Question about Yamaha RX-V530 Receiver
Yamaha AV Amplifier RX V530
The problem that I am having with my amplifier is that everytime that I switch the amplifier, it powers off after 2 seconds. Can anyone help??
All the output transistors and driver transistors are ok.
  • 52 Answers
You might have your speakers shorted. Check the wiring at the amp and speaker terminals
Posted on Sep 01, 2010
How do I connect my 901 equalizer /speakers to the yamaha rx-v633 receiver?
Sorry, it doesnt look like you can hook up an external EQ while still using the amplifier section of the yamaha. Instead, You would have to use the preamp out to go to 901 EQ, out of the EQ into another stereo amplifier, then to the 901 speakers. Personally, to power the 901's properly, I'd use another external amplifier. You will barley get 75watts per channel out of the receiver to power the 901's
Jan 03, 2015 | Yamaha Av Reciever Rx-v793 Cinema Dsp...
I have a Yamaha RX-V340RDS amplifier and need to know how to connect my tv, dvd recorder and hd-pvr
manual found here: http://www2.yamaha.co.jp/manual/pdf/av/english/re/RXV340.pdf
Mar 23, 2014 | Pioneer VSX-D608 Receiver
I have a RX-V1000 Yamaha Receiver. I recently added on speakers for my back yard, but would like to run them independent of the receiver. Meaning I don't want to have to have speakers in the house on...
Any Tape Out (REC) is flat Line Level output for any analog source selected by the RX-V1000.
Or you could just set up Zone 2 as on Page 61 in the manual - with or without the remote capability.
Sep 13, 2011 | Yamaha RX-V1000 Receiver
Does the yamaha RX-V1900 have analog zone two output
Yes your amplifier has assignable multi zone capability .You have to go into the initial setup of the amplifier and select if you want to assign any one of the amplifiers ( eg: rear back amp ) as zone 2.
May 22, 2011 | Yamaha RX-V1900 Receiver
Our 2nd zone won't work, we get the error saying check SP wires. The wires seem connected correctly. We also can't change the volume on zone 2. The Yamaha unit is working otherwise.
U cant get an amplified out put form ur av receiver for zone 2. speaker a A and B is the same out put of frond left and right. it is not ZONE 2 output. U can get only a pre output for zone to from this receiver. U nee a separate stereo amplifier for using zone 2 .put an amplifier in the other room, connect the zone 2 pre out to it. And do the following setup in ur av receiver .
The receiver shows check speaker cable because its amplifier minimum impedance is 8 ohms . when u connect other speaker in speaker the total impedance will come under 4 ohms. Speaker b is not ZONE 2 in this amplifier
1. press the input selector button A or B to select the source component you want to setup.
2. press and hold LEARN (on remote) button about 3 seconds by using a boll pen or similar object ( SETUP and the selected component name appear alternately in the display window.)
3. press up or down arrow to select "zone2"
4. press LEARN to complete the Zone 2 setup.
5. press source select up arrow to display Zone2 in the window.
6. press an input selector button to select input source u want to listen to in the second room
7. u can control the component by using the component control area button
ok
Dec 26, 2010 | Yamaha RX-V2200 Receiver
I have a Yamaha RX-797 reciever and wish to install an outdoor speaker system through the zone2 outlet. Do you know if I can go from the zone2 outlet through the coupler jacks to the speakers so I can...
Hello sounds like you want to take the low level zone 2 output and run it to the PRE AMP in?
If that is correct the onboard amplifier will power your speakers but will no longer provide sound for your main channel as you are removing the "loop" which send the front L & R signal to the amp.
Your best bet is to find an inexpensive secondary amplifier.
Sonance makes a sonamp 260 or 260x3. These are available on ebay for under $100 and work great for multiroom applications.
A 260x3 would give you 3 speaker outputs allowing you to run not only to your patio but also to two other locations and includes a switch to turn each zone on/ off.
Hope that helps
Jan 02, 2010 | Yamaha RX-797 Receiver
Yamaha amplifier no power
check the MAIN POWER SUPPLY for a possible blown fuse . thanks AJ
Dec 23, 2009 | Yamaha RX-V461 AV Receiver
The unit does not work
check the standby power supply first and then the main power supply.also check the output transistors and fuses your problem is in one of those points, normally the standby transformer goes bad, it is the small one right next to the big one.
good luck
May 21, 2009 | Yamaha RX-V463 Receiver
DENON AVR-1404 switch on problem
Maybe the audio amplifier IC´s are damaged that´s why go on the protection mode
Jul 21, 2008 | Yamaha RX-V461 AV Receiver
Yamaha RX-V2400
Get another receiver! I had the same problem and had the power supply replaced $250 and after 3 months it started doing the same thing.  I just purchased a Pinoeer Elite VSX 90TXV.
Jun 04, 2007 | Yamaha RX-V2600 Receiver
Yamaha RX-V530 Receiver Logo
227 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
