Question about Samsung ML 2010 Laser Printer
Black lines when printing or faxing
Hi, my printer shows some black lines on the copy and fax, does it need any cleaning, if yes then how do I do it? Its still new.
    Master:
    Sergeant:
  • 460 Answers
It is a catridge problem. so you can replace the catridge.
Posted on Sep 09, 2009
I have a Epson cx11 and get a black vertical line down the middle of scans and copies
Check your flat bed and Document feeder scanning glass need to be clean, if any dot or dust in scanning glass of document feeder it will appear a line, check this points first
1- Check printouts from computer or FAX if it is clean problem in scanning section
2- Check using Copying a blank paper using only Flatbed if it prints without any line its problem from document feeder Scanning glass
So solution is clean the Document feeder scanning glass using wet cloth, note careful about wet cloth switch off the machine and clean it
Feb 04, 2013 | Epson AcuLaser CX11NF Printer
Black line on copy and fax functions
Clean the paper path for the scan/fax portion. The original goes in and as the document is "read" a spot of dirt is causing the black line down the page because it is picked up in the copy area.
Dec 16, 2011 | Dell 948 All-In-One InkJet Printer
When I receive a fax, it prints out perfectly. When I make a copy or scan to fax/email, the page has multiple black lines running down the length of the page. I have recently replaced the drum and the...
As the fax receives and prints incoming faxes ok then the print engine is working ok. the fact that the problem arises when copying or scanning indicates the problem is with the scanner or software that controls the scanner.
First clean both scanner glasses and the white area (white reference) under the doc feeder. When you are happy all is clean, follow the following instructions:
Press menu, * 2864 within 3 seconds. the display will show "Maintenance"
now press 55. The scanner will initialise and go back to "Maintenance"
now press 99 and the machine will go back to the default screen showing date and time.
Now do a copy. if you still have the lines or its all black then you will need a new contact image sensor. If all is well then that was a good cheap repair.
May 26, 2011 | Brother MFC-7340 All-In-One Laser Printer
On a copy or fax there is a black vertical lineI
does line appear from both adf and flat bed? clean glass does line show up on print jobs? try cartridge then fuser
Jul 29, 2010 | HP Laserjet CM 1312NFI Color Printer
2" black horizontal line appears on paper when I fax, print,
Check the wondow where the paper passes to be scanned. You will probably find some debris or white out stuck on the glass. That is usually the cause of vertical lines on sent faxes.
Sep 17, 2009 | Office Equipment & Supplies
Won't print or copy black. won't send fax but am hooked up to a digital phone line with clear. Prints out fax report in black. test page doesn't print black ink.
for fax if u have a dsl line,u should have a dsl splitter,if analog line,its fine. u also need to claen printhead of printer and upgrade the firmware of printer,issue will be solved i tried it and it worked on my ESP-9
Aug 18, 2009 | Office Equipment & Supplies
When copying or printing a fax, a vertical black line 2-3 mm line
try cleaning the rollers with water in the feeder at the top check the glass too too see if it's dirty
Jun 27, 2009 | HP Officejet 6310 All-In-One InkJet...
Black lines printing out on sent fax
If you make a copie and the lines are on the copie then the optics's are dirty, white out, ink or fourn oblrct on glass.
If you have clean the optics and the lines are still there then the C,C,D, needs to be replaces the part that reeds the documents.
more then what the fax is worth sorry.
Feb 16, 2009 | Sharp UX B700 Plain Paper Inkjet Fax
Hp 3330 line prints on document when faxing or copying
does this problem appear when you copy from ADF? if yes check the rollers, perhaps something stuck on them.otherwise try to clean the glass
May 04, 2008 | HP LaserJet 3330 All-In-One Printer
Samsung ML 2010 Laser Printer Logo
476 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
CheckitRight
CheckitRight
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
