Question about Hansgrohe Home
Installing a Hansgrohe raindance showerpipe no 27167000, and following the instructions of the related manual, in the picture no 14 one should mount a screw; I couldn't identify that component - there is not even a thread in the hole - nor can't I understand why this is so important (ref. the exclamation mark next to the image). What is the purpose of it and which screw should I search for??? Thanks for your answer.
    Top Expert:
  • Hansgrohe Master
  • 44,957 Answers
This is an example of communication failure between the designers and the IPB preparer. It may be necessary to have Hansgrohe explain the discrepancy.
Posted on Jul 15, 2017
SOURCE: flashing orange light with exclamation mark
Just talked to a mate of mine who said its the ASC that has been turned off. I flicked the ASC switch and problem solved.
Posted on Dec 12, 2008
  • 8 Answers
SOURCE: shower leaking at showerhead when off, can't identify model
please email pics to kjfournier@verizon.net
Posted on Jan 08, 2009
  • 24 Answers
SOURCE: what is the priming?
Prime refers to priming the pump. The error message means that there is air in the system which is preventing the pump from pumping water. To correct this, fill the tank with water, press the water button on the right side, and turn the water/steam knob to open. Allow the water to flow until the stream is steady. Press the water button again and your problem should be fixed
Posted on Feb 14, 2009
  • 68 Answers
SOURCE: i just bought a white sew ez and am unable to wind
If you look on the top of the machine, there should be a little round metal disk near the far left side. That's the clamper it's talking about, also known as the bobbin winder tension. As for the hole in the bobbin, you can use any of the holes. I'm assuming you're using a metal class 15 bobbin, the plastic class 15 bobbins only have 1 small hole on each end. Both will work with your machine.
Posted on Feb 25, 2010
SOURCE: We have no instructions for the wall mount on the
the wall mount should have came with the proper screws to fit the back of your tv, if the screws fit the mounting holes on your wall mount, fit the larger screws that came with your tv through and make sure its tight, if so it should work.
Posted on Jun 26, 2010
How do i install showerhead
REmove old showerhead using two wrenches, one to hold the stem from the wall steady, then twist the head counterclockwise. Use the same wrenches to install the new one, twisting the head clockwise to tighten. But before you put it on, clean the threads on the stem with a rag and wrap teflon plumber's tape around the threads clockwise 4-5 turns. That keeps it from leaking and makes it easy to remove in the future.
May 26, 2014 | Hansgrohe Shower 27495 Raindance S 150 Air...
Air rain shower head leaking
The most common issue with this type of head is water deposits building up in the spray face. This will cause the unit to express water from the venturi in the center of the spray face as well as other places. If this is the case the best solution is to remove the unit and soak it in CLR for about ten minutes. Then rinse it well and reconnect to the water source. Run water throught the shower head and while running rub the rubber water channels to further break up and clear out the deposits. Then repeat the process at least two more times or until the deposits are cleared out. If you need further help feel free to contact Hansgrohe Technical at 1-800-334-0455.
Jan 22, 2013 | Hansgrohe Raindance 240 AIR Showerhead ...
Hansgrohe allegro faucet leaking at base
The first thing to do is identify the faucet. If you do not know the model number the best way to identify is to send me a picture of the unit in question as it is installed. Feel free to send me a picture of the faucet to my email address at david.scarborough@hansgrohe.com. I'll be happy to help identify the unit and/or provide instructions for repair.
Dec 23, 2012 | Hansgrohe Plumbing
Slow flowing hansgrohe shower head
First thing to check is the filter screen at the hose connection on the hand shower. If this screen is clean and there is no debris in the flow restriction device inside the handle end you will most likely need to clean the hand shower spray face. You can remove the unit from the hose and soak the spray face in CLR. Follow the instructions on the container for use and dilution. Soak for no more than 10 minutes at a time. After soaking, rinse the unit well and reconnect to the water source. Run water through it and while running rub the rubber spray channels to further clear up any deposits. Repeat the soaking and cleaning process at least two more times to clear out all deposits that may be limiting your performance. If you need more help feel free to contact me at Hansgrohe. 1-800-334-0455. Press 2 for tech and ask for David Scarborough. I'd be happy to help.
Oct 29, 2012 | Hansgrohe Shower 28504 Raindance S 100 Air...
Hi, I purchased a Hansgrohe Raindance S 100 AIR 3-Jet Handshower last year. Lately, some amount of water seems to be coming out between the grey plastic and the outer-housing (instead of through the holes...
Hello david41139,
This is a sign the spray face is getting clogged or slowed by water deposits. When this happens it will slow the water going through the venturi in the head and begin to express water in the areas it would normally draw in air. The first thing to try is to soak the spray face in CLR. Follow the instructions on the container for use of the CLR. It will most likely instruct you to dilute. Then rinse the head well. Reconnect the head and run water through it. While running you will need to rub the rubber water channels in the spray face. Then repeat the process at least two more times to remove all the deposits. If you need any further assistance give me a call at 1-800-334-0455. Press 2 for tech and ask for David. I will be happy to help.
Apr 09, 2012 | Hansgrohe Home
We've installed a Hansgrohe ibox rough-in part #01850181 with a single control valve Solaris E part #04228820, (although the # on the valve is 3072474) and a handheld shower part #28518821 Raindance E 150...
It could be misplumbed behind the wall. In other words someone may have accidentally attached a "T" connection in the wrong place. It happens....
Feb 08, 2011 | Home
Shower leaking at showerhead when off, can't identify model
Jan 07, 2009 | Hansgrohe Home
Hansgrohe concealed thermostatic mixer ref no 1537418
check for sediment in your valve body... sometimes sediment can build up particularly in hot water pipes and that can cause the pressure balancing function of the valve to limit total hot water and therefore you cant get it hot enough... here is a link to what I think is the proper valve and the instructions for installing it... you'll want to follow the instructions for flushing and pressure testing... if you have good pressure at the thermo body then you might try adjusting the hot limit stop also covered in the document linked below...
http://www.hansgrohe-usa.com/JP/hrgh0264.pdf
Hope theat helps...
Oct 25, 2008 | Hansgrohe Plumbing
Home Logo
2,365 people viewed this question
Top Hansgrohe Home Experts
ray gallant
Daryl Gleaton
Are you a Hansgrohe Home Expert? Answer questions, earn points and help others
