Question about Singer Tiny Tailor TT700
Nextar MP3 player won't work
Hi, I have this MP3 player and the first time I tried it, it took forever to start playing. The second time it played great. This time it goes to the file name but won't let me in to choose the songs. I will never buy one of these again.
Rose
    President:
  • 1,188 Answers
Seems like you are trying to play very high quality songs or their format is incorrect.
Format the mp3 player's internal memory in FAT file system. (Format is same as erasing the entire memory contents). Before copying your songs encode them in the mp3 format with bitrate 128kbps max. Try 64 kbps if it still does not work. Remember to copy your songs to the memory directly or to its predefined folders. Try not to keep folders to just one.
You can try these free software samples to encode your songs (if you already do not have one):
FreeMP3 RIP
FreeRIP
Please note that there are numerous other software for encoding tasks. I am providing the above links for reference only and have chosen them randomly. I am in no way affiliated with their developers and take no responsibility for their actions.
Posted on Sep 09, 2009
Testimonial: "Thank you so much. I will try it and see what happens. Thanks again, Rose :-)"
Hi, my elna lock f4 keeps on breaking the nr2 string. I have treid everything, changing tension...... please help
try changing the needles, also try adjusting the tension, make sure it's threaded correctly
Nov 23, 2014 | Elna Sewing Machines
Singer confience stylist beeps four time and won't let me sew
The beeps usually indicates that your machine is not ready to sew which probably means a function has been left in the activated mode, ie bobbin winder, buttonhole function, etc. . Here are some ideas:
Why does the electronic beeper beep and the sewing machine won sew Sewing...
20 Most Recent Singer 7467S Confidence Stylist Electric Sewing Machine...
Mar 05, 2018 | Singer 7467S Confidence Stylist Electric...
Start sewing about 3 stiches in and thread for bobbin gets tangled up
hi, normally that problem is associated with the top tension being too loose .. Timing could also being playing a part here ...
Regards
Rob
www.electronicrepairs.co
Dec 30, 2013 | Michley Lil Sew Mechanical Sewing Machine
Necchi serger pl1036 hand wheel screw keeps falling out
Try some removable thread locker on the screw. Then retime.
Sep 13, 2012 | Necchi Sewing Machines
Stiches form loops below the work
it's possible that the machine needs to be checked at a sewing machine shop for the timing
May 12, 2012 | New Home HF-2022
Presser foot tension?
I just found that dial too and was tempted to play, now I am glad I did not. look for a white dot or arrow that takes you back to the starting point. try that, if that does not work try oiling the machine, also if you have manual it might tell you where the dial should be for best performance. hope that helps.
you could also pull up models similar to yours on google that are for sale, if you can see a detailed picture it might show you the setting. I don't think that changes to much model to model.
Jun 15, 2017 | Bernina Sewing Machines
My computer crashed & I need to reinstall my embroidery machine. I have been thru this before when I got a different computer & know the disk won't reinstall without alot of codes & ****....
go to http--www.allbrands.com-products-abp09693.html it will tell you how to clear old code s and get new one . Then you need to reinstall disk. they tell you everything so follow step by step and be shure your Computer is window xp ,I heard Machine wont work on new Systems , anyway doublecheck on that allbrands has a nr. on there site that you can call. they may be able to help further. good luck I just had to recode my machine and that worked however i have another issue that I need help with, mine tells me threatbreak when there is none .
Jun 07, 2011 | White Sewing White 4400 Computerized...
The bobbin case turns when i sew
This little "notch" is a stopper and there needs to be a little play so the bobbin case can move approx 2-3mm and allow the thread to pass through. Adjust the spring stopper on the main body just a very little to give it some play and try again....if this was adjusted at dervice, it is not good !
Sep 04, 2009 | Singer CE-200 Quantum Futura Computerized...
White Jeans Machine
I agree about the needle, took me forever to learn that one. I have a Kenmore Sewing Machine that would not pick up the bobbin thread every time I tried it after having it for a while. I would go to my other machine and use it. Then my daughter in law put in a new needle and it worked perfect until I tried to stitch a different type of material. It was then it clicked and I started researching needles for machines. You have to use the correct size needle for the material you are sewing or it will not work right. Also if your needle is dull or bent you will also have problems. Here is a site that may be helpful http://www.taunton.com/threads/pages/t00185.asp You can find more info by searching for "sewing machine needle information" Hope this helps.
Happy Sewer
Feb 11, 2008 | White Sewing 1766 Mechanical Sewing...
Sewing Machines Logo
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
