Question about Palm Treo Pro Smartphone
How do I receive and send pictures using my Palm Treo 850 phone. And when I try to answer my phone it hangs up on everyone. This occurs when I click on my green button and then my palm button to unlock. Or if I click on the palm button first and then the green button. I am so lost with this phone.
Solution to recieving pics...you can either use SMS or MMS...just click on the "envelop" key on your phone...should be top choice. Make sure you have a data plan through your service provider.
Solution to disconnect calls...Go into the settings for the phone and lock out your keypad while on a call...will stop the hang up..uless there is an internal probelm in which you would need a service tech to look at.
Posted on Sep 11, 2009
Cant receive pictures on my palm 500 treo
hi...
please call your service provider and ask for the setting. they wil send you the setting.please save it and make that setting as default so that you can start using the feature.
Jul 16, 2010 | Palm Treo 500 Centro
My palm treow 850 won't ring
if it wont ring then there might be a problem with its loud speaker so take it to product service center
Mar 30, 2010 | Palm Treo Pro Smartphone
How do i change my ringtone on palm 850 treo
Changing your ringtone should be easy. Select Applications > Preferences > Sound. Click on the TONES selection. You can set Known Caller ID and Unknown Caller ID. If you want to change your ringtone to use MP3's , then you'll need a program such as CallFilter, Lightwav or Ringo
Oct 24, 2009 | Palm Treo Pro Smartphone
I'm unable to send pictures from my palm treo 650 to email.
LOL....that is the crappy thing about this phone. Can't receive text pictures either...have you noticed that? I LOVE everything else about this phone.
I don't understand how you can surf the net, download webpages and pictures, but you can't recieve a text picture or send a picture to anyone! baffles me....but I still love this phone.
Sep 13, 2009 | Palm Treo 650 Handheld
Handling Two Calls
Actually, if you hang up on the two calls, the one call isnt "really" hung up on. Example:
Bob hasa treo and is talking to Phil & Jane swapping back & forth. Bob says goodbye to Phil and hangs up and both calls appear to get disconnected. Jane's phone never hangs up. A few seconds later, BOb's Treo rings again... it's Jane. But to Jane, it's the same call. She was never disconnected. Bob just clicks answer and he's back...
Nov 03, 2008 | Palm Treo 700w Smartphone
Palm Treo Rebooting After send an Text/SMS
Hello, hope it helps (from http://www.chaddickerson.com/blog/2006/05/19/what-to-do-when-sending-an-sms-makes-your-treo-650-reboot/)
The application that causes the reboot varies, but it’s always the same error related to the message store. Here’s how you fix it (and beware — this deletes all the text messages on your device!):
  1. If you don’t already have it, you need to download and install FileZ on your Treo. All this does is give you access to all the files on the Palm OS filesystem. This is a tool that must be used very carefully, since you can move, copy, and delete any files on the Treo, even ones you didn’t know were there. It’s one of the most useful Treo utilities you can have.
  2. Run FileZ on your phone and choose “View and Edit Files.” In the next screen, you should see “Internal” under Filename. It might also say “ROM.” If you have an SD Card, you should also see “External” or “SD Card.”
  3. Click on the little wedge beside “Internal” to expand the list of files on your Treo.
  4. Find Messages Database and delete it (you do this by checking it, choosing “Details,” and then clicking “Delete”)
Apr 01, 2008 | Palm Treo 650 Handheld
Palm treo 750 not ringing
Taking the battery out to switch your phone ON/Off can cause serious problems.
To receive calls, your phone must be on.
This is different from having only the screen turned on (see Turning your phone on). When your phone is off, your calls go to voicemail. To see a picture of the person calling you!
Learn how to assign a caller ID picture in Assigning a caller ID ringtone. If music is playing when a call arrives, the smartphone rings softly. You can answer the phone as you normally would. The audio pauses during your call. To answer a call, do one of the following:
• Press Phone/Send .
• Press Answer (left action key).
• If the headset is attached, press the headset button.
To ignore a call and send it to voicemail, press Menu (right action key) and
select Ignore or press the Power/End key.
Waking up the screen and turning it off.
Wake up the screen and leave the phone turned off when you want to use only the organizer features of your smartphone, for example, when you’re on a plane and want to look at your calendar. You can also turn off your smartphone’s screen without turning off your smartphone’s wireless features. You can turn your screen on and off by pressing Power/End.
Mar 08, 2008 | Palm Treo 750 Smartphone
Treo 600 dropped calls
Try hard reset your phone
Dec 15, 2007 | Palm Treo 600 Handheld
Treo 700w
depending on how you hold the phone this could be the answer you are looking for since your problem only occurs sometimes. see how you hold your phone as you put it up to your ear where is your thumb you might be pressing on the lower part of the screen. this will mute that call. causing you to hear them but they will not be able to hear you. next time you make a call and the other person can not hear you look at the screen and see if the picture of the mic in the lower right hand corner is greyed out if it is press it and it should work. I know this answer sounds silly but it happens to me alot.
Oct 15, 2007 | Palm Treo 700w Smartphone
Phone Freezes
If you mean that the phone hangs for a couple of seconds and then hangs up the call - I think I found your solution - http://www.wombatnation.com/2006/03/fix-for-treo-600-hangs My Treo was doing the same thing - so I just reseated the battery connection and it fixed my problem.
May 30, 2007 | Palm Treo 600 Handheld
Palm Treo Pro Smartphone Logo
266 people viewed this question
Top Palm Cell Phones Experts
fhonwizards
wayne chamberlain
Are you a Palm Cell Phone Expert? Answer questions, earn points and help others
