Question about Epson Stylus Photo 1290S InkJet Printer
Trying to print a word document
Both the red light and green light are on but nothing is printing . I was trying to print a job previously which stopped with a paper jam but there is no paper stuck anywhere in the printer
It just won't work. The light is green but I send a document to the printer and nothing happens. When I turn it on the light is red but if I put the "job cancel" button it will got to green.
Go to "Printers and Faxes" in the "Control Panel" and check to see if your printer shows any documents waiting to be printed, Cancel these documents and Right click your printer icon
select "Properties" and select "Print Test Page" to test your connection...For varies reasons documents sometimes fail to print and the printer queue backs up
Feb 22, 2011 | Computers & Internet
My printer wasn"t working when I had tried to
Hi pjmgranny !
Yes , you can cancel the previous printing jobs .
under Win XP :
go to start \ settings \ printers and faxes , select the jobs , clic on documents and cancel .
under Win 7 :
go to start \ devices and printers . Right clic on the printer , select open \ documents in queue \ select documents and cancel
Best regards ,
fanaudi .
Feb 21, 2011 | HP DeskJet D2560 InkJet Printer
Printer won't print documents. Green light on
Hmmm, try feeding a sheet of paper into the manual feed slot... you might have inadvertantly sent a Manual feed job, and the printer is waiting for a sheet to be fed by you.
Feb 10, 2010 | Dell 1710n Laser Printer
I am trying to print a document ,i press the print icon and nothing happens. the print icon is at the bottom of the srceen awaiting print but nothing.
There could a lot of possible things happening right now. For one you could have a previous job that didn't finish. So delete all jobs from the print queue. Then go to control panel and go into printers and faxes. Make sure that the printer you are trying to use is set to the default and is ready. Then try and print to that printer again and double check when printing to make sure your printing to the correct printer. If you still need further assistance let me know.
thank you,
Lee
Nov 05, 2009 | HP PSC 1410v All-in-One Printer
Printer not printing
Go to the printer properties and make sure there is not a previous print job. Cancel all print jobs. Then send a test print to the printer.
Mar 27, 2009 | Canon imageCLASS MF5750 All-In-One Laser...
HP LaserJet 4 Printer stopped printing
Try putting a piece of paper in tray 1
Feb 26, 2009 | HP LaserJet 4 plus Printer
Problem printing from my acer aspire one
Can you provide a little more information. Is the printer green power light on but neither of the red lights. Does the printer just sit there doing nothing, or does it go through the motions of printing and produce a blank sheet. If it does nothing, can you check the print queue (double click the printer icon). If there are a mass of jobs waiting (all the times you've attempted to print something), right click and select cancel all jobs. When the print list is clear, right click the printer icon and select properties. Now click on test print. If nothing happens as before, cancel this job also. Then go to control panel and uninstall the Epson printer software (the "driver"). Reboot and reinstall the printer driver. Report back if it's still not behaving.
Jan 21, 2009 | Epson Stylus C66 Inkjet Printer
The Paper light keeps flashing when theres paper in the printer
A few things could be happening here.
1. Clear the print queue, and if there are jobs that won't delete, reboot the computer.
2. Now clear the jobs on the printer (cancel job button) until the status light turns green.
3. Put a piece of paper in the manual feed tray on the front.
4. Print a test page.
If the test page prints to the paper in the manual feed tray, then it is set as the default tray. Go into the printer settings and change it to "auto" or tray 1. If the test page prints to tray 1, but the original document you tried to print (when it got stuck) still won't print, cancel the job. Now, again, put paper in the manual feed tray. Try to print the document again and if it pulls from there, go into page setup of your document and change the setting from "manual" to "auto" or tray 1. Clear the job again (if it's stuck) and you should be able to print again. Hope this helps. This is one of the most common solutions - it happens a lot, especially with documents that are emailed from other people and once they get stuck in the queue, nothing will print (except the test pages directly from the printer, like you describe).
Jun 25, 2008 | Brother HL 5250DN Laser Printer
Printer won't print on my MacBook
had the exact same problem and was ready to trash printer.  Then I played around with the print settings.  Set picture size to postcard and magically it printed.  Try it
Nov 09, 2007 | Canon Selphy CP510 Thermal Photo Printer
Epson Stylus Photo 1290S InkJet Printer Logo
27 people viewed this question
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
