Question about Harley Davidson Harley-Davidson Motorcycle Desktop Telephone
Oil leak I have a 93 sporty 883 with a 1200 conversion, a hypercharger I have noticed that I have oil on tube that go's into front box then comes out into bottom of carb into a tube into back box. Are these breather tubes? Should I have oil on them? Also have alot of carbon in pipes, black!! Anyone have any ideas??? Looking for some insight.
  • 116 Answers
Excessive oil comming from breathers combined with the pipes being black could be blowby depending how long ago the conversion was done if it was just done someone didnt check ring clearance or put a ring in upside down if it wasnt just done proabley time to start saving for a top end job till then nothing you can do but ride it
Posted on Feb 16, 2010
There is oil coming out through the carbs into the four rubber tubes going into what appears to be an (airbox?). Not sure what the box is for. Oil is leaking from box onto the ground through a hose that I...
air boxes usually have a hose coming out of them for just that... to drain the air box of oil or water that gets in it. it doesnt attach to anything, it's just to drain the box onto the ground instead of all over the bike.
Aug 09, 2011 | Yamaha XJ 700 X Maxim Motorcycles
My harley has a small leak coming from the air filter, the mechanic at the harley dealership told me it was the air filter. So i bought a new filter put it on and checked the oil level, with the bike...
Regrettably, a small oil leak from the air cleaner assembly is "normal". This is because the EPA requires all crankcase emissions to be routed to the intake system so that it can be burned in the engine. The result is that oil mist in the crankcase vented condenses in the air cleaner and eventually drips out.
The crankcase vent for your Sporty is in the heads. If you noticed, there are two large bolts that are hollow holding the air filter backing plate on. The crankcase vents into the air cleaner assembly through these two bolts. There is an "unbrella valve" in the rocker box center section that allows the air to flow one way but not the other. There are baffles in this area to keep the oil mist to a minimum but still there is some in the air coming out of the engine.
There are a few kits available on the aftermarket for re-routing this crankcase vent. You can direct the exit anywhere you wish using one of these kits. Most people just route the hose down and exit it under the bike just in front of the rear wheel.
When adding oil to your bike, only add the oil when the engine is hot. On your dipstick, you have two marks. The upper mark represents "FULL HOT" while the lower mark represents 'FULL COLD", Do not overfill. Check the level with the bike on the side stand.
Good Luck
steve
Oct 15, 2010 | 2006 Harley Davidson XL 1200 L Sporster...
Leaky transfer case or gearbox. Oil covering front diff.
If the front differential is covered with oil, chances are that the leak is from the pinion seal on the diff itself or from an engine leak. check all the fluids and find what is low and clean off all the residue there so you can find the source. Since the t case is behind the diff, and the air flow is towards the rear (unless you drive backwards all day long) any leaks would tend to blow towards the back, not towards the front.Once you find the actual leak source, someone here can help advise you on how the repair can be made.
May 12, 2010 | 1983 Jeep CJ7
Oil on breather tubes.
Not sure how many miles you have but oil on breather tubes (depending on how much) is normal the problem is when you have excessive blowby and high oil consumption. When was the top end done last... If never, it's due....
Sep 08, 2009 | 2008 Harley Davidson FLHX Street Glide
1986 suzuki savage
check the oil level again. trace the tube to see what it really is. make sure it isnt coming from the oil filter. had 1 that was the wrong size and was like 2mm off in length. screwed down tight but had a persistent leak. good luck. if it is the oil overflow, I used a very clean shop towel and wicked out excess by dipping it in the filler hole.
Jul 07, 2009 | 2008 Yamaha Crux
1996 Sporty Sport Oil Leak
Without seeing the bike its really hard to tell but It could be leaking from a sensor (crank position?) and that would just require a new gasket or O-ring. If its your case halves leaking then you are talking a major tear down which could cost $800 to $1200 dollars not including whatever parts they find need replacing.
Jun 05, 2009 | 2000 Harley Davidson XL 1200 C Sportster...
Oil leaking into sparkplug chamber
thread dammaged in head causing spark pug to come loose can fit heli coil to fix thread in head so spark plug wont come loose and leak oil into tube. other places oil can come from to cover plug in oil
remove rocker cover then remove spark plug tube they are screwed into head and clean thread of tube and apply sealant loctite to thread refit to head and may pay to replace seal for top of spark plug tube that is in rocker cover
one of these or both can leak, if tube is tight in head it may not be leaking the top seal is
Jun 04, 2009 | 1993 Isuzu Rodeo
Oil in intake?
sounds like blow by do a compression test
May 29, 2009 | 1985 Yamaha XJ 700 X Maxim
93 explorer dripping oil over night from bottom of car
clean the srea and watch, tracing back to the source. The oil can leak from the front seal, rear main seal,Pan gaske, or come from the top of engine. Chances are greater it's coming from the front because of fan draft. good luck
May 29, 2009 | 1999 Ford Expedition
I recently added a kuryakyn hypercharger on my sportster
The worm clamp proly did choke off the breather. Usually when oil comes out of your breathers it means there is to much oil in your oil tank.
Apr 16, 2009 | 2002 Harley Davidson XL 1200 S Sportster...
Lands Phones Logo
124 people viewed this question
Top Harley Davidson Lands Phones Experts
ted dux
Ronny Bennett Sr.
Ronny Bennett Sr.
David Payne
David Payne
Are you a Harley Davidson Lands Phone Expert? Answer questions, earn points and help others
