Question about Apple iPhone Smartphone
Can not switch on i phone
Hi i can not switch on iphone.It went charge less.Then i have put it on charge.but never switch on again.It look likes can not charge it as well.Charger is ok.I have checked it with my friends as well.please tell me what to do.
My iphone 4s fell on the floor and did not turn on again and when i put the phone on the charge it gives the apple sign then goes away and then come on and stays like this what should i do?
I would take it to the apple store and see if they can fix it. Even if it is not under warranty sometimes they will fix it or replace it for less than the cost of a new one.
Oct 14, 2013 | Apple iPhone 4S
The last 2 days my iphone 4s has gone completely dead within 9 hrs time while not being used & not on the charger. It was 75% when I went to bed and then have nothing upon waking. It's never done this...
Is this since upgrading to IOS7? If not you may have an earthling issue which could be draining the battery. If less than 12 months take back to Apple shop, they will replace IPhone.
Sep 23, 2013 | Apple iPhone 4S
Hi my iPhone 3GS is dead. I have tried everything including charging it for 8 hours, holding the two buttons for up to 12 seconds, charge through my laptop with iTunes running and much more. When I put it...
Sounds' like your battery is defective. Bring it to the apple store. If they want to charge you for a replacement phone, try to replace the battery yourself, part is on ebay and there is a guide that shows you how at : iPhone 3GS Repair Guide
Jun 30, 2010 | Apple iPhone Smartphone
Hi, my Name is Nick, I am very good at most stuff to do eith computers ect But I am stuck :( I recently bought a new iphone 3g case for my old 3g, as i have a 3gs now i thought i would put a new case on...
you can maybe try putting it into disk mode and hooking it back up through itunes to do a restore that way? sounds like its possible something got disconnected from the board good luck
Jun 10, 2010 | Apple iPhone 3G Black Smartphone
My Iphone went dead, and i was charging it through the PC....but it didnt charge...so I reset it (home + on/off) but it just went blank and the low battery sign came on again! a
Try an a/c charger, many times the usb ports don;t put out enough to give it a good charge.
If it's a 3G you have to have a charger that works on it.
May 15, 2009 | Apple iPhone Smartphone
Hi My Iphone fell down from my hand while taking photos. But then it worked fine. When I tried to switch off and switch on again, the screen went blank. Now I m able to call or attend the call.. but could...
to dissassemble an iphone 3g is very very complicatly.
Normaly you should give it to an expert.
Like: http://www.podmod.de/ for example.
But here you see how an expert can dissassemble an iphone.
http://www.ifixit.com/Guide/First-Look/iPhone3G
Here iss the Link for the old Iphone (without 3G) http://www.ifixit.com/Guide/First-Look/iPhone
i wish you luck
Jan 01, 2009 | Apple iPhone Smartphone
Is my iPhone Lost Forever?
If the phone is new then it's under warranty and replaceable. Take it in.
Oct 31, 2008 | Apple iPhone Smartphone
Iphone dead
Ok. There is a nasty rumor that only the update affects iphones that are unlocked. This is very untrue.  Whenever you try to use almost every accessory that was made for an iphone, You will encounter this problem. As well, most of these products when you plug in your iphone will cause a message to pop up stating that the device is not compatible with an iphone. and will ask you if you want to put the phone into airplane mode. Though this option is available you now have a device trying to charge, and use an incompatible device. Hence the black out. I went through those myself with a ipod dock alarm clock. Unfortunately, unlocking your phone, voids your warranty.. I will still try to to find a way to revive you iBrick but the outlook is bleak. Sorry.
Nov 08, 2007 | Apple iPhone Smartphone
Apple iPhone Smartphone Logo
Top Apple Cell Phones Experts
Computer Repairing
Computer Repairing
Lesley Cameron
Lesley Cameron
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
