
To Remove:
  1. Remove the steering column trim covers.
  2. Remove the wire harness from the retainers as needed.
  3. Slide the turn signal and multifunction switch connectors out from the bulk head connector.
  4. Remove the two mounting screws and remove the multi-function switch from the steering column.
To Install:
  1. Install the multi-function switch on the steering column.
    • Tighten the screws to 42 lb in (4.7 Nm).
  2. Slide the turn signal and multifunction switch connectors into the bulkhead connector.
  3. Install the harness in the original retainers.
  4. Install the steering column trim covers.
Jun 25, 2009 | 1996 GMC Sierra
Trouble changing signal/brake bulb in trink
if you can see the sockets... they turn about a quarter turn to remove them.
Feb 01, 2009 | 2008 Chevrolet Malibu
Panasonic TH37PX60 37 in. Plasma Television Logo
43 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
