Question about Sony Ericsson K800i Cellular Phone
THE JOYSTICK WONT MOVE DOWN CORRECTLY, IT ALWAYS CLICKS THE OPTION ON THE RIGHT HAND SIDE OF THE MAIN SCREEN.
  • 421 Answers
Sir its hardware problem go nearest mobile repair shoppe
Posted on Sep 09, 2009
Having trouble programing my extreme 3d pro joystick and FSX deluxe. I am using Vista. I can't get the elevator trim up/down to work. Doesn't even seam to work when i press 7 or 1 on the...
I would first of recommend doing a calibration of your joystick. To do that, make sure your joystick is connected to your computer and go to your start menu>>devices and printers. Once your window pops up, find your joystick and right click on the icon, and go to settings. You can find the calibration wizard there. Once that is done, open up your Flight Simulator X, and go to the settings tab. Along the right hand side, click on controls. From there you can configure your joystick buttons to whichever action you like. Please keep in mind as well when your are adjusting the elevator trim, rudder trim, that the adjustments made from one keystroke, or button push, are very very small adjustments. You can change that by moving the slider on the Repeat column, thereby making one keystroke or button push equal to multiple taps!
Sep 13, 2011 | Microsoft Flight Simulator X
My computer is unresponsive to the joystick; I plugged it into the usb port a message confirmed it was installed and ready for use but nothing happens when I move the joystick in a flight simulator or...
Hello, Here's the solution to your problem, you have to configure the games you're playing for the joystick to work, I believe all games have this option, ussualy in the "configure keyboard and mouse" options menu, click on any funcion you want your joystick to use for each button, and then press the button you want for that function, do that with all buttons of the joystick you want to use, some games need the joystick axis to be configured, just click on left/right and move your joystick in the desired direction, same procedure to up/down, if your joystick has a throttle wheel, do the same for it (if needed).
Procedure is simple and most games has small variants of this procedures I gave you, but they are simple to figure out.
Hope my solution helps, have a nice day :)
Apr 14, 2011 | Trust Predator TH 400 (12629) Joystick
How do you set the correct time ???
Press and hold the source button until the unit turns off. Then with the power off, press and hold the multi-function control (i always call this a joystick since you can move it left, right, up or down OR press it like a button and it reminds me of old video game controllers). When you press the joystick for a moment it will bring up an initial settings menu. Scroll to the clock option and press the joystick button to enter. Use left and right to select minutes and hours and use up and down to change to the correct time and you're done. Press source again to turn the unit back on and you should be good to go. Enjoy!
Dec 01, 2010 | Pioneer DEH-P5900IB CD Player
I have a 2007 Mercedes ML 350 that has a clock with hands on the dash. How do I change the time?
Its on the screen - if I remember correctly, you go to the Nav menu and you'll see a "main menu" button (it may say "settings") on right hand side (forgive me I am doing this from memory)... press the button, it will give you the "set clock" option; select daylight savings time or whatever corrects your settings and it will move the hands automatically
Nov 07, 2010 | 2007 Mercedes-Benz ML350
How can I get the small FB chat to return to lower right side of screen, I have this giant screen and hate it!
On the left hand-side of the Chat window, click "Options" and then click "Pop in Chat" or you can simply click the icon shown at the bottom right corner of the main facebook page. When you move your mouse to the icon (like double rectangle), you'll be able to see the text "Pop In Chat", click it and it'll return to it's original feature.
If you need further help, let me know.
Good luck.
Thanks for using FixYa.
Sep 02, 2010 | Facebook Social Network
I need calibration software for the logitec 3d pro joystick. will not maintain level flight in AP (flight sim ).
this was not originaly my post but i saved it.and it worked for me. HOW TO CALIBRATE THE LOGITECH EXTREME 3D PRO JOYSTICK
I just figured out how to calibrate this joystick. I am using Windows XP. I assume it will work with all Windows operarting systems though.
Go to Control Panel, click on "Game Controllers", or however you get to your joystick settings. Hold down the "Ctrl" (control key) and the "Shift" key together - at the same time, THEN click your mouse on the "Properties". This should take you to a different calibration screen that you would get to without holding the two keys together. IMPORTANT - Click on the "Test" tab first. If you go to the settings tab first, it likely will not work. Without doing anything else after clicking on the "Test" tab, next click on the "Settings" tab. Then click on the "Calibrate" button below. Click "next". Click the thumb button on the left side of the joystick which should bring you to another screen. Then follow the prompts......
* On the "axis calibration", move your joystick in full circles, making sure the "+" symbol moves around the far margins of the square. After a few complete circles, click the "next" button with your mouse.
* On the next screen, click the left button on the joystick again, which should bring you to the next screen. Move the throttle lever back and forth a few times. Then click "next" again.
* On the "Z rotation screen", move the joystick to the left and right (rotate it) a few times. Then click "next" and then "finish" then "ok". Thats it. It should be calibrated now. Hope this helps everyone with problems.
Feb 08, 2010 | Logitech Extreme 3D Pro Joystick
My touch screen on the right side no longer is working so that I can not enter any data. any suggestions
you may have to replace the touch screen itself. it should be available at pioneerelectronics.com.
Nov 05, 2009 | Pioneer AVIC-D2 DVD Nav/6.5"...
WILL NOT CONTROL AIRCRAFT HAS NO LIFTOFF
Oct 09, 2009 | Logitech Extreme 3D Pro Joystick
Fine tuning grid on my Samsung HDTV with remote.(BP59-00048)
To adjust manual convergence on your projection TV, follow theses steps:
  1. Turn your TV on.
  2. Let it warm up for 30 minutes.
  3. Press the Menu button on your remote. The Main menu appears.
  4. Use your remote to select Function, and then press the joystick.
  5. Select Convergence, and then press the joystick. The Manual Convergence screen appears.
  6. Select Red, and then press the joystick. A series of crosshairs appears on the screen.
  7. Select one of the outside crosshairs by moving the joystick up/down/right/left or by pressing the 2 (up), 4 (left), 6 (right), or 8 (down) buttons on your remote. The method you use depends on the model of remote you have. Note: You must do the outside crosshairs first.
  1. In the crosshair you selected, if you can see a horizontal red line, use the CH up or CH down buttons to move the line so that it is superimposed on the horizontal center line of the crosshair. Note: Make the single horizontal line as white as possible.
  1. In the crosshair you selected, if you can see a vertical red line, use the Vol + or Vol - buttons to move the line so that it is superimposed on the vertical center line of the crosshair. Note: Make the single vertical line as white as possible.
  1. Repeat for all outside crosshairs, and then for the inside crosshair.
  2. Return to the Manual Convergence Screen, and select Blue, and then press the joystick.
  3. Repeat Steps 7 through 10 for Blue.
  4. Press the Menu button on your remote to exit.
Important: The directions above work for most Samsung Rear Projection TVs. Yours may be different. For exact directions to perform manual convergence, see your user's manual. If you don't have your user's manual on hand, click HERE to view your manual on line.
If you cannot get your Projection TV to converge, it may need to be serviced. To arrange a service appointment, call Samsung Customer Care at 1-800-Samsung (1-800-726-7864). Have your TV's model number and serial number on hand when you call.
Jan 05, 2008 | Samsung BP59-00016A Remote Control
New JVC Everio MG 130
Hi, to set the time or date, first press the MENU button (beside the DIRECT DVD button). Nudge the joystick to the left to select which settings you want to edit. Then go up until you reach the general options. Nudge the joystick right. Move the joystick up until you see "CLOCK ADJUST". Here you can set the correct time. The light is really easy to access. In the shooting mode (where you are seeing live video from the lense), nudge the joystick down. The light should come on. Nudge it down again to put it on Auto. It will turn on/off depending on the lighting. Nudge it down a third time to turn it off. Hope this helps!
Eric
Jan 03, 2008 | JVC Everio GZ-MG130 Camcorder
Sony Ericsson K800i Cellular Phone Logo
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
270rexton
270rexton
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
