Question about Olympus X-715 Digital Camera
Hi, turning on & it keeps opening then shutting the lense won't stay on. Got new batteries
    President:
  • 2,761 Answers
There may be something more serious wrong with the camera, but the problem you describe is frequently due to weak/wrong batteries or corrosion on the battery contacts inside the camera. Make sure that your new batteries are the correct type for the camera and that they are fully charged. If all seems OK with the batteries, remove them and wipe the camera contacts firmly with a clean dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during the cleaning, wipe both ends of the batteries with the cloth, and reinsert them into the camera. This clears the problem about 90% of the time - I hope it works for you.
Posted on Sep 09, 2009
Peugeot 307 hdi 110. lights left on battery died, put a new battery in. car keeps turning but won't start. immobliser light stays on
the car is imobalised, try disconectint the earth from battery for 5 mins and reconect, car should start
Dec 12, 2012 | Cars & Trucks
Won't stay on
Sound like a stuck lens problem; check here about fixing-lens-error-on-digital-camera.
Hope this helps; also keep in mind that your feedback is important and I`ll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using FixYa, have a nice day.
Sep 03, 2012 | Fuji FinePix A330 Digital Camera
My motorola i1 (provided by boost/nextel) phone keeps shutting off & turning back on on its own. I have never dropped my phone nor got it wet. My battery is fully charged & it only shuts off &...
Try get another battery, it could be that the present battery you are using is malfunctioning, it could be bad and that could be the reason why it is shutting off and on, first, replace the battery to check the performance.
Jul 28, 2011 | Motorola Mobility i1 Smartphone
I have a casio exilim ex-z280 and when i turn the camera on, the lens keeps closing, and stays shut. So all you can see is the shut lens on the screen. It was working last night, Now its not. Thanks...
Make sure that battery cover closed properly & the memory card is place rightly while camera is ON,
May be battery is not holding charge or possibly loose contact between camera & the battery terminal, Make sure that your battery is fully charged & place battery in battery terminal in right direction (+,-), Sometimes battery terminal gets dirty, wipe it with clean dry cloth, There could be possible that your charger is faulty and not allow battery to charge. I would recommend you to try replacing new battery before sending your device to service center.
Thanks...!! 4 thumbs rating keep us motivated to answer more free questions.
Oct 08, 2010 | Casio EXILIM EX-Z1000 Digital Camera
When opening camera, the len keeps coming out and back in
there is aproblum with lense assy it cannot access the focus & telly wide so plese go to your nearst sony service centre & fix this problum
Apr 29, 2010 | Sony Cyber-shot DSC-W55 Digital Camera
Lens keep extended in an out
Hi. I had exactly the same problem with my Sony Cyber-Shot DSC-W7. The problem started after while lense was fully open, the battery became 100% empty. I did not have access to new batteries and did not have my charger with me so I put the camera on my car seat and went home. After charging the batteries, I turned the camera Off and the lense retracted 100%. Later on I tried to transfer some pictures to my PC. After connecting the camera to my PC with the dial in the P position and lense fully open I turned the dial to play in order to transfer photos. After transferring the pictures, I turned the camera off and disconnected from the computer.
I turn the camera on to take new pictures next day, The lense would go up, and and turn with lense fully open. It would never close. The screen was black with a message "Turn the camera on and off again". I tried 30 times or more and the same thing would happen again.
Here is what I did to fix my camera and it has been working normally since then.
1- I cleaned around the outside of the lense with lent free cloth
2- I used dust OFF to get raid of the remaining small dust particles from around the lense.
3- While turning the camera off, I pushed (down, up and turn) the lense in (NOT TOO Hard) by my hand. If you push the lense too hard, you may damage the mechanicall moving parts of the lense.
4- After a few tries, the lense retracted 90% +. I then pushed the lense a little harder all the way in, the way it normall retracts. The lense cover also closed 100%.
5- I turned the Camera on and off a few times. It was opening and closing exactly the way it used to. My Cybershot has been working okay since then.
I read a lot and here is what cause my lense to malfunction.
While lense was fully open and battery died, some small particles got on the lense and prevented lense from fully opening or closing.
In summery: two things could have caused your camera lense to malfunction.
1- if you had dropped your camera hard, some mechanical parts may have got damaged or dislocated. In this case you have to open the lense and replace the damaged part, clean and put it back on the camera. This is too risky for most ordinary people. You would most likely make it WORST.
2- If you did not drop it, most likly, some how some small dust particles got on the outside of the lense and they prevent the lense or the lense cover from fully opening and closing. If this is your case, please follow exactly what I did and your camera would be back to normal.
GOOD LUCK!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Jun 25, 2009 | Sony Cyber-Shot DSC-S500 Digital Camera
Try camera on stays on for 2 seconds and then shuts off
Chage your batteries and try again. Try different set of new batteries. It is also possible some dirt somehow got on the outside of the lense and it prevents lense from opening all the way out. Clean the outside of the lense. Good luck
Jun 09, 2009 | Sony Cyber-shot DSC-S730 Digital Camera
Keeps powering on and off.
Keep in mind since you cleaned it out, only have the AC adaptor hooked up to rule the battery out. If the laptop stays on with only the ac adaptor hooked up and doesn't shut off then you know that the battery is faulty. If it still shuts off even with just the ac adaptor hooked up then it could be the ac adaptor.
Also check one more thing, with only the ac adaptor hooked up, wiggle the cord where it plugs into the laptop and see if the laptop shuts off, if it does then the dc jack on the motherboard is loose and needs to be resoldered back into place so it stays put.
May 13, 2009 | Dell Computers & Internet
Olympus X-715 Digital Camera Logo
Top Olympus Cameras Experts
Willem.
Willem.
Are you an Olympus Camera Expert? Answer questions, earn points and help others
