Question about Dell - NPS-200PB-73M (NPS200PB73M) Power Supply
How many ways can i break this
Dell xps m140 laptop turned off in mid down load. thought battery or power supply,bought new ones.Now have tested the processor, changed hard drives,memory, STILL NOT EVEN CHARGE LED WHEN PLUGGED IN.
doesn't spell the burned plastic so any hope way to at least the cause of death????
    Sergeant:
  • 193 Answers
Most likely cause of death: motherboard charging circuit. there isn't a simple way to fix this one, i reccomend you get a new motherboard.
Posted on Sep 09, 2009
Test dell xps 210 power
Most laptop power supplies are made for a particular brand, so the best way to test is in another Dell laptop. The other way is using a voltimeter, first testing the power cord alone, and then testing the tiny connector.
Aug 25, 2012 | Dell XPS 210 PC Desktop
Need to reset the bios password on my dell xps m140 laptop.
You would have to reset the whole bios to default which maybe something you cannot do. The only other method would would be to take the laptop apart and remove the battery that keeps the motherboard BIOS memory powered. It should look like a large watch battery. Remove for 5 to 10 seconds, and replace. Then put the laptop back together and that should reset the BIOS, password and all.
Apr 27, 2011 | Dell Inspiron XPS M140 Notebook
Dell xps m140 press the power button green lights come on then go off nothing ever comes on screen
dead motherboard or power supply or powercord and or battery try another power cord if nothing take out battery and try to start with out battery if neither works then it will need either a motherboard or power supply
Oct 17, 2010 | Dell Inspiron XPS M140 Notebook
My Dell XPS M140 has gone thru 3 power supply/cords in the last 2 months. With a new supply it just makes a loud hum.
try upgrading your power supply, if you're burning through them then theres a good chance that your power demand is higher then the cords are rated for. Replacing a power supply is quite simple as long as you ground yourself to something metal to make sure you don't manage to accidentally discharge static into your mobo. Also make sure that you're at least somewhat comfortable performing this task if not then id personally advise that you find someone who will
Feb 06, 2010 | Dell Inspiron XPS M140 Notebook
Hello, i got a DELL 700m. it did not start. i didnt make anything... no sound, no beeps, no lights, no fan spinning... just nothing. Powersupply is ok, i tested it with a defintivly working one from my...
Looks like the input for your power has failed... a common problem. You will need to open up the laptop and have the power jack replaced. Happy New Year to you and yours
Jan 05, 2010 | Dell Inspiron 700M Notebook
Where are the memory slots on a dell xps m140 laptop?
One memory module, ('Stick') slot is located on the bottom of the laptop, in the Memory Compartment. (Has two Philips screws on the cover, and is located close to the battery release button)
The other memory module goes under the keyboard.
Here's how to replace them from Dell Support,
http://support.dell.com/support/edocs/systems/xps140M/en/sm/upgrades.htm#wp999869
Sep 02, 2009 | Dell Inspiron XPS M140 Notebook
Xps m140 want higher resolution displayed tonew secondary monitor
Notebooks usually don't have high res . They trade off the high resulation  for the small size and less power consumption.
Mar 07, 2009 | Dell Inspiron XPS M140 Notebook
Dell XPS M140 laptop shuts off after powering on
Most laptops that I have worked on that power off that quickly turned out to be an overheating problem. Is the cooling fan running for the brief period that you can hear the hard drive before it powers off ? If the fan is running another potential resolution might be to remove the processor and apply new thermal paste.
Nov 10, 2008 | Dell Inspiron XPS M140 Notebook
DELL XPS M140
One of three things, 1- power supply, check your power supply with an ohm meter to see f it's getting the proper output to the machine. If the supply is starving the machine of power the charging system won't work to it's full potential. 2- the power management system on the motherboard, if this system isn't working properly it can divert power from the charging system. If it's just glitched then a bios download or chipset utility download will fix it, if it's malfunctioning, then motherboard replacement is the only option. 3- the battery itself, I have a Dell, and in the past two years, I've ordered two new batteries. The first held a great charge, more than three hours, but only lasted about eight months. The second only holds little more than an hour charge, but has lasted well. Batteries are just funny that way. Start with the power supply test.
Aug 23, 2008 | Dell Inspiron XPS M140 Notebook
Computers & Internet Logo
80 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
