Question about Mantis 2-Cycle Tiller
Bulb and gas lines are OK why does gas leak out the Carb.? I ran the tiller yesterday but today it will not start and the entire gas tank emptied out thru the Carb. I have not adjusted anything
  • 85 Answers
Most carb problems can be remedied with a carb. kit & cleaning.
However, this problem is solved by replacing the carb. 95% of the time.
not exactly what you wanted to hear.
Posted on Sep 13, 2009
Replaced fuel lines on my troy-bilt tiller and it ran great came back the next day gas in the lines and bulb was empty realized the bulb was cracked , i replaced the primer bulb and put everything bac
By the absence of the gas in the lines Sounds like the small hoses are cracked also, best to replace them..they do get brittle over time..best to change them periodicly... It can be a DIY job may have to loosen the carb to bend and get them on.a .very inexpensive part..and be bought at any shop or auto parts store..and not a big job for the repair shop..good luck
Sep 23, 2014 | Troy-Bilt Garden
Fuel line diagram for troy built tiller
Try reversing fuel lines. They may be connected to the wrong ports.
Jul 05, 2014 | Yard Machines Cultivator
Ryobi RY60511A tiller wont start
when the primer buld is empty, when pushed it should push bubbles into the gas tank and when let go should draw fuel from the tank. the primer buld now when pressed pushes fuel into the carb and should not push back to the tank. when let go again it will draw more fuel from the tank. the inlet nipple on the carb should be the 3 oclock
Apr 11, 2012 | Ryobi Cultivator
Runs for a few minutes and then is starved for fuel.
Replace fuel filter in tank if you have not already done so. Also clean or replace air filter. Make sure there is no leak in primer bulb ((you should feel resistance after pressing several times before starting). Make sure there are no kinks in the fuel line to the carb (if you detach line from the carb fuel should flow from the tank. Otherwise you may have carb issues.
May 24, 2011 | Mantis 2-Cycle Tiller
I HAVE A 2009 FRONT TILLER 500 SERIES. RAN FINE LAST YEAR. THIS YEAR STARTS AND STALLS. NEW PLUG, OIL IS OK.AIR FILTER IS CLEAN. IT HAS A FUEL PROBLEM. I CAN GET IT TO STAY RUNNING WITH THE PRIMER.DOES IT...
There are a few things to look at.First and easiest is check the primer bulb and fuel line for any cracks,and the in line fuel filter.Next is a filter on the end of the fuel line,inside the tank.If all of that is ok there is a small screen in the carb. you will have to tear down the carb to get it.
May 14, 2011 | Mtd Products Yard Machines 158CC Tiller
Started PB620-ST yesterday with some difficulty. However, ran until fuel empty. Refueled today, but will not start. Spark at plug ok. Fuel flowing, but seems to overflow into air filter compartment. ...
Sounds like your flooding the engine; I did the same thing. Wait a while to let the gas drain back to the tank. Use your primer bulb once and your choke for only ONE pull; then shut off the choke. Pull start without the choke 2-3 times and it should start.
Apr 30, 2011 | Echo Gas Blower 185 MPH 900 CFM Blower...
Troy Bilt Rear tine tiller model 643 Bronco, won't start,it ran out of gas, put in new gas and it started but wouldn't stay running. Put in new spark plugs, cleaned filters, changed out gas,still won't...
did it run out of gas when you added gas it could be that the fuel line has plugged up with something from the bottom of the tank take the fuel line off and try blowing threw it and take a air hose and blow out the carb and carb cleaner
Jun 05, 2010 | Troy-Bilt Pony Garden Tiller
Weedeater blower will not prime
The primer bulb sucks fuel from the tank to the carb. When the carb has enough fuel the remainder is sent back to the tank. When you replaced the fuel line did you use the exact length of line and did you re-install the filter. On some of the trimmers the filter is weighted and holds the line in the fuel. Good luck...Lee
Sep 24, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Primer bulb won't re-fill.
Not sure about your particular set-up, but there is usually two fuel lines running from the fuel tank. One goes to the carb and the other goes on a fitting on back of the primer bulb. The primer bulb will have a second fitting with a line going to carb. Sounds like either a clogged or leaking fuel line to me. Hope this helps and good luck.
Jul 11, 2009 | Garden
Gas leaking in a stream from other end of primer line
Something is causing the float in the carb to stick in a downward position. This float tells the carb when to cut off the flow, and stuck down it keeps the channel open for gas to flow through. Empty the gas and remove and thoroughly clean out the carb, making sure you hit the float bowl very well. Worst case the float could be bad. If cleaning it thoroughly doesn't get it, consider a carb rebuild kit from the engine manufacturer or replacing the carb.
May 15, 2009 | Mtd Yard - Man 160cc, 21" Self - Propelled...
Mantis 2-Cycle Tiller Logo
491 people viewed this question
Top Mantis Garden Experts
paulfvincent
Matt Olenzek
Matt Olenzek
Mike Squire
Are you a Mantis Garden Expert? Answer questions, earn points and help others
