Question about Nikon D80 Digital Camera with 18-135mm Lens
Nikon d80 how to reset nikon d80 camera
    Brigadier General:
  • 4,090 Answers
RESET Find the two buttons with green dots next to them on the top right of the D80. They are the +/- * and AF * buttons. Hold them both down for a few seconds. The top LCD blinks and everything is back to normal.
Please rate our help to keep the FREE service online++++Thanks for using FIXYA
Posted on Sep 09, 2009
4 Suggested Answers
SOURCE: Nikon D80
i had the same problem occur a couple of times. i found that removing and reinserting the lense cured it!
Posted on Feb 11, 2008
  • 7 Answers
SOURCE: Nikon D80 Camera
During shooting, or when the shutter-release button is pressed halfway, the number of images that can be stored in the memory buffer at current settings is shown on the exposure-count displays in the control panel and viewfinder. "r06" indicates that six images can fit in the camera's buffer, "r08" would indicate eight frames. Any other number could be displayed as well. Burst mode is used when you want to hold down the shutter button and continuously shoot. You are probably shooting in burst mode and your buffer is full, set the camera to single shot and see if that helps.
Posted on Jul 21, 2008
lock123
  • 6831 Answers
SOURCE: nikon d80 will not take pics has err flashing in
Hello
The problem is that the lens has become stuck in the barrel after dropping it. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
Hope the advise is useful.
Regards
Andrea
Posted on Aug 31, 2010
Everything on control panel is flashing. Can't operate camera.
Hi Shirley,
It sounds like your camera's CPU is stuck in a loop. First, I'd remove and transfer any pictures on the SD card in a card reader connected to your computer, followed by formatting the card. Leave the SD card out of the D80. Set the power switch on the D80 to "off" and install a freshly charged battery. If it is still flashing, a "Full Reset" may help.
Nikon recommends that a full reset be done only under direction of Nikon staff. The procedure is outlined along with graphics on this page under "Full reset". I suggest calling Nikon support to see if they think this procedure (or maybe another that they have) will solve the problem.
Nikon Technical Support
8AM - 12AM (Eastern)
7 days a week
1-800-Nikon-US
1-800-645-6687
Jan 09, 2013 | Nikon D80 Body Only Digital Camera
Nikon D80 in fine setting but not sharp images
To reset the camera, press and hold the Exposure Compensation and AF Mode buttons simultaneously for two seconds.
Dec 27, 2011 | Nikon D80 Digital Camera with 18-135mm...
Reset Nikon D80 to Factory Defaults
Find the two buttons with green dots next to them on the top of the D80. They are the +/- * and AF * buttons. Hold them both down for a few seconds. The top LCD blinks and everything is back to normal.
Nov 17, 2010 | Nikon D80 Digital Camera
My nikkon d80 is showing err what ot do
This is a very often asked question. The answer has been posted many times on this site: The ERR message is not a good thing. Read page 132 of the D80 Manual. Also, try a factory reset found on page 129 of the manual. On the left side of the camera is the terminal cover, inside below the USB connector is the reset switch. If that does not work call Nikon digital 1-800-645-6689.
Aug 29, 2010 | Nikon D80 Digital Camera with 18-135mm...
D80 err message . what can I do to fix without sending the cam in? I have already did the reset and nothing so far is working..
Page 132 of the D80 manual states the ERR is a camera malfunction. My suggestion is to rest the camera, see if that helps you will find those instructions on page 129 in the D80 manual. Sometimes removing the batter then pressing the shutter release numerous times will free up any static buildup. If none of that works it is off to Nikon.
Jun 20, 2010 | Nikon D80 Digital Camera with 18-135mm...
ERR error code. When I try to take a picture nothing happens.
The ERR message is not a good thing. Try a factory reset found on page 129 of the manual. On the left side of the camera is the terminal cover, inside below the USB connector is the reset switch. If that does not work then it will need to go call Nikon digital 1-800-645-6689.
May 13, 2010 | Nikon D80 Digital Camera with 18-135mm...
Nikon D 80 digital Camera
Apr 13, 2010 | Nikon D80 Digital Camera with 18-135mm...
I have a Nikon D80. The flash is not working.
if u r getting green signal of flash charging,then discharging section is defective,sochaque the section replace the parts xenon tube etc or take it to a tech.
Apr 02, 2010 | Nikon D80 Digital Camera with 18-135mm...
My nikon camera keep got error and dont have the
You have not provided enough information, what is the error read? If it shows ERR then: The ERR message is not a good thing. Read page 132 of the D80 Manual. Also, try a factory reset found on page 129 of the manual. On the left side of the camera is the terminal cover, inside below the USB connector is the reset switch. If that does not work call Nikon digital 1-800-645-6689.
Mar 24, 2010 | Nikon D80 Digital Camera with 18-135mm...
Nikon d80 does it records
if you mean take videos.. the nikon D80 does not support the video function..it is a picture only camera.
Oct 30, 2008 | Nikon D80 Digital Camera with 18-135mm...
Nikon D80 Digital Camera with 18-135mm Lens Logo
527 people viewed this question
Top Nikon Cameras Experts
Ric Donato
Are you a Nikon Camera Expert? Answer questions, earn points and help others
