I have an epson SX600FX installed new black cartridge but no black print - all other colours work
I have bought new genuine Epson ink cartridges, installed them correctly and although the settings are recognizing that there are 4 full, genuine cartridges it is not printing any black ink. I have done a...
I know it sounds stupid but do you have the old black cartridge, if you do put it back and see if it is printing even if the quality is poor and faded. If it is then possibly there is a contact bad, try swittching the black cartridge for one of the other colour ones, but put a colour in to the black space but don't put the black into one of the colour spaces. If the colour one is working in the black space then it's basically a dud cartridge and bring it back to where ever you got it from. Hope it works for you - Pat
May 16, 2011 | Office Equipment & Supplies
Epson sx200 printer, wont print black ink only
Many printers especially Photo ones also use colour even when printing Black. so you do need to replace the spent colour cartridge.
If you only need to print in black get a B&W printer not a colour one.
Jan 01, 2010 | Epson Office Equipment & Supplies
Epson Stylus Photo PX800FW doesn't print text
printer working ok-did 50 colour photos ,6x4 when i made a mistake and pushed the print button when there was still about 1 inch of the previous photo still being printed.This print emerged with overprint of about 1".Thereafter the printer has refused to operate properly the next print being heavily discoloured.It then told me to replace the light magenta cartridge-this I did and the discolouration changed hew.It then told me to change the magenta and light cyan carts.-I did and discolouration changed again.It then told me to change the yellow and cyan=siscolouration now bright
red over coloured. I then successfully printed a letter in B&W proving that the black cartridge was still working.However as soon as I tried again to print a coloured photo it now tells me that the machine does not recognise the black cartridge and orders me to change it and until I do refuses to take any instructions telling me to install the black cartridge cprrectly.The black cartridge installed isout half full and has successfully printed copies and photos.I have carried out the suggested remedies by the machine and none were effectuve.How do it the infernal machine working again???
Oct 11, 2009 | Epson Office Equipment & Supplies
Bypass using any colour ink with Epson D120 printer? Possible?
Yup that's Epson for you. I had the same. bought the black one but to get it to work you must have ALL the ink cartridges full. no way around it.
Jun 10, 2009 | Epson Stylus DX6050 All-In-One InkJet...
Prints in black are poor quality
fist of all reunisall your printer driver ....
if problem dose not fix .
it means black colour laser section have problem so you can clean lens of laser if posible and replace laser secaner.
thanks
Apr 29, 2009 | Epson AcuLaser C4100 Printer
How to use only black cartridge on cx7450 epson !
Hi, this is not a solution because I don't think there is one apart from buying new inks. You need to consider 2 things, firstly the official line: Epson (and all other inkjet manufacturers) do this to prevent the coloured print head nozzles from getting blocked. If they are not used for a long time the ink dries up and blocks the nozzles. Epson recommends printing at least once a month with all colours to prevent this. Whenever the printer is turned on it performs a head clean, this is why the coloured inks get used over time even though they are not used for printing. It is also why the "print in Black only" option (available on some printers) only works when the coloured inks are OK.
The 2nd unofficial line is that it is a win-win situation for manufacturers. Firstly they get to cut down on costly warranty call outs for blocked heads (replacement printers, technician manhours, etc) and secondly they get to sell lots more inks (Ka-ching!). If you really want to print black text only (and save cash on price per-print) then a mono-laser printer is the best way as they can now be bought at inkjet prices.
Apr 06, 2009 | Epson Stylus Multifunction Inkjet Printer/...
Epson sx200 One of the colour inks is empty and no print in black
Hi, this is not a solution because I don't think there is one apart from buying new inks. Epson and all other inkjet printers do this to prevent the coloured print head nozzles from getting blocked. If they are not used for a long time the ink dries up and blocks the nozzles. Epson recommends printing at least once a month with all colours to prevent this. Printing in black only option will only work if the colored inks are OK. Whenever the printer is turned on it performs a head clean, this is why the coloured inks get used over time even though they are not used for printing.
Apr 02, 2009 | Epson Stylus CX3200 All-In-One InkJet...
Epson 1290 - I just want to print in black and white
Unfortunately, Epson printers demand that both black and colour cartridges are OK before the printer will work at all. Now, if you are really sure that you only want to print black, the most cost-effective solution for you is to buy an Epson Chip resetter on E-Bay. This will reset your empty colour cartridge to "full", as far as the printer is concerned. You can then happily continue with your black-only printing.
Feb 01, 2009 | Epson Stylus Photo 1290 InkJet Printer
Non printing epson c20ux
Sounds like color cartridge ran out. Were u using color to print black?
Try new color cartridge.
Then if you don't need color go in and set to use black cartridge to print black (text).
If you need color on something only takes a minute to turn color back on.
Since printer worked you can go in and select black which uses the black cartridge and if it prints gives validity to a bad/empty color cartridge.
Good luck.
JC
Nov 27, 2008 | Epson Stylus C20UX InkJet Printer
194 people viewed this question
jasbo
jasbo
