Question about Husqvarna Husky 165
Local Parts ?
I live in Worksop Notts and have been looking for a shop where i can get spares ie sprocket smaller bar for small work chains and oils but i cant find anywhere and dont want to pay postage all the time does anyone know of a good place local for all my needs? Ta Matt
  • Husqvarna Master
  • 1,388 Answers
Sounds like a chainsaw issue.........this is a sewing machine forum, suggest a re-post in a different category to get a sensible response quickly.
Posted on Sep 10, 2009
I seem to be missing a tension guide for Empisal sk280 knitting machine. Can I buy one
Sorry this site doesn't sell parts or have access to any parts books . Try a local small appliance repair shop for help with this.
Oct 12, 2016 | Sewing Machines
Tip
HOW TO OIL A SEWING MACHINE
THIS IS ONLY DONE WITH SEWING MACHINE OIL.
CLEAN ALL PARTS WITH QTIPS OR RAGS PRIOR TO PUTTING OIL ON.
1. OIL THE NEEDLE BAR AND PRESSURE FOOT BAR. ALSO, UNDER THE NEEDLE BAR IS THE COUNTERWEIGHT. IT NEEDS TO BE OILED.
2. TAKE OUT BOBBIN AND BOBBIN CASE. THERE IS A SMALL AREA UNDER THE BOBBIN CASE THAT IT SETS ON. IT LOOKS LIKE A RACE TRACK. CLEAN WITH QTIP AND THEN PUT ONE DROP OF OIL ON IT. PUT PARTS BACK IN PLACE.
3. REMOVE TOP. TURN HAND CRANK TO SEE WHERE METAL TO METAL PARTS ARE RUBBING. PUT OIL ON THOSE PARTS WHILE YOU ROTATE CRANK. THE PARTS THAT ARE PLASTIC: USE TRIFLOW. THIS IS AVAILABLE OVER THE INTERNET.
4. REPLACE TOP.
5. REMOVE BOTTOM:
6. CLEAN PARTS WITH RAGS AND QTIPS.
7. LIKE BEFORE OIL MOVING PARTS THAT ARE METAL AGAINST METAL.
8. THE PARTS THAT ARE PLASTIC: USE TRIFLOW. THIS IS AVAILABLE OVER THE INTERNET.
PARTS USUALLY PLASTIC: COGS ON TOP (MAKE THE ZIG ZAGS), GEARS.
IF CLEANING IS DIFFICULT BECAUSE OF THICK GREASE THEN CARBURETOR CLEANER WORKS VERY WELL.
on Feb 28, 2015 | Sewing Machines
Looking for manual and spare parts for a janome memory craft 6500 sewing machine
Fixya does not sell parts. Try Googling (Janome)(6500)(manual) without parens.
Jun 30, 2016 | Janome Sewing Machines
I just need to know where I can get the bobbin case ?
try e-bay search for your make and model machine ending with bobbin case
try you local sewing machine service shop as most can get parts for any machine
contact the manufacturer on their web site and ask for spares
Sep 23, 2015 | Sewing Machines
I have an Elna Carina SU sewing machine and it will only sew in very small stitches and can not adjust it what is the problem
sounds like the needle bar is gunked up, has it had a service recently? ie the past two years. Has it been used regularly or has it been away for a while and now pulled out and found this problem. All machines if left for a while, internally the oil dries up and that combined with any dust or lint forms a real gunk on the moving parts. Often this results in no swing on the needle bar, ie the machine will only produce a straight stitch, no needle swing. Take it into the shop for a good clean and service.
Dec 26, 2014 | Elna Sewing Machines
How do i oil my bernina 801?
Please do not oil anything with WD40, it is an alcohol based cleaner hense why it's flammable. No where on the container will it say anything about lubricating, it will merely dry out your machine. We use it, but only to clean metal parts... we then clean it off and let it evaporate for a day before applying oil.
There are two key points I suggest customers can do themselves to help lengthen the life of their machine. One is your hook and the other is the needle bar...
Hook - Open your bobbin door, removee the bobbin case/bobbin. On the upper left corner there is a small latch, push in the latch and your shuttle race ring will fall down forward. You can now remove your stainless steel hook. You need to keep this hook clean and the lip it fits back into clean and void of lint and debris. On the back of this hook or the "lip" that the hook fits back into apply a small amount of hook/sewing machine oil.
Needle Bar - Open up your head cover, the needle and needle bar clamp is attached to a long stainless steel rod that travels vertically inside your head. All sewing machines have a needle bar that looks like this. This bar travels thru two brackets attached to the frame of the machine. Rotate your handwheel and clean the needle bar well of debris. Rotate the handwheel so that the needlebar is in it's highest point and apply a small amount of oil to the upper and lower bracket of the frame, rotate the handwheel so the needlebar slides back down and therefore lubricating it and the inside of the brackets.
Hook oil or sewing machine oil is relatively inexpensive from all quilt, sewing machine, repair shops. Be sure to take your machine in a minimum of every three years for proper cleaning and lubricating of all the other parts (This is of course for average home sewing machine use 8hours a week)
Dec 02, 2008 | Bernina Artista 180
Is there a bar oil adjustment on my 36 cc husqvarna chain saw. Where might is be? Cheers paul
If there is one it'll be underneath the saw just behind the clutch cover/side plate. Though some of the smaller cc / hobby saws don't have an oil adjustment screw. happy hunting
Jun 29, 2008 | Husqvarna Husky 165
Bernina 930 where to put oil
May 18, 2008 | Bernina Artista 180
Spare parts
go see your local teach, or repair shop. they can fix all your problems, this is your fasteat way back to sewing.
Dec 16, 2007 | Sewing Machines
Sewing Machines Logo
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
Derek Massey
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
