Question about Samsung CLX 3160fn All-In-One Printer
Dose not print evenly
My samsung clx-2160 all in one laser colour printer dose not print evenly some of the page is correct then it has alight strip
The problem I have with my Samsung CLX-2160 is that it is only the blue which is not printing evenly - it fades out across the page. The others colours + black are all printing fine & evenly. Any...
you'll need to get to the transfer rollers and de-magnetize them. There should be a "Corona wire" that you can slide from one end of the transfer roller all the way to the other. On the other hand, you may be facing a clog in the blue toner channels, so a thorough cleanup of the entire assembly should help. Or, make a full-blue A4/letter sized document and print it out. Maybe the large amount of blue toner can de-clog the channels. Also, keep the old blue toner if it's not empty because this is not a toner issue.
Jan 11, 2011 | Samsung CLX2160 Multifunction Color Laser...
Colour printing not working
Hi ,
While printing go to the printer settings nad check if any Black print option is clicked. Also check the color cartridge status.
Jan 26, 2010 | Samsung CLX-3170FN All-In-One Laser...
Replacement transfer belt on my Samsung CLX-2160 not recognised?
enter tech mode by pressing menu>idcopy>left>right>menu>back>menu ,then in data setup clear all memory and clear count
Dec 12, 2009 | Samsung CLX2160 Multifunction Color Laser...
Wrong colours (only red and blue present) on laser colour copying
It sounds as though you may have to replace the Image Transfer Unit.
Apr 24, 2009 | Samsung CLX-2160N All-In-One Printer
Samsung CLX Printer printing unevenly
it is possible that this is a fuser prob, fuser works applying heat and pressure, if the roller, either the pressure roller or the fuser roller is defective this is most likely will happen too, you might want to  check the number of copies or prints made
Mar 22, 2009 | Samsung CLX-2160N All-In-One Printer
I can't print from Internet Explorer 7 with my samsung clx-2160
If you change the settings to grayscale it does print. Damn annoying though :-(
Jan 31, 2009 | Samsung CLX-2160N All-In-One Printer
Samsung clx-2160
Hi I asked about the CLX-2160 NOT the SCX-4100  I have had no replies yet
Regards
Anthony Showman
Nov 09, 2008 | Samsung SCX-4100 All-In-One Laser Printer
Samsung CLX 3160fn All-In-One Printer Logo
95 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
CheckitRight
CheckitRight
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
