Question about Jabra BT160 Wireless Headset
CHARGING My Jabra bt160
My Jabra bt160 headset was lost for about 5 months, Ijust found it but can't get it to charge.
  • Anonymous Dec 12, 2007
    for got my password is there any other way to find out my code
  • Anonymous Mar 23, 2014
    When I put it on charge the blue led flashes but no charge appears to be going into the earpiece. All connections are good.
I have the same problem
Posted on Feb 18, 2008
I think something's goofy with these headsets. I bought 2 of them recently (one for me and one for my g/f). Within a week or so, she told me hers just "died" - and she couldn't get the blue light to come on when it was plugged into the charger.
Mine acted dead too, just a day or so before she told me about her problem. On mine, I think I just held down the "volume down" button and the main button at the same time for about 15 seconds and it appeared to "reset" it. That apparently didn't work for hers, but oddly enough - after a few days, we plugged it into my charger and it started working again!
Posted on Dec 11, 2007
WHY IS MT BT2020 NOT CHARGING
Batteries have died as these batteries only have a certain life span after that they dont charge!!! C if the batteries can b changed....
Jun 29, 2014 | Jabra BT160 Wireless Headset
I do not have manual for jabra bt160 how do i connect to phone
Wear it how you like it 4
5
English
The Jabra BT160 is ready to wear on your right ear. If you prefer the left, gently flip and
rotate the earhook 180°. (See fig. 2 )
For optimal performance,wear the Jabra BT160 and your mobile phone on the same side
of your body or within line of sight.In general,you will get better performance when
there are no obstructions between your headset and your mobile phone.(See fig.5 )
Answer a call
Tap the answer/eend button on your headset to answer a call
End a call
Tap the answer/eend button to end an active call
Reject a call (DDependent on your phone supporting this feature)
Press the answer/eend button when the phone rings to reject an incoming call.
Depending on your phone settings, the person who called you will either be
forwarded to your voice mail or hear a busy signal
Make a call
• When you make a call from your mobile phone, the call will (ssubject to phone
settings) automatically transfer to your headset
Activate voice dialing (DDependent on your phone supporting this feature)
Tap the answer/eend button. For best results, record the voice-dialing tag through
your headset. Please consult your phone ’ s user manual for more information about
using this feature
Redial last number (DDependent on your phone supporting this feature)
Adjust sound and volume
Press the volume up or down (+or – ) to adjust the volume (See fig. 1 )
How to...5
Before you use your Jabra BT160, you need to pair it with your mobile phone.
1. Put the headset in pairing 2 mode
Make sure that the headset is on.
Press the answer/eend button and press the volume up (+) button at the same time,
until a solid blue light comes on.
2. Set your Bluetooth phone to ‘ discover ’ the Jabra BT160
Follow your phone ’ s instruction guide. This usually involves going to a ‘ setup,’
‘ connect ’ or ‘B luetooth ’ menu on your phone and selecting the option to ‘ discover ’
or ‘ add ’ a Bluetooth device.** (See example from a typical mobile phone in fig. 4 )
Pair it with your phone 3
English
Turn on your headset 2
Press the answer/eend button to turn on your headset
Press and hold the answer/eend button to turn off your headset
Charge your headset
Make sure that your Jabra BT160 headset is fully charged before you start using it. Use
the AC adaptor to charge from a power socket. Connect your headset as shown in fig. 3.
When the LED is solid blue, your headset is charging. When the solid blue LED turns off,
it is fully charged.
The Jabra BT160 is easy to operate. The answer/eend button on the headset performs
different functions depending on how long you press it.
Instruction:Duration of press:
Tap Press briefly
Press Approx: 1 second
Press and hold Approx: 5 seconds
Getting started
3. Your phone will find the Jabra BT160
Your phone then asks if you want to pair with it. Accept by pressing ‘ Yes ’ or ‘ OK ’ on
the phone and confirm with the passkey or PIN 3 = 0000 (44 zeros).
Your phone will confirm when pairing is complete. In case of unsuccessful pairing,
repeat steps 1 to 3.
http://www.jabra.com/Sites/Jabra/UK-uk/support/Pages/JabraBT160.aspx
It is all in there www.jabra.com
ARTGIRL
Jul 18, 2008 | Lands Phones
My jabra BT160 is not getting connected to my nokia 7610 when ever i search for the device the results r no device found.
hold down the front button and your + volume key for 3-5 sec. that should put it in pairing mode.
Jun 04, 2008 | Jabra BT160 Wireless Headset
Jabra BT160
The default Jabra password seems to be 0000
Give it a try - it may work
Good luck
Feb 25, 2008 | Jabra COMMUNICATIONS BT160 Bluetooth...
My Jabra BT160 won't connect to my Nokia 6103 why?
hold the on/off button and the + button for 2 min. If you fail at the first time. Try again, until you see the blue solid light. Search again in your phone, you should see Jabra bt160. Enter 0000 at the passcode. Good luck
Nov 07, 2007 | Jabra BT160 Wireless Headset
Jabra bt160
hold the button down for a long time
Apr 17, 2007 | Jabra COMMUNICATIONS BT160 Bluetooth...
Jabra BT160 Wireless Headset Logo
417 people viewed this question
Top Jabra Radio Communications Experts
Greg Cann
Greg Cann
Michael Vincent Cruz
Jerry Greenberg
Jerry Greenberg
Are you a Jabra Radio Communication Expert? Answer questions, earn points and help others
