Question about RTO Motor Scooter 50cc
Midi moto 49cc off roader will start and run but will not idle
  • 45 Answers
You need to adjust the air screw on the carb
the bottom screw in the pic
Posted on Sep 03, 2010
Tourke settings moto 200
Exhaust manifold nuts 10-14Nm
Exhaust mounting bolts 30-14Nm
Engine mounting nuts 45-50Nm
Oil drain bolt 11-15Nm
Oil filter screen cap 10-20 Nm
Spark plug 10 -14Nm
Crank case bolts 8-12Nm
Cylinder head bolts / nuts 18Nm-22Nm
Variator center nut 35-40 Nm 49cc gy6 149cc gy6 40-60NM
Clutch assembly nut for spring 50-60Nm 49cc gy6
Clutch center nut 35-40Nm 49cc gy6 1 49cc gy6 40-60NM
Gear box drain and fill bolt 9-15Nm 49cc -149cc gy6
Fan bolts 9Nm 49cc -149cc gy6
Valve lash adjusting nut 7 Ft Lbs
Standard Torque Setings
M5-Bolt or Nut--5Nm
M6-Bolt or Nut--10Nm
M8Bolt or Nut--21.5Nm
M10Bolt or Nut 35Nm
M12Bolt or Nut 55Mm
M6Bolt or Nut flanged head 12Mn
M8Bolt or Nut flanged head 27Nm
M10Bolt or Nut flanged head 40Nm
Jan 13, 2018 | Cell Phones
I have a quibo 49cc pocket bike it runs good but will not idle
you need to open the screw on the carberator prolly a 1/4 turn
Jun 30, 2014 | Quad 47 cc / 49 cc Pocket Mini Bike...
What could be causing my 49cc mini chopper motor from starting?
If its a brand new carb and you have compression and spark most likely the problem is the idle mixture screw is turned in too far or turned out too far I think the proper setting is 1and a half turns out from being lightly seated .if that doesn't work check your spark plug for proper gap or clean it
Oct 12, 2013 | Garden
49cc atv will not idle just drives
there should be an idler screw on the side of the carb. its has a spring behind it loosen the screw and see if that helps and dont loosen it too much its best to do this with it running
Oct 28, 2012 | Quad 47 cc / 49 cc Pocket Mini Bike...
I have just bought 2 midi ATV quads, I got one started yesterday and today it won't start and keeps popping when pulling the cord to start. The other one I think the engine has flooded as there is...
If it started yesterday you might have fouled the spark plug or check crank case, air intake system, and exaust pipe for dirt dobber nests if both have sat up for some time I had this problem when I bought one of the same 4wheelers what happens is the crank case builds pressure also the exaust builds pressure and will not let the motor run check for ignition spark parts are vary cheap for the pocket minies check ebay i got a exaust pipe for 13 dollers 49cc also check motosports max.com or type Kazuma.com in your search bar
Jul 23, 2011 | Quad 47 cc / 49 cc Pocket Mini Bike...
Everytime i stop for a long or short time the car will cut off i replace the spark plugs and wires and the roader cap and ball
Possible vacuum leak. Use a can of carb cleaner spray to check for vacuum leaks. Remove air cleaner housing assembly and plug the vacuum line. Start car. While idling in park, spray cleaner around base of carb, intake manifold to head area and around all vacuum lines. If the idle increases or smooths while spraying an area, that is where the vacuum leak is.
Feb 21, 2010 | 1983 Oldsmobile Delta 88
2 stroke 49cc quad engine dies when i accelerate
well it is 2 stroke so if its rev'in slow thats not dunna help . my sister had one and its the kind of thing that u don't let it idle just keep it going. thats what i found best
Nov 01, 2009 | Razor Dirt Quad Bike
Midi 49cc bike will not start. owners haven't started it for 2 years. please help!!
If it is still turning over all you probably need to do is service the carb and drain and replace tank with new gas.
Aug 09, 2009 | Quad 47 cc / 49 cc Pocket Mini Bike...
49cc 2 stroke engine
I have a 49cc cateye mini bike it starts idles fina dn every thing but when you ride it it goes fine i can reach around 55 almost 60 with the stock engine but it seems to quit on my after about 15 mabey a little less sometimes and then will not start for about another half hour
Jun 18, 2008 | 1997 Acura CL
RTO Motor Scooter 50cc Logo
242 people viewed this question
Top RTO Toys Experts
The Scrivener
Pete Bruk
rostit
Are you a RTO Toy Expert? Answer questions, earn points and help others
