Question about LG WM2301H Washer
Puddle appears in washer after clothes have been removed.
My washer will run all the cycles and complete them. When I take the clothes out there is no puddle but then over night or maybe a day later there is a puddle in the tub. I leave the door open and the drawer for the detergent as well. A repair guy has been out once and said that there was air in the drain tube. But even after he "fixed" it the puddle comes back. I'm frustrated because we spent a lot of money on this machine and I expect it work properly.
    President:
  • 1,489 Answers
This sounds like a check valve for the drain hose has failed. This check valve is in the pump discharge port and prevents water left in the hose from draining back into the tub.
Charlie
Posted on Sep 09, 2009
Rl on the control panel
The "rl" (remove load) error code appears when you are running the "Clean Washericon1.png" cycle. You must not have a load of clothes in the washer during this cycle. Remove the clothes from the drum, and restart the cycle. The "Sud" error indicates that the detergent is over-sudsing. The Duet washer automatically combats this by reducing the amount of suds in the washing machine. Let the washer finish the suds-reduction steps. Use less detergent during the next wash cycle.
Oct 21, 2012 | Whirlpool Duet GHW9150P Front Load Washer
The washer is not spinning well...Clothes are partly wet when cycle is completely off...it used also to leak at one time where we can see some water when the cycle is complete...
Hello, when the clothes are partly wet when cycle is complete then check these.
1. Motor coupler
2. Spin cycle
MOTOR COUPLER; To test the motor coupler, restart the washer in it's spin cycle,let the machine runs for a minutes and then open the lid and notice if the tub is spinning: if it's spinning when you lift the lid that means the coupler is fine and if it doesn't spin that means you have to replace it.
SPIN CYCLE: If the washer doesn't reach it's proper spin speed,the cloth may be wet at the end of the cycle,check to be if the load is properly balanced and run a spin cycle again,if the clothes are still wet, you may have a worn or loose belt which you have to replace.
Thanks
Jun 10, 2010 | Maytag LAT3600A Top Load Washer
Washer not draining
Probably the pump filter needs cleaning.
It should be located at the bottom front of washer behind drop down cover, turn anti-clockwise to remove and clean.
May 04, 2010 | Bosch Nexxt 100 Series WFMC1001UC Front...
Small puddle of water underneath washer when wash cycle was completed.
That could be 1 of a couple things.
1) During the agitate cycle... some water could've made it out of tub.
2) Possible Tub Crack (or overflow line)
3) Check your inlet lines
I would run it again watching it very carefully to determine if any of these are the problem.
Dec 02, 2009 | Whirlpool LTE5243D Top Load Stacked...
Kenmore 80 washer that spins but clothes are still too wet...
to me this sounds like a clutch,
or possibly worse, your transmission that is spitting oil onto your clutch
lift the front of the washer and check to see if there is a puddle of oil on the ground. if so, its most likely your transmission. and a clutch would be a temporary fix
but if no puddle, it is most likely just the clutch that needs replacing
May 26, 2009 | Kenmore 24032\24036 Top Load Washer
Dc code appears only when clothes are in washer during spin cycle
If it’s an FAV6800A I think you may have a clutch malfunction with your machine. To verify if the clutch has malfunctioned we need to perform a quick check. Please visit this link and review my post of Solution #1 posted on Jan 30, 2009. Steps 1 & 2 should get you started and give us some troubleshooting direction. Please post back with your results or if you have any questions.
http://www.fixya.com/support/t1612027-maytag_neptune_fav6800aww_wont_spin
Good Luck… Rich.
Feb 28, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Amana Washmachine (not all water removed during spin) ALW780QAW
you may have blockage in the drain pipe several feet from washer. if you can run spin cycle with hose in different location ex. tub,sink or outdoors. if this works run long snake down washer drain pipe to clean gypsum residual.
Jan 28, 2008 | Amana ALW780QA
Washer not spinning the clothes completely
For the the initial filling of the tub, the pump is not involved. The rinse cycle is also done with fresh water supplied by the inlet valve, although the water pump may be running simultaneously to remove the water while it is being added. Try removing front (or top) cover and find the water pump. It will have connecting hoses clamped to it. Check the hoses for blockages first. Then check the pump for any objects inside or broken impeller blades. If impeller is broken, replace it only if possible --- if not, you'll need to purchase a new pump. Hope this helped.
Dec 08, 2007 | GE WBSR3140DW Top Load Washer
LG WM2301H Washer Logo
262 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
